Question about E-Machines (308714) Motherboard
Emachine won't boot. when first turned on, get 2 beeps, floating error "Self check, check your PC and signal cable, monitor is working" on black screen, fan runs fast and loud. machine not connected to internet. just moved it to install wireless usb. have checked all other connections several times and they are ok.
    Scholar:
  • 172 Answers
I am an emachine specialist. These computer suffer with problem motherboards which often blow the power supply unit. Replacing the power supply on it's own does not solve the problem as the motherboard processor socket is the cause of the problem, the fault in turn blows the power supply. The same applies to all Advent and Medion computers sold via the high street stores.
Need help to repair, email me me at compdoctor2005@btinternet.com or ring me on 07926-106150
Chris
Posted on Apr 26, 2009
  • 15,935 Answers
Your video card has failed.
If it is on-board - the motherboard needs replacing, or you can add on a AGP or PCI video card and use that instead.
Thanks for using FixYa - a FixYa rating is appreciated!!
Posted on Feb 20, 2009
Power on but no display
Does it say no signal? Does is beep correctly during POST(power on self test)? Usually the remedy for this is checking your vga data cable if its connected properly and if it is, check the pins, are they all looking fine? If not change the cable and try again. If the cable is attached to your screen permanently, try a different screen.
Mar 20, 2014 | Computers & Internet
Cpu on but no video no beeps
There is likely a hardware-error.
1) Did you connect all powerconnectors correctly to the motherboard ?
2) Same question for attached internal hardware ?
3) Memory modules inserted correctly ?
If all OK, it's seems you PC is correctly booting and running succesfully an operting system like Windows.
Now, the error might occur something between monitor and PC.
4) Did you recently change the screensettings under Windows ?
If your monitor can run max. 1024x768-mode, but you accidentally fiddled with Windows-settings, to set it into 1200x900-mode, your monitor will turn black, not showing anything of Windows. In panic you might have turned of your computer. To solve this, it's best to push the F5-key when booting in Windows safe-mode. Here you can restore the older screen-setting.
5) No damage at pins of connectors between monitor and PC ?
6) Cable between monitor and PC connected correctly ?
If all OK :
7) Does monitor power on ?
Yes. Shortly but turns off within seconds (for TFT-monitors)
- Something at inverter-level is damaged. This is inside the monitor.
No. monitorLED is not even turning on
- Monitor has an internal defect
Oct 14, 2013 | Computers & Internet
My monitor samsung 2330 keeps saying check digital signal cable and I've put the cords all in the same way I had them before and now this screen keeps popping up
If you already check your connections and still no answer from what you're doing, do these steps:
  1. check for any beep codes
  2. remove and reinsert your RAM to another memory slot, if it works you have a problem with your RAM, you'll need to buy a new RAM that is compatible with your motherboard
  3. if you here a 1 short beep, that means it already start the booting sequence of your computer but you don't see any boot screen and still the out of range error. You have a defective graphic card.
  4. Is your monitor is a LCD type? if your answer is yes that means your monitor is not compatible with your old graphic card, buy a new graphic card that is compatible with your motherboard and to your LCD monitor. Because old graphic cards or onboard vga cannot hold much more pixels than newer ones that's why you have an out of range error
Aug 01, 2011 | Samsung Computers & Internet
"no signal" on monitor, my cpu fan is working fine but beep sound is not coming
Hi
Try this steps:-
1.Please check your power cables properly.
2.Remove the monitor cable from CPU and turn on the monitor and see are you getting the dispaly or not.
Oct 04, 2010 | Intel Motherboard
Installed the board, scren displays message no signal and stays black. no peeps or beeps. usb has power so do drives and signal leds
Check the cable between your monitor and computer. If this is a new install and you have added a graphics card, you will need to boot up once using the on-board VGA. Doing so will allow you to turn off the on-board VGA in the BIOS. Then you can shut down and move the monitor cable to the new graphics card and reboot.
Dec 05, 2009 | MSI G31M3-L V2 Motherboard
I am getting three short beeps while booting
The beep codes below may help you identify the possible computer problems. However,
they are only for reference purposes. The situations might differ from case to case.
gAMI BIOS Beep Codes
*Computer gives 1 short beep when system boots successfully.
*Except for beep code 8, these codes are always fatal.
1 beep Refresh failure
2 beeps Parity error
3 beeps Base 64K memory failure
4 beeps Timer not operational
5 beeps Processor error
6 beeps 8042 - gate A20 failure
7 beeps Processor exception interrupt error
8 beeps Display memory read/write failure
9 beeps ROM checksum error
10 beeps CMOS shutdown register read/write error
11 beeps Cache memory bad
g AWARD BIOS Beep Codes
1 short: System boots successfully
2 short: CMOS setting error
1 long 1 short: DRAM or M/B error
1 long 2 short: Monitor or display card error
1 long 3 short: Keyboard error
1 long 9 short: BIOS ROM error
Continuous long beeps: DRAM error
Continuous short beeps: Power error
Nov 03, 2009 | Gigabyte GA-7VKML Motherboard
Black screen after factory BIOS reset
Have u connected signal cable to the monitor? Is it ON?Try with different monitor
May 07, 2009 | ASUS A7N8X-E Deluxe NForce 2 Ultra 400...
My ECS 915 G-A elite group motherboard doesnot display anymore on the monitor..
have you tried to isolate what the cause of the problem? first check the video card if is properly inserted into the slot, and check the memory, and cable from CPU to monitor if it is connected properly. then boot your system. And try to observe this beep error code this might help you locate where the problem is.
short beep System is OK
2 short beeps POST Error - error code shown on screen No beep Power supply or system board problem Continuous beep Power supply, system board, or keyboard problem Repeating short beeps Power supply or system board problem
1 long, 1 short beep System board problem
1 long, 2 short beeps Display adapter problem (MDA, CGA)
1 long, 3 short beeps Display adapter problem (EGA)
3 long beeps 3270 keyboard card
thnk you.
Nov 29, 2008 | Computers & Internet
No video, monitor and video card are good
There 3 possible problem with your board...
1. Processor
2. Ram
3. Bios
Check one by one
Nov 25, 2008 | Soyo SY-KT333 DRAGON Ultra Motherboard
Emachine t3958/d845gvsr mobo
try resetting your bios.. reset it to system defaults.. check all connections properly.. pc to monitor..etc etc..
if you mean no error code by "no bios beeps" then it's okay..
if you mean even the regular single beep after post is not heard than chances are high that your video card has some problem.
Aug 20, 2008 | Intel D845GVSR Motherboard
E-Machines (308714) Motherboard Logo
835 people viewed this question
Top E-Machines Computers & Internet Experts
Brian Sullivan
Brian Sullivan
Matthew Spark
Matthew Spark
Are you an E-Machines Computer and Internet Expert? Answer questions, earn points and help others
