Question about Brother QL-1050 Printer
Brother QL-1050 not printing complete label
Bottom part of 4x6 label is printing - but the top part is not.???
It's "cutting off" the top inch or so...just a little blurry remant of what should be printing. Worked fine in the past.
yooperbud
  • 8637 Answers
SOURCE: I have a Brother QL-550
Normal 0 Normal 0 Driver could be corrupt.
Disconnect the printer or at least be sure it is turned off. I'd do both and reinstall the CD software program that came with the printer. When the software program asks you to connect the printer to the USB port, do so and it should again work properly.
Hope this helps. Bud
Posted on Jan 26, 2009
  • 7 Answers
SOURCE: QL 550 won't print
It has no ink as it is a thermal printer.   Make sure you are using genuine Brother Thermal Labels.
Posted on Mar 31, 2009
siawolf
  • 749 Answers
SOURCE: Lost my installation disk for my Brother Label Printer
the drivers and manuals are available here (free) at brothers' website. http://welcome.solutions.brother.com/bsc/public/us/us/en/dlf/download_top.html?reg=us&c=us&lang=en&prod=lpql500eus save them to a usb flashdrive or cd so you can put them on the next computer. make sure you choose the correct operating system so that you get the correct software.
Regards
Posted on Jun 30, 2010
Testimonial: "Thank you very much =)"
SOURCE: I have a P-touch QL-500
This solution from loquiter worked for me on my Vista PC
noavatar_s.gif loquiter
I am assuming that your hard disk is not actually full. I am guessing that you are running Windows 7. Click through your start menu until you can see the entry to launch your P-touch Editor. Right click on the entry and click "Properties". Click the "Compatibility" tab. Under "Privilege Level" check the box labeled "Run this program as an administrator". (You can do the same for all users of this computer by clicking the button immediately below, labeled "Change settings for all users".) Click OK, and you're done. The next time you launch the editor, you will get a message asking: "Do you want to allow the following program from an unknown publisher to make changes to this computer?" Click yes, and you should be able to edit and print your labels. Of course, all this assumes that you have sufficient privileges to actually edit permissions and run something as an administrator. Hope this helps. .g_thread_answer { overflow:visible !important; } Was this solution helpful?
Posted on Jun 30, 2011
P touch QL 560 wont work with new paper
brother touch ql 560 Questions & Answers - Fixya
www.fixya.com > Forum > Tags
Get free help, tips & support from top experts on brother touch ql 560 related issues. ...i just set up a new computer with the vista windows and i have a brothers ql-500 p touch the install disk will not work with the vista what can i do go ... QL 550 won't print I have a Brother PTouch QL550 that won't print anything on the label.
[PDF]Creating Labels - Top Edge Engineering
www.topedge.ro/info/USER-GUIDE/.../OL-500-560-650-1050.pdf
pe nd ix. Software User's Guide. QL-500. QL-650TD. QL-560. QL-1050/1050N ..... This manual describes how to create labels using the P-touch Editor software .... want to create a new label layout or open an existing label. .... When this check box is not checked, labels won't automatically be cut ..... Used to select the paper.
Oh Brother! - Compatible Brother Labels saving you money
www.ohbrother.co.uk/
Compatible with Brother P-touch QL-500, QL-550, QL-560, QL-570, QL-580N, ... Thermal Quality Grade A Paper with Strong Adhesive and Sharp Print. ... Oh Brother! you won't find Brother replacement labels any cheaper on the internet.
brother QL-560 - Oh Brother! - Compatible Brother Labels ...
www.ohbrother.co.uk/index.asp?search=QL-550
Feb 03, 2016 | Office Equipment & Supplies
Brother ql-570 - not enough disk space
I am using Windows XP and your solution above didnt work any other ideas
Mar 21, 2012 | Brother QL-570 Thermal Label Printer
When printing a label on brother QL-1050 printer comes up with error "Either BOF or EOF is true or the current record has been deleted Requested operation requires a current record" I have removed...
I solved this problem by pressing "Control N" to bring up a new label. Works fine that way.
This is the answer Brother gave when I called them:
Description of Problem 100000003722
When I click print I receive the error message: Either BOF or EOF is true, or the current record has been deleted.
Description of Solution 200000004488
This error message occurs when you print a label that has no record in the database table.
To avoid this error message, click on Database menu, select Create New Record.
Oct 09, 2010 | Brother QL-1050 Label Printer
Brother ql 570 processes the print and cuts the label. However the information I want to print is not printed on the label sheet. Why is this happening?
1. is it printer other information, such as text ,photos/images or barcodes?
2. What are you trying to print.
3. Make sure the Ink color is Black.
Dec 02, 2009 | Brother QL-570 Thermal Label Printer
QL 550 won't print
Mar 09, 2009 | Brother P-touch QL-550 Thermal Label...
Brother QL-1050 Printer Logo
James Cagle
James Cagle
Samyfam
Samyfam
Jim Keysor
