Question about Dell Latitude D600 Notebook
My dell d600 wont come on even when i put the charger on
  • 3,940 Answers
If the system shows no power indication when trying to power on or if you get only a momentary flash of the Power LED, then it goes off, the first point to check is the AC Adapter. If possible, try a known good adapter from another D-Series Dell. Check the LED on the AC adapter to see if it is ON before connecting it to the system. If it is and it goes out when you plug it to the system.
If the LED goes out and no other adapter is available, then I'd start with a new AC Adapter. (If you have no known good adapter available, you might try taking it to best buy and see if they can connect the system to a known good there to see if it powers on).
If replacing the AC Adapter does not resolve your issue, the motherboard is the next component to replace.
Posted on Feb 20, 2009
My charger port on my dell latitude d600 is broken. I'm trying to get some information on what i should do.
Ah yes the charger port, It can be repaired but it is a very tricky job. I would reccomend that you take your laptop to a computer technician. If it is done incorrectly or even a failed attempt will render your laptop unoperable and therefore useless.
Contact an experienced laptop computer technician, one that is willing to do the job for you!
Take care!
damnor01
May 31, 2011 | Dell Latitude D600 Notebook
Hi,i have a Dell Latitude D600 with cant boot with the charger. I can turn on the laptop using charger but it wont boot. It juz powered on like 2secs n gone off. But if i use battery to boot,then is...
That could either be a problem with the AC adapter or the motherboard.
You can try updating the firmaware of you motherboard first. Go to this link: http://support.dell.com/support/downloads/driverslist.aspx?c=us&cs=19&l=en&s=dhs&ServiceTag=&SystemID=LAT_PNT_PM_D600&os=WW1&osl=en&catid=&impid=
download the BIOS firmware, save it on the desktop then run it. Your computer will reboot while the BIOS is being updated, if you'll have the same problem after that, call Dell to get a replacement for your AC adapter or motherboard.
Dec 31, 2010 | Dell Latitude D600 (D6005C) PC Notebook
My dell inspiron600m does not even come on at
It sounds like the power adapter/charger has gone bad. If the adapter/charger is bad, then 2 things will happen.
1. The battery will not be charged.
2. the system will not be operable from the adapter.
If your adapter is not able to charge the battery or operate the device, then the battery is likely dead, which means youd have no power from the battery, and youd have no power from the adapter, and no power from the battery or adapter means it wont come on. I suggest taking that machine to a shop and having the adapter checked, as well as trying a new adapter.
Dec 13, 2009 | Dell Latitude D600 Notebook
My dell d600 been shorted after using defective charger
try connecting a known good ac adapter if fails then remove battery then try it again if still fails then replace the motherboard.
Oct 14, 2009 | Dell Latitude D600 Notebook
Dell d600
It could be your charger, if you have say a dell laptop, get a dell charger for it, it should fix the problem and it will reduce any damage done to your laptop and/or the charger, saves you money in the long run to. and if you want more technical assistance contact http://tinyurl.com/msfzw7
Jun 20, 2009 | Dell Latitude D600 Notebook
I have the same exact problem with me dell laptop
DID YOU CHECK THE CHARGER? KINDLY CHECK FIRTS THE CHARGER WORKING OR NOT! THEN IF IT IS WORKING MOVE TO DC JACK CONNECTOR OF YOUR LAPTOP... OR REMOVE FIRTS THEN BATTER FACT THEN CONNECT THE CHARGER THEN PUSH THE POWER BUTTON IF WORKING OR NOT
Jun 04, 2009 | Dell Latitude D600 Notebook
My dell latitude d600 onboard bluethoot just doesn't work, don't even know how to start it up.
go to control panel, classic view, bluetooth. self explanitary from there, unless ur dell is like mine and doesnt have the hardware installed!! so youve just got a light that wont do anything
Jun 01, 2009 | Dell Latitude D600 Notebook
I'm using a universal battery charger and my
did you have a look at the sticker under laptop to see what voltage it was then set the charger to this,, if to setting is to low it will do this but if to high it could damage the laptop ,, you will find that it set to low or the other problem is most dells wont run via uni chargers unless the charger states it because dell like to use there own parts made by them unlike other makes
Apr 04, 2009 | Dell Latitude D600 Notebook
Same issue
Well i think that there is a problem on the motherboard.
Oct 29, 2008 | Dell Latitude D600 Notebook
Wont turn on
Maybe that is why Dell makes an external battery charger.
It may be the ac power adapter (BRICK) is not putting out the required voltage/amps.
Apr 05, 2008 | Dell Latitude D600 Notebook
Dell Latitude D600 Notebook Logo
136 people viewed this question
Alun Cox
