Question about Acer Extensa 5420-5687 Notebook
Unable to connect unless hard-wired ethernet cable.
Is there a physical on-off switch for wireless on Acer Extensa 5420? Where is it?
    Scholar:
  • 75 Answers
There is a WLAN switch located at the front panel of your laptop. It looks something like this (( /\ ))... you need to switch it on for Wireless to work mate :-)
Posted on Feb 20, 2009
    Novelist:
  • 148 Answers
yes there is acer utility for wireless which usually can be accessed through the acer E button on the laptops
and if the wireless is set to be controlled by this utility then you will not be able to control it using standard windows utility no even on/off
here is a link to the manual
ftp://ftp.work.acer-euro.com/notebook/extensa_5420/manual/OLM_ENG.pdf
Further Queries are welcome
if you find my soilution helpfull please do rate me
Need network adapters, ethernet controller and mass storage controller for Acer Extensa 5420-5438 laptop
You should be able to install applications and drivers using system recovery partition.
Start/programs/acer/recovery
Mar 27, 2013 | Acer Computers & Internet
Extensa 5420 Blank at boot
you have a brand new hard drive... probably cable is not fitted properly and the memory contacts needs cleaning. try it... good luck.
May 19, 2012 | Acer Extensa 5420-5687 Notebook
My wireless network adapter is gone? My wireless modem can not connect to my ACER because I do not have a wireless network adapter.
I may not understand you on this because the 5420-5687 notebook should have come with a wireless connection.
Does your "Modem" have both wireless and a hard wired LAN " For instance my "Modem" came only with a hard wire LAN" and no wireless transmitter. I needed to buy a "Wireless Router" to tramsit between the "Modem" and then wireless on my ACER 5420-5687.
If the "Modem" had both the hard wired Lan and a Wireless transmitter it should be able to go directly without the "Wireless Router". If that is true you should see the amber flashing light, on the last in the group of 4 below your touchpad. If it is not flashing as I said above, it is either not sending/receiving or likely not turned on. The on/off switch is alternately turned on/off by sliding the switch below the light to the right.
Hope it helps. I tend to get a little too wordy.
Rocky
Feb 08, 2011 | Acer Extensa 5420-5687 Notebook
Laptop acer extensa 5420 drivers, bluetooth, wireless
1. Go to: http://gd.panam.acer.com/home/
2. Click "Notebook" under "Select Product Family".
3. Click "Extensa" under "Select Product Line".
4. Scroll down & select "Extensa 5420" under "Select Product Model".
5. Click on the down arrow opposite to the component you want to download the drivers for.
Oct 29, 2009 | Acer Extensa 5420-5687 Notebook
Find wi-fi on/off switch
if it has WLAN which mostly llaptops have now adays look for Dish antenna like sign on the front panel of laptop it might be somehwere on function keys if u find it just pree it with the FN key it will turn on pls check in ur config on the box or beneath the laptop there should be written somewhere intel 2200 BG or 3945 bg or intel 4965 BG then it has wifi otherwise not there is no need ofr finding it but it should be there if u bought like after 2005
Feb 20, 2009 | Acer Extensa 5420-5687 Notebook
CAN'T USE BLUETOOTH
you need to install blue tooth drivers/application first. then you will able to use it.
Dec 01, 2008 | Acer Extensa 5420-5687 Notebook
Acer extensa 5420 help!
i need hilp fof my webcam
Jul 24, 2008 | Acer Extensa 4620 Notebook
Acer 5420 laptop on D Link DI524 Router
first of all, to check the wireless card on a friends network or a public hotspot, like starbucks. if that internet is slow, then most likely it is your wireless card that is on the fritz. otherwise, if it is fine on these networks there is a compatability issue with your router and your cards. make sure that if your router is very old, it is still compatible with a newer adapter.(e.g. n-wirelesscards maynot work with b-routers. and a-wireless cards will not work with b/g/n routers...or vise-versa.)
Jul 23, 2008 | Acer Extensa 4620 Notebook
Acer Extensa 5420-5687 Notebook Logo
338 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
