Question about Cub Cadet Street Sign- tractor lawn riding mower parts
A short in the pto wiring perhaps?
My cub cadet blows the fuse every time I engage the pto switch. It just started with no reason. Can you help me?
  • 15,935 Answers
Form what you are desribing you have a direct short, probaly in the wiring going to pto. I t has rubbed somewhere and is causing your short. Unplug the wires at connector close to your pto clutch and try it again and see if fuse stuill blows after you unhook it.
If the fuse still blows it is in the wiring going back up to thje switch. If the fuse does not blow after unhooking wiring connector the problem is in the clutch.
Thanks for using FixYa - a FixYa rating is appreciated!!
Posted on Feb 20, 2009
I'm considering buy a cub cadet off a guy.....a fuse blow every time the PTO lever is engaged on a 2003 cub cadet. hould i be concerned
if you are buying a used mower my advice is if you cant start it and mow with it don't buy it. it may just be a short in the switch but if the clutch is bad some of them cost $200.00 to $400.00 to buy. have him fix it before you buy it. or take a chance. good luck
Jul 30, 2017 | Cub Cadet Garden
LT1046 cub cadet blown clutch..what caused this with new Pto switchpto switch froze..replaced it still will not engage blades.what could blow the new clutch
Are you sure it's blown? Run two jumper wires from the battery or power side of the starter solenoid and energize the clutch. If it energizes and clicks, that's eliminated. Did you blow any fuses?
Jun 16, 2016 | Cub Cadet Garden
Keeps blowing fuse
There are several things that can cause the fuse to blow. PTO stands for Power Take Off and most likely this will not be the problem unless it blows the fuse when it is turned on. What you are saying is the fuse is blowing by just turning on the switch will be a short which can be anything from a pinched wire, shorted diode, short in the stator. bad voltage regulator.etc
Apr 17, 2014 | Cub Cadet Lawn Mower Electric PTO Clutch...
What does PTO stand for
power take off which drives the belt that runs the mower deck sounds like a dead short in the pto clutch maybe a wire shorting out check for bare wires
Cant get the switch to acctavate the mower deck on a cub cadet lawnmower
Check the fuse, tan/blue wire coming off ig switch or tan coming off PTO sw.
If it keeps blowing, check wire going to PTO unit for shorts or defective connection to PTO.
Apr 16, 2014 | Cub Cadet Garden
I have a cub cadet lt1554, when engage the pto the engine cuts off, fuse blows
near the engine where the wire goes to the clutch there is a plug unplug that connector and try the switch again if the fuse blows the problem is in the wiring if not the short is after the connector i have seen the wire going into the clutch rub on the clutch housing and i have been able to repair it
Jun 02, 2012 | Cub Cadet Garden
Pto blows the fuse everytime i engage it on my rzt 50 cub cadet mower.
Wire harness for the PTO on the RZT's is designed dangerously near the drive pulley. After time, the harness drops and comes in contact with the pulley which grinds through the coating and shorts out the circuit. Repair (tape up) the wiring, relocate the the wire to the opposite side of the crank pulley (may have to zip-tie in place) - shouldn't be a problem anymore.
Sep 25, 2010 | Cub Cadet Lawn Mower Electric PTO Clutch...
Cub Cadet 1861 amp light comes on when the PTO is engaged and after mowing for a short time the PTO disengages and now the 30 amp fuse blows and stops the engine
Sounds like you have a short circuit, either in the PTO clutch, or in the wiring that goes to it. Inspect the wiring for any obvious spots where insulation has rubbed off or burned. Also look at the wiring at the back of the PTO engagement switch for these signs. Before buying an expensive PTO clutch, unplug its connector. Drive around with the PTO switch on (even though the PTO won't activate and the blades won't be engaged). If the fuse doesn't blow, the problem must be within the PTO clutch. If the fuse still blows, it must be in the PTO switch or the wiring from there to the clutch. Use an ohmmeter to trace and find the short. Good luck!
Jul 09, 2010 | Oregon Scientific Electric PTO Clutch for...
Blown fuses when mowing
you have a wire that is shorting out somewhere, i would trace the wires from the clutch all the way back to the fuse including the relay and pto switch. You will more than likely find your problem in the control circuit between the fuse, pto switch and relay since this is what is fuse protected.
Aug 06, 2009 | Oregon Scientific Electric PTO Clutch for...
PTO clutch on 2007 Cub Cadet 1040 won't engage - wire damage.
mice seem to chew wiring insulation these days. its organic in some cases and must taste good!!!
Apr 19, 2017 | Oregon Scientific Electric PTO Clutch for...
Cub Cadet Street Sign- tractor lawn riding mower parts Logo
899 people viewed this question
Top Cub Cadet Garden Experts
Tim Whalen
DarkfireVA
Level 1 Expert
Matt Olenzek
Matt Olenzek
Are you a Cub Cadet Garden Expert? Answer questions, earn points and help others
