Question about HP Pavilion s3020n (882780985063) PC Desktop
My HP pavilion wont start up.it will sometimes but for the most part it won't. it takes me to a screen to repair startup problems but never fixes the issue.
    Problem Solver:
  • 4 Answers
I too have had this problem. There is a limited Warranty on this exact issue. Visit this link to see if you are elligable: http://h10025.www1.hp.com/ewfrf/wc/document?lc=en&dlc=en&cc=us&lang=en&docname=c01514044&product=3376325&printable=no&encodeUrl=true&
Posted on Jul 17, 2009
    President:
  • 1,902 Answers
Check the power supply. You can do this by opening up the case and hitting the power button. If the fan on the back of the power supply and the fans internal in the unit all turn of then it is not a power supply issue and is a motherboard issue. This seems to be a power supply problem and will be around 100 dollars if you fix it yourself
Posted on Feb 20, 2009
HP Pavilion Entertainment PC issues. Laptop loads with 4 of the same screen. Won't startup so I can check the settings. Any help would be greatly appreciated!!
i think u have problem with the cable that connect motherboard to the screen ... go to closer computer and laptop-repairing office
Feb 17, 2013 | Computers & Internet
My hp pavilion g7 series laptop startup repair won't complete
I suggest you re-install Windows. If possible backup your before you install Windows.
Jan 28, 2013 | HP Pavilion Computers & Internet
Hp pavilion dv9000 takes a long time to get past the bios screen. It won't boot of dvd either??
Check BIOS boot options and assign local hard drive as first for faster boot. This is also where you set CD\DVD as first to boot from disc. Look for F Key press on start up. It will be shown on screen. These can vary.
Many HP machines also have a boot menu option during boot. Again an F key and may vary.
Sep 22, 2012 | HP Pavilion dv9000z Notebook
Windows 7 won't start
If you have a Windows Installation DVD at hand, you can do as below:Step 1. Insert the DVD into your detective computer and reboot; Windows Error RecoveryStep 2. Set language, time and keyboard;Step 3. Click "Repair your computer";Step 4. If you have more than one systems on your computer, choose the one you want to repair;Step 5. Click "Startup Repair" to start restoring your Windows;Step 6. After startup repair is done, you need to take out the DVD and reboot the PC.
More info, visit:windows won't start
Sep 04, 2012 | HP Pavilion p7-1030 Desktop PC Black
Hp pavilion slimline s3600t desktop pc - Wont boot up, flashes to blue screen after hp blue screen and restarts. no option for safe mode either
A Blue Screen is more time than not indicative of a driver issue or some hardware issue. First of all when it boots to the screen that shows Safe Mode and the other options, scroll down and see if there is an option to Stop or Disable Automatic Restart on Boot. This will stop the screen from restarting itself when the blue screen appears and give you a chance to read and see what the error is. Afterwards it is ok to run Startup Repair. Startup Repair does not delete any of your personal files. Let startup repair run and then see if it boots. Once again, startup repair does not delete any of your music, documents, pictures, videos or programs. System Restore does not delete any of you documents, music, pictures, videos or programs. System Recovery WILL DELETE all of your music, pictures, videos, documents & any programs you've added since you brought the computer home from the store. System Recovery sets your computer back to the very first time you turned it on after you purchased it. I would run the startup repair, if that does not fix your problem, see if you can run a System Restore. A lot of time the Restore Points are damaged or missing when this happens, but give it a try and restore to a point before you started having the blue screen issue. If all fails you're going to need a system disc so that you can get into the Recovery Console so that you can enter a dos command in the little black box that opens up with white letters. You want to type: chkdsk /r
Let it run. It will run well over an hour and you will notice the percentage of completion going from high to low, but that's ok. Let it run to completion then try rebooting. If this doesn't work, you're going to need to take it to a repair shop or reload the operating system yourself.
Mar 19, 2012 | HP Pavilion Slimline s3600t Desktop PC
When i am start my hp pavilion this shows Bootmgr is missing alt+cntr+del to restart again it same cycle
1. Error: BOOTMGR is missing:
The following error opens when attempting to start the PC:
??¢ If you recently installed an additional hard drive, turn off the computer and remove the drive before using the following steps:
??¢ Open HP System Recovery:
??¢ CAUTION: Do not perform a system recovery! Stop at the first recovery screen.
- Press the F11 key repeatedly while the computer is starting.
- If you have a recovery disc, turn on the PC and insert the first recovery disc into the drive. Use the disc to enter the system recovery.
??¢ Select Microsoft Startup Repair tool and wait for repair to find and fix errors. When finished, restart the computer; even if the startup repair tool finds errors but cannot fix them.
??¢ If the error message persists, open the recovery manager screen as was done in step 1.
??¢ At the recovery manager screen, press ALT + D.
??¢ Enter the following text at the command prompt: bootrec /rebuildbcd
??¢ If bootrec displays "Add installation to boot list?", press y .
??¢ After bootrec completes successfully, the computer displays "The operation completed successfully".
??¢ To close the command prompt, enter the following text: exit
??¢ At the Recovery Manager screen, select Microsoft Startup Repair tool (again) and wait for startup repair to find and fix errors. When finished, restart the computer.
??¢ The error should no longer open. If it does, perform a system recovery, making sure to backup important files.
??¢ If you removed a hard drive before using these steps, replace the drive. If the error occurs again, make sure the additional hard drive is not set as an active drive. Only the main bootable drive should be set as active.
Dec 12, 2010 | HP Pavilion Ze4900 Notebook
Hello, I have an HP Pavilion dv2000 laptop. The problem is the laptop keeps freezing on startup.When I first turn it on I get a screen that says "Windows failed to start" and gives me two options: Launch...
It is also important to remove the suspicious applications and programs in the computer to avoid Windows freezing. In this type of infection not only your Windows registry gets corrupted and needs massive repair but also there is virus based penetration in the Windows set up. In this situation it is recommended to conduct a virus scan as well.However, if your Windows freezes up, the best solution is to repair the computer registry.use registry cleaner reginout
Sep 22, 2010 | HP Pavilion dv2000t Notebook
The pc is running but nothing but black screen,,sometimes will come on briefly and go black again
Try to go to the bios screen and check if it does the same . You can go to bios by tapping f10 during startup. If it happens the same its the hinge problem i.e. the connection between the screen and the bottom of the nb. I think you might have to take the nb in for repair.
Apr 25, 2010 | HP Pavilion ZT3000 Notebook
HP 9700 17" Wont Startu up
The startup files on the hard drive appear to be corrupted. You will need to reinstall the OS to fix the corrupted files. Also, test the hard drive, it might be starting to fail.
Feb 11, 2010 | HP Pavilion dv9000z Notebook
HP Pavilion Slow boot up
Well, that's absolutely abnormal. Generally the problem can be caused by many many reasons such as outdated hardware, overload startup programs, corrupt registry issues, too many junks, virus attack, poor security software taking too much system resources, remnants of uninstalled applications etc. The fact is, you should keep some system maintenance job regularly. If you don't want to do these manually, try the hp speed up tool http://www.speeduphp.com/ to give a free & full scan of your slow HP PC to find & fix all possible issues. Regards!
Oct 18, 2007 | HP Pavilion dv4000 Notebook
HP Pavilion s3020n (882780985063) PC Desktop Logo
142 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
