Question about Fuji FinePix S5000 Digital Camera
Blank Screen When I switch the camera on, the screen or veiw finder are totally white, no picture can be seen, if i depress the shutter, the camera focus's and it takes a picture but when viewed, picture is also white.
    President:
  • 1,223 Answers
Dear sorry to tell u but ur FUJI S5000 have a CCD HR failure which is due to the manufacturing fault in these CCD'd thats y fuji now adays stopped working on these CCD's and got tons of recalls for that it occurs after 4 to 5 years of use and this fault was present in all cameras manufactured between 2002-2005 , the ccd offcourse u can check with fuji try hard to get it replaced free of charge other wise consider buying a new one it is not that much expensive there new model as compared in those days it is around 250-300 $ a better version of this , pls vote me generously if u think i helped u
Posted on Feb 23, 2009
What causes the screen on my DSC H9 Sony camera to show white
Does the display in the veiw finder look like the screen? Do you mean it's blank/white?
Mar 13, 2014 | Sony Cyber-shot DSC-H9 Digital Camera
When trying to take pictures, looking through view finder or on back screen, it is blank. Am able to access menues and all though. Canon PowerShot S2 IS.
A stuck shutter is another common failure mode for digital cameras, but especially so for the S2 IS. The symptoms of a stuck or "sticky" shutter are very similar to CCD image sensor failure. The camera may take black pictures (for shutter stuck closed), or the pictures may be very bright and overexposed, sometimes with lines, especially when taken outdoors (for shutter stuck open). To confirm a stuck shutter, put the camera in any mode other than "Auto", and turn the flash OFF (you don't want to blind yourself for the next step). Next look down the lens and take a picture. You should see a tiny flicker in the center of the lens as the shutter opens and closes. If no movement is seen, then you likely have a stuck shutter. If so, please see this link for further info and a simple fix that may help.
Oct 11, 2010 | Canon PowerShot S2 IS Digital Camera
Camera will not show image on screeen or in veiw finder. Green status light is on.
A stuck shutter is another common failure mode for digital cameras. The symptoms of a stuck or "sticky" shutter are very similar to CCD image sensor failure. The camera may take black pictures (for shutter stuck closed), or the pictures may be very bright and overexposed, especially when taken outdoors (for shutter stuck open). To confirm a stuck shutter, put the camera in any mode other than "Auto", and turn the flash OFF (you don't want to blind yourself for the next step). Next look down the lens and take a picture. You should see a tiny flicker in the center of the lens as the shutter opens and closes. If no movement is seen, then you likely have a stuck shutter. If so, please see this link for further info and a simple fix that may help:
Feb 19, 2010 | Canon PowerShot S2 IS Digital Camera
FinePix F470 Lines on images and faded colors on photo mode.
You have over exposed pictures due to the shutter sticking.
The video is the clue to the problem. It doesn't use the shutter.
Shutter needs to be cleaned. This is no easy task im afraid
Sep 11, 2009 | Fuji FinePix F470 Digital Camera
View screen is white (blank) with internal cracks
Look fo the switch that has two setting. one of them will say LCD and the other Migt EVF if you have a view through your view finder this is your problem.
Jun 28, 2009 | Samsung L200 Digital Camera
My S2 IS all of a sudden cannot see anything out of either the lcd screen or view finder. I can see all of the settings on those but just a blank screen. Yes, my cap cover is off. Any thoughts?
To confirm a stuck shutter, put the camera in any mode other than "Auto", and turn the flash OFF (you don't want to blind yourself for the next step). Next look down the lens and take a picture. You should see a tiny flicker in the center of the lens as the shutter opens and closes. If no movement is seen, then you likely have a stuck shutter. If so, please see the following for further info and a simple fix that may help:
http://camerarepair.blogspot.com/2009/05/simple-fix-for-stuck-shutter.html
Jun 08, 2009 | Canon PowerShot S2 IS Digital Camera
Blank View Screen
Press DISP. button, and repeat untill the display shows up
Jun 02, 2009 | Canon PowerShot SD800 IS / IXUS 850 IS...
The viewing screen on the back is blank white.
Somkewhere after submitting the problem, I read a blog that instructed to press all five of the small buttons in the circle on the back while turning on the power. I took me twice and regained the viewfinder. They also had written that it may take a few times.
Mar 27, 2009 | Sony Cyber-shot DSC-W35 Digital Camera
No image in view finder
There is definately a problem with the camera. You will want to call Canon technical support and seek repairs.
Please mark as FixYa!
Aug 25, 2008 | Canon PowerShot A60 Digital Camera
SCREEN AND VIEW FINDER BLANK
Is the battery dead? Try taking it out and charging it, then put it back into the camera.
Also, you can try using another battery of the same type.
May 30, 2008 | Panasonic Lumix DMC-FZ50K Digital Camera
Fuji FinePix S5000 Digital Camera Logo
317 people viewed this question
Top Fuji Cameras Experts
Greg Cann
Greg Cann
Are you a Fuji Camera Expert? Answer questions, earn points and help others
