I have a NEW laptop computer with Windows XP but without a printer port. I installed a parallel to usb device & driver so I could connect the scanner but my computer still does not recognize the scanner. IS there anything I can do to get it to work with the usb port?
Comments:
Feb 28, 2009
- The Canoscan N340P Scanner is ~8 years old. It does not have a USB Connection Port.
Feb 28, 2009
- The Canoscan N340P Scanner is ~8 years old and does not have a USB connection port.
There is going to be issues with connecting it in this fashion. The usb adapters are not addressed the same as a real parallel port. This means that the drivers probably do not have a chance at working. The other issue is usb ports on laptops rarely have the power to drive devices larger than a mouse or keyboard. This means that the usb adaptor may not have enough power to function. Try plugging it into a powered usb hub then to the laptop. This may give it enough power to do what you want if the drivers are compatible of course.
Good Luck.
If all else fails goto goodwill and get a usb scanner. I always see stacks of them. Most are the usb type.
Was this helpful?
Yes
No
Popular Solutions for Canon CanoScan N340P Flatbed
dear, When I start the install of the driver of the canscan n640P it display the follow message: The...
(More)
dear, When I start the install of the driver of the canscan n640P it display the follow message: The system file isn't aproprieted to MS-DOS and Windows. How I can resolve this problem?
