Question about Western Digital My Book World Edition 1TB Remote Access Storage System
I cannot map a Mybookworld External HDD
I have MBW attached to a router. I cannot access it via the network. I can ping it succesfully but I cannot map it either. On my laptop I can sometimes see it and then sometimes not.
Thanks
2 Suggested Answers
  • 92 Answers
SOURCE: After about 15 months of use with no problems, the
Try starting everything from scrtach again.. Check that the drive is fully working... Hope thius helps
Posted on Nov 17, 2009
Can you turn the product to a cellular router by connecting cellular modem stick via USB ?
No. There is no OS built into your router. The USB ports in router are usually included to attach a large external HDD and let you share that wirelessly and for upgrades to the firmware. Nothing else.
Nov 16, 2014 | Computers & Internet
Can both USB 3 and FW800 used at the same time with two computers?
The fast answer is no. This miniStack is not a network-attached storage (NAS) device.
However some of the newer Wi-Fi routers that also offer excellent network storage (NAS) features when coupled with an external hard drive.
Additionally depending on your operating system, you can have a local area network (LAN) with your main computer (hub), with the miniStack attached to it, and have the second computer access the HDD through an older (non-NAS) router. The second computer access would slower than the HUB.
Apr 23, 2014 | Newer Technology 3.0TB miniStack 7200RPM...
How to access my WD ebook locally to store information??
Try and map it, by right clicking on 'my computer' and select 'map network drive'. In the folder option type: \\**ip address**\public (where **ipa address** needs to be the ip address assigned by your router or one of the 2 default names: mybookworld or wdstorage. If you have previously changed to name of the NAS drive, use the name you assigned.
Jan 26, 2010 | Western Digital 500GB My Book World...
WD external drive is not opening usb
If by USP, you mean USB, then this is not possible. The drives USB ports are only for extra storage and not meant for communication to a PC. You can try connect the drive directly to the PC with a network cable and then map it as a network drive.
To do this, right click on my computer and select 'map network drive'. In the folder option type \\**name of the device**\public and then select 'finish'.
**name of the device**: If you have changed the name previously, you should use that name for it. Ig you have not changed the name, then the default names are either mybookworld, so \\mybookworld\public or 'wdstorage', so \\wdstorage\public.
If you have created your own shares and wish to map them, just replace the public share with the share you want.
The drive will appear in my computer and you can access your data.
Hope this helped!
Jan 10, 2010 | Western Digital 500GB My Book World...
Connecting WD Passport external HD with Belkin N+ router
I had this same issue. Found it to be a sequencing issue. Plug the USB into the router with the power off to the HDD. Power on the HDD and you should be able to get to it fine. Also make sure you have the latest firmware on the router.
Nov 27, 2009 | Computers & Internet
Storage Server Mapping Issue
Check that the DNS servers used by both the LAN & WLAN are the same.
Mar 25, 2009 | Computers & Internet
Freecom external network drive 500gm I installed today via wireless router and connection main pc and laptop and copied files over. Now does not work and will not see the external drive. Operating...
If it is a network drive. I believe it must have an IP address.
The best way to start troubleshotting is to know the ip address
Then you can ping the Ip address to know if your computer can see the drive.
If the ping time out...then the drive is not on the network.
If the ping reply then it is on the network. so you'll need to look at the share.
Rgds,
Mar 21, 2008 | Computers & Internet
ICMP blocked automatically
return, cut this configuration, but put route the her isp´s.
You can ping after this?
Can´t ping you has other problem.
Feb 18, 2008 | Computers & Internet
Western Digital My Book World Edition 1TB Remote Access Storage System Logo
694 people viewed this question
Top Western Digital Computers & Internet Experts
Arora Singh
Arora Singh
Alun Cox
Marcin
Are you a Western Digital Computer and Internet Expert? Answer questions, earn points and help others
