Question about Konica Minolta Office Equipment & Supplies
Will the fk-102 fax kit work on konica 7222?
Or is the fk103 the only one that works on 7222
  • Konica Minolta Expert
  • 158 Answers
The 102 will work but not all the features will work like with thefk103
Posted on Oct 19, 2009
SOURCE:
Konica 7020 how to enter the service mode
Which one the they have three mode 25, 36 and 47 depends on what you want to do.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
Oct 11, 2014 | Konica Minolta Fax Kit Fk-102 For 7022...
How to reset code 35-3 on photocopier konica 7020
DO THIS once because you are re-setting the FUSER it can catch on fire that will ruin a perfectly good day!!!!! Get a tech out to look at it.
Turn on the main and sub power switches.
Keep pressing the * button until the message
"Please enter service password." appears.
Input 9272 as the password and press the
[Start] key. (The password is fixed and cannot
be changed.)
[Mode Select Menu Screen]
Press 2 and 5 to select 25 mode. Then select soft switch. Set 3, then set 1 then change 1 to 0. to clear the code.
Jun 13, 2014 | Konica Minolta Konica 7020 W/fax Kit...
Help "Closing" Conveyance Door
Their is a switch letting it know that it is not closed.
find the switch and either adjust it so it closed the contacts ,when the
door is closed,. or temporarily jump it out to confirm that it is the switch. Sometimes switches can be shimmed up with tape etc.
Jun 03, 2014 | Konica Minolta Konica 7020 W/fax Kit...
Konica Minolta Bizhub 7222 scaner don't working N-37
Does it print?, Can you ping it. Scan to Email or PC? Or SMB/FTP? Check mail server. also try this site
Self Help Product Support Konica Minolta Business Solutions Inc
Feb 14, 2014 | Konica Minolta Office Equipment & Supplies
E-56-2 error code
remove the drum and clean the sensor that monitors the drum or you have a bad sensor and or board
Nov 30, 2013 | Konica Minolta Konica 7020 W/fax Kit...
C2801 bizhub 750
Sir/Mam,
There is a sensor that monitor the drum some times it gets cover with toner and can not do its job of monitoring the drum which it has to do before copying/printing Sometimes you may also get "please wait" same problem. Have to remove the drum assy. Two bolts and center bolt. Then pull out assy. BE CAREFUL DONT NIC THE DRUM!!!! Then you remove the drum and clean the sensor. (Two sensors the white covered one, clear one is for paper jams) When was the last time a 250,000 copy Preventive maintenance kit was installed? and Drum replaced at 500,000 developer also replaced at 250,000 copies/prints. every 250K PM kit install.
May 10, 2013 | Konica Minolta Konica 600/750 Mount Kit...
Cant find where to connect the phone line
what make and model copier? if there is no rj-14 jack(s) on the copier then it does not have the fax option installed. Many models have a fax button but do not come standard with the fax card. Usually an FK-502 or an FK-503 fax system.
Jan 28, 2013 | Konica Minolta Office Equipment & Supplies
Hi, We have a Bizhub 200 Model number FK-503 in our office. We are unable to find the user manual or guide. We would like to be able to delete a one-touch dial recipient and add a new one-touch dial...
Your machine is a Konica Minolta Bizhub 200. The FK-503 is just the designation for the Fax Kit. FK = Fax Kit, so just ignore that part.
You can download the user manuals here:
http://kmbs.konicaminolta.us/content/support/supportmanuals.html
Set Category to Office Systems
Model to Bizhub 200
then click on user guides, there are 12 available.
Good Luck and Thank You for using Fixya.
Jul 20, 2010 | Konica Minolta bizhub 200 Printer
Optional Fax Kit FK-503 Installation
yes there is a manual, but it required certified technician by konica to install this for you or authorized dealer.
Jun 10, 2009 | Konica Minolta bizhub 350 All-In-One Laser...
Konica 7022 Scan to Email Upgrade
I have never heard of a "kit" for scan to email. What I think they may be telling you is that you need to upgrade your Memory in the machine. The Memory that is standard in the machine may be limiting you to 10 pages, or the email service you are using is limiting the size of the file you are recieving. Are you using an inhouse mail server or an outside source like AOL, Gmail, Hotmail? Again, I have never heard of any "kit" for scanning at all. Hope this clears up some of the confusion
Feb 10, 2009 | Konica Minolta Office Equipment & Supplies
134 people viewed this question
Top Konica Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Adorjani Laszlo
George Mclaughlin
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
