Question about Honda 3000 Watt Portable Generator
Honda 30is generator
I just had my honda 30is generator serviced and it is running a little rough when the eco trottle is on (or in the eco position). It sounds like it is starving for fuel. Is their any adjustments on the carby or anywhere else that may help or do you have any other suggestions? It was running fine before I got the service done. If I run it in the off position so it gets full power it runs better but you can still hesr it missing.
    New Friend:
Dear sir i have one honda 30is it not working when i on the key that showing E-03 what is the problem let me now
Posted on Jul 04, 2013
SOURCE: Battery in a honda 3000is
The battery is behind one of the end plastic casing pieces. You have to remove the center plastic panel, then remove the bolts holding the handle in place, and then remove the small, lower metal panel. I don't remember if it is on the side where the exhaust opening is or not, I believe it is on that same side.
Posted on May 06, 2009
  • 225 Answers
SOURCE: honda 5.5 generator gas is filling oil compartment when not in us
turn the fuel off when not in use,it is going through the carb.to the oil.
Posted on May 31, 2009
joecoolvette
  • 5660 Answers
SOURCE: my 13hp honda generator won't run.I have cleaned
You cleaned the fuel bowl? Was there any dirt, etc, in it? How does the fuel line look? How about the bottom of the fuel tank? How old is the fuel?
From your description, it 'sounds' like a fuel system problem. If it's a Honda EU3000is, it has Electronic Ignition, and electronic ignition usually just goes out all the way, not slowly.
The fuel line is small, and easily obstructed. Does fuel flow when the fuel line is removed from the carburetor? After the generator starts, runs, then dies, remove the float bowl. How much gas is present?
Observe the float. See if it's in good repair.
Check the float needle. See if the rubber (Neoprene) tip is squished, or is still in good shape.
Could be that when gas fills the float bowl, the float raises, then gets stuck in the up position, cutting off the gas flow.
Posted on Aug 31, 2009
Testimonial: "thank you very much for your help,most greatful.The Gen Set is at my farm and I will "attack' it this week and let you know how I go.thanks again."
  • 615 Answers
SOURCE: i have a honda em3500 watt generator that runs
it could be the connectors need to be changed, when you open the front of the gen you will see a shaft with wires attached to it in both sides a small charcoal like peaces attached with a small wires each these connectors see if the are touching the shaft or not and how long they are if they not or too short that mean you need to replace them and you can get them from any please by looking at the manual and get the number for them and do search on the net or local store...However did you first reset all your brakes? let me know if that work and please remember to rate my service so I am able to continue provide quality service and improve on it with your help. God bless
Posted on Sep 24, 2009
  • 274 Answers
SOURCE: Honda generator ei3000. Will run only a few mins
Tank filter not blocked? (Take tap off tank) Enough oil in motor? Try overfilling it slightly
Posted on Oct 23, 2009
I have a rough idle on my generator eu3000is and won't run my roof air on my RV
honda make good generators
a service should sort it out
motor part
generator has a govenor that can be adjusted
check carby idle .bad fuel . ,coil lead and plug
four stroke may need valve adjustment
generator part
check its voltage output and how much load you have on it when it has the rough idle
Sep 09, 2016 | Heating & Cooling
The generator will not hold the load.
Confirm that the ECO-Throttle Switch is in the off position. When in the ECO mode the unit goes into an idle condition and when detecting a load will spin up to operate the load.
In the off position the unit will remain in the ready for load speed taking the initial load with less hesitation.
If this does not solve the problem it is likely the carburetor has some old fuel residue. This residue restricts the fuel flowing through the carburetor. Suggest using a fuel additive carburetor cleaner added to fresh fuel and allow the unit to run under load for an extended period. These gas treatment products are readily available at any auto parts store.
These carburetors have no adjustment for fuel mix and after trying fresh fuel and cleaning the fuel system with additive the only remaining choice would be cleaning or replacing the carburetor.
Nov 21, 2015 | I Power In Box Honda Eu1000i Power...
Honda 3000is runs great on eco but hesitates and either stops the load source or stops running itself when under load.
Sounds like the throttle control motor is not adjusting the engine speed to compensate for the load. Does the generator rev up to full speed if you turn OFF eco with NO load?
Funny thing, I have one on my workbench that is doing pretty much the same thing. Runs on eco, revs up with eco off with no load, coughs, sputters and dies with a load in either mode. I will update with what I find when I figure it out in the next week or so. Have a new carb on order.
I swapped the carb and it made no difference. Still backfiring (rather dramatically) and won't stay running. I see on some other posts that Valve lash will cause this. It makes total sense as the exhaust valve gap actually tightens as the engine wears which would keep the exhaust valve slightly open when it ain't supposed to be allowing raw fuel to enter the muffler.
With this one I can believe it as it has a ton of hours on it and I know they have never been adjusted.
I will try to get a chance to do it over the weekend and update this post when I do.
Apr 01, 2015 | Honda EU3000iS Inverter Generator
EU6500 eco switch on won't idle down the engine
need more info did you leave gas in the tank without stabil if so carburator is got gas sludge in it
Feb 27, 2014 | Honda EU6500iS Inverter Generator
Have a Honda EU6500is generator with 410 hours. I live off grid and run the gen 2-3 hours daily. The generator rpm surges under load on eco throttle and surges under load AND without load when the eco is...
i have the same problem with a new one ,take a peace of paper and cover the battery cover air inlet when it's running ,if your problem stops-it's the seal around the cover,a honda rep let the cat out of the bag,---jk
Sep 08, 2011 | Honda Electrical Supplies
While driving truck wants to stall but continues to run, also service engine light comes on.
see if you can pull the codes for vehicle ,,but it sounds like a idle air control valve,iac,,,or sometimes trottle position sensor,,,most the time you can take iac off clean part and trottle body
Aug 30, 2010 | 1994 GMC Sierra
Problem with a ef1000 generator running rough. starts easy, gets to operation rev range, lasts for 5 to 20 sec, then runs rough, changed oil, air filter and plug cleaned carby, made little differance run...
I purchased a Propane Generator from Central Maine Diesel a few years ago.
20 HP Honda engine, Italian generator head.
Paid about $2300 plus shipping via Paradise Freight which was a few hundred.
I see the price is just a bit higher now... But the one I want most is Yuchai which i saw from a website.
Recently it blew a capacitor. Central Maine sent me 2 for the price of one even though it is out of warranty. $39 total for two.
I looked at generators on island but a similar Honda at Quality electric was close to $6000 and it wasn't even a 13750kw. More like 8 or 9000kw if I remember right.....
They have many generators at great prices but this is the one I settled for.
However, it is said that the Cummins generator is more popular than others.
Cummins Generator Cummins Generator Set Supplier and Manufacturer in China
Nov 12, 2017 | Yamaha EF2400iS Portable Generator
EU 3000is generator is running rough with Eco Throttle on
The air intake system on this unit is highly fine tuned. Make sure all covers including front battery cover, plenums, air intake system is properly installed and that any and all gaskets on doors and covers are not damaged.
Oct 01, 2009 | Honda 6370C - Parallel Power Kit For ...
Honda EU3000is Generator is running poorly.
Can anyone help me with the eco-trottle switch when I switch it on it seems to run the same idle whether I have it off or on, what could be causing it not to work, is it a bad switch or I am running 89 octane could that be the problem.
Thanks
Alex
Aug 17, 2009 | Honda 6370C - Parallel Power Kit For ...
Rough running engine, air intake seem to be involved. what should I be checking?
should your vehicle by any chance be a V6 then you should have the trottle positioning sensor checked as this is the commen cause for a rough engine
Jul 11, 2009 | 2003 Hyundai Santa Fe
Honda 3000 Watt  Portable Generator Logo
422 people viewed this question
Top Honda Electrical Supplies Experts
John Trevino
Are you a Honda Electrical Supply Expert? Answer questions, earn points and help others
