Question about Dell Inspiron B130 Notebook
BATTERY LIGHT FLASHES ORANGE
MY B130 BATTERY INDICATOR LIGHT FLASHES ORANGE. I HAVE TWO DELL BATTERIES AND AFTER IT REACHES FULL CHARGE IT STARTS FLASHING ORANGE 4 TIMES THEN GREEN THEN ORANGE 4 TIMES AND ON AND ON. WHEN I UNPLUG AND RUN ON BATTERY POWER WITH EITHER BATTERY IT DOES THE SAME THING. DELL SAID IT COULD BE A MOTHERBOARD PROBLEM BECAUSE OF THE PROBLEM SHOWING UP WITH DIFFERENT BATTERIES. DOES ANYBODY HAVE THE ANSWER?
  • 60 Answers
The flashing battery light is an indication that the system is attempting to charge the battery. The orange light indicates a problem charging one of the battery cells. This usually means that the battery either needs to be recalibrated or replaced. To recalibrate the battery just use the system until the battery is dead, then recharge and repeat the process twice, after which time the battery should be recalibrated. If this doesn’t fix the flashing orange light then the battery may need to be replaced.
ps. you could try putting it in the freezer over nite covered with glad wrap or something to protect from freezer burn then leave out on room temp for a few hrs well. "disclaimer(this is my own suggestion and is not in any way covered by the manufacturer but you may try it at your own risk)"
Posted on Feb 20, 2009
  • rtrtrtrt Sep 07, 2010
    The amber flashing light simply means the battery is fully charged.
    This usually happens with a replacement battery not manufactured by Dell.
    Not a big deal.
    If you open your power meter (right click on the icon) and notice the charge continues to diminish even while plugged in and indicating "charging"
    You should unplug and use your laptop until the battery is depleted.
    You can set adjust the power properties (right click on the same icon) to hibernate when the critical battery reaches 5% so that you don't lose any work in progress.
    If the battery will not begin to recharge after running it down and plugging back in, leave your laptop plugged in, remove the battery and lock it back in place.
    The computer will reset and the battery begins to recharge again.
    This appears to be a feature that occurs in replacement batteries to ensure the battery is kept at an optimal charging capacity.
  • michelle hewes Dec 08, 2011
    thank you dragoness for your comment, your solution worked for me!
    Novelist:
  • 148 Answers
if you have tried both batteries with the same laptop and they are giving you the same error code, then it could very well be a motherboard problem, both the batteries cannot be bad, what you can do is try these batteries on some other compatible laptop model to check if they work fine there. Also try swapping the AC adapter as in both case you might be using the same Ac adapter, try using some other good known AC adapter as well.
Further queries are welcome
If you find my solution helpfull please do rate me
Battery light flashing orange
Your battery may have Battery charge status indicator, when you press the button next to the 4 led indicators the LEDs indicate the charge status.
Also the System Battery/Charge LED indicates the battery's current operational condition.
Flashing orange indicates Battery failure.
May 25, 2012 | Dell Inspiron Mini 10v Netbook Computer
That means that the battery is faulty. It starts reaching certain level and then it starts blinking. You laptop is ok, it's just the cells inside the battery are going bad. So just replace it. Try to find an original battery because those replacements are not that good and it is not going to last very long. Dont forget to rate if my answer helped you. Thank you :D
Apr 28, 2010 | Dell Inspiron 1525 Laptop Midnight Blue
Battery indicator flashing red when running on battery or on main supply and battery is 75% charged
When your battery indicator is flashing Red, it usually means that the charger is defective.
Dell also had a recall on some of its batteries. To see if you qualify for a free replacement click here: http://www.dellbatteryprogram.com/
If you want to reset your battery utility follow these steps:
1. Let the battery run completely dead. (Make sure all your work is saved)
2. Fully charge battery (You may still have flashing lights but if you turn your computer on and enter BIOS you can see the charge level)
3. Once again run battery dead.
4. Remove battery and wait 5-10 minutes.
5. Replace battery and use in normal operation.
If you found this information helpful, please give me a big thumbs up when you rate my answer. Thanks!
Feb 03, 2010 | Dell Latitude D600 Notebook
I have a Dell Inspiron 1525 that won't start. The battery light would flash orange 4 times then blue once, and then start over with the same sequence. Pulled the power board and fixed the solder joints on...
This is directly from the User Manual:
If the computer is connected to an electrical outlet, the Battery light operates as follows:
• Solid green: The battery is charging.
• Flashing green: The battery is almost fully charged.
If the computer is running on a battery, the light operates as follows:
• Off: The battery is adequately charged (or the computer is turned off).
• Flashing orange: The battery charge is low.
• Solid orange: The battery charge is critically low.
Dec 27, 2009 | Dell Inspiron 1525 Notebook
Dell latatude D630 is docked/battery flashing 4 red 1 green
4 orange and 1 green can mean a battery malfunction, or it could be an indication that the battery is about to reach the end of its life cycle. When a battery is built, it has a planned expectancy. a date code is stamped in the electronics of the battery pack. as that date code is reached, the indicator lights on the computer let you know the battery (even if its working fine) is considered obsolete and needs to be replaced soon.
Nov 05, 2009 | Dell Latitude D600 Notebook
Red Battery light flashes when computer is turned off
The reason the battery indicator would flash is because its reaching the end of its useable life. Meaning that it will become harder for the battery to keeps its charge until it finally doesn't keep a charge at all. best thing to do is when your not using your laptop unhook the charger to it so its not always charging the battery.
To fix the problem though you'll have to get another battery unfortunately.
Jun 02, 2009 | Dell Inspiron B130 Notebook
Dell latitude D600 battery charge light flashing
That usually indicates battery is beginning to go bad. Eventually it will not hold a charge and will need to be replaced.
Your responses are intended to improve the level of service provided. Please show your appreciation by rating your experience.
Thank You.
Nov 09, 2008 | Dell Inspiron E1705 Notebook
Orange/yellow light
Seems the light indicates a defective7bad battery. Removed the battery and the laptop works fine. Thanks to those that responded.
Sep 09, 2008 | Dell Inspiron B130 Notebook
Orange and green light flash
hope this helps
Jan 07, 2008 | Dell Latitude D600 Notebook
Dell Inspiron B130 Notebook Logo
2,316 people viewed this question
Brian Sullivan
Brian Sullivan
mukhtar21 shaikh
mukhtar21 shaikh
