What does a dashboard light the symbol looks like a house, mean, on my 1996 Toyota Estima Lucida? Help please?
SOURCE: my toyota estima lucida
Well I would start with the small things and work my way up. Make sure your radiator is topped off with the manufacturers recommended fluid and ensure there are no torn hoses or leaks. Next you might try purchasing a new thermostat. They are inexpensive and easily changed.
SOURCE: hi i have a toyota estima lucida diesel and it chucks out smoke.
I have had the same problem and am fairly sure it is the glowplug not working (I haven't tested it yet). The cylinder with the dead glowplug keeps filling with fuel until it gets hot enough to start burning it, in which case it is very rich and therefore smoky. Once it runs for a while it burns the excess fuel off and runs fine. If it were any other cause the engine wouold not retain its normal power etc when hot. The lumpy running indicates that it is related to one or two cylinders only.
SOURCE: how easy is it to fit a prop shaft coupling on a Toyota
Undo front coupling first and slide shaft towards the rear of the vehicle. Just enough room then to slide the front coupling downwards may need to use hammer on old front coupling.
Replace front coupling. Replace rear coupling.
