Question about Frigidaire ATF6000ES Front Load Washer
Mold build up around rubber in washer drum. Can
Mold build up around rubber in washer drum. Can not even scrub off with bleach .
    New Friend:
    Problem Solver:
  • 12 Answers
I had this disgusting problem and learned from a chemist on line:
1) Use HE detergent.
2) Use a TINY amount of detergent.
I use about a tablespoon = 2 short pumps on the Tide dispenser. It is sufficient to totally clean the clothes without feeding the black mold. You will be surprised. The chemist described how a tiny amount does all that is necessary to rearrange the molecules to make dirt magnets. The detergent manufacturers encourage overuse. All the excess detergent just pollutes freshwater after having served no purpose.
3) Leave the door slightly ajar at all times for air circulation. I used the plastic cup lid from the liquid detergent as a prop.
4) I cleaned with citric acid (Glisten for dishwasher cleaning) and though it is still somewhat stained, there is no active growth.
5) With the above precautions, I do not have to be constantly cleaning the gasket.
Posted on Aug 05, 2015
  • 370 Answers
Buy affresh washer cleaner. You can order it over the internet and this should take the mold off and then if you use this regularly like the package explains it will keep the washer from molding. I use this stuff on all the front loaders that come into my shop. This stuff works great.
Posted on Feb 20, 2009
I have the Bosch Next 500 series and I hate it. I am trying to clean off the mold growing on the 'roof' of the detergent basket. I am using a dental tool and q tips but I can't reach some of it.
Hello. Welcome to a "nature of the beast" situation with cleaning your washer. These washers are a lot more user intensive than the older ones. I'm a tech and tell all my customers to build a CLEANING KIT consisting of the following:
2-gallon bucket
2 old toothbrushes
1 kitchen or bathroom scrub brush(on the medium/small side)
3 old wash cloths
3 pairs of comfortable rubber(Playtex) gloves
1 gallon of household bleach
Procedure: Put on gloves(always)
MIX 1 cup bleach to 1 gallon of warm/hot water
Clean the dispenser areas with the toothbrushes dipped in the water/bleach solution(be careful to *not* get bleach on any metal surfaces, use the scrub brush also. Try to flush the areas with clean water or wipe/flush with a wash cloth and clean water.
Dunk a wash cloth or 2 in the water/bleach solution, squeeze out enough water so that the cloth is very wet but *not* dripping, carefully place the cloths in the fold of the bellow and wipe around and around, repeating the dunking and squeezing as often as needed. DON'T BE ROUGH, DO NOT USE DENTAL TOOLS ANYWHERE NEAR THE BELLOW--if you puncture it, it will leak and have to be replaced. You can use a toothbrush or scrub brush as long as you are gentle with the scrubbing. Take your time and try to remove as much of the mold as possible.
Run a washer cleaner through the unit at least once per month. For heavy mold build-up you will have to use several boxes of cleaner once a week for 3 weeks. After each cleaning cycle(no spin needed), run the washer on HOT WATER, heavy duty, bulky, etc WITH NOTHING IN IT), then, for run #3, only wash whites--this will ensure that anything with cleaner in it has been flushed out the washer. I hope I helped you!
Sep 03, 2015 | Bosch Washing Machines
I have a huge problem with my wash mach of mold build up on the rubber and smelly clothing as a result
If You Can't Remove The Rubber To Clean It. Get Bleach, Simple Green Or Ajax. Get A Paint Brush, Dip It Into Any Of The Cleaning Agents And Brush It On The Rubber. If You Don't Have A Paint Brush Use And Old Toothbrush. Now Start Scrubbing The Mold Of. Use Warm Water :o)
Sep 18, 2011 | Maytag Neptune MAH5500B Front Load Washer
Moldy door gasket, smelly clothes
Mold growth is a common problem due to tight seals and poor drainage.
Pull back the rubber or plastic around the tub or basin to reveal the problem. You should also check your detergent dispenser as this is another common area for mold growth. Remove any visible mold. You can use a solution of water and dish detergent or bleach (1 part bleach to 10 parts water). You could also use bleach wipes to do this depending on how stubborn the mold is.
Because of the set-up of the washer, mold can also tend to grow in pipes, traps, and outside the drum where you can't see it.
You can run an empty load on the hottest water setting with 1 cup or more of bleach. Run an empty load on the hottest water setting with 1 cup or more of vinegar. Use a product designed to attack build-up from detergents and fabric softeners. Call a repair man to service the parts of the machine you can't see or attempt to do it yourself
However Mold needs moisture to grow. Leave your washer door and detergent dispenser cover open in between loads to allow for complete drying. This will dramatically decrease or eliminate the problem.
2. clean the machine monthly to stay away from the problem.
3. Switch to powder and/or low-sudsing detergent.
Let us know if you need further clarification else please accept the solution.
Thanks for contacting
Mar 21, 2010 | LG Washing Machines
Build up of mold/mildew on rubber gasket. Makes
you need to purchase a package of 3 tablets called AFRESH at your local appliance parts store and follow the directions on the package. also, leaving the door open a bit after each wash will help.
Oct 24, 2009 | Frigidaire Affinity ATF7000E Front Load...
Mold Mold Mold
You are speaking the truth there , the really sad part is all brand front load washers will have mold/mildew build up due to the rubber boot seals they all use , the only way of fixing this is soaking and scrubbing with bleach which is not a fun job to do.
until they can figure out how to get all the water out after use we will have to deal with mildew.
top load washers use gravity to drain most water out so they dont have this problem.
Jun 11, 2009 | Bosch Nexxt Premium WFMC6400UC Front Load...
Mold build up around ribber gasket . Heavy, black and hard
Front load washers are notorious for developing mold/mildew to build up because they retain a lot of moisture in the round gasket the door closes into. Wash it down with a 50:50 soulution of bleach and water. You may have to use a brush on the "hard" stuff. Occasionally, run a quick load with no clothes and just bleach through a complete cycle in the washer. After a heavy day's washinh, leave the door open a little to help dry it ou.
May 28, 2009 | Washing Machines
Black mold on washer door seal
this is a very common problem with the neptune washers.
use a javex and hot water solution and scrub the rubber boot.
you should also do an acid wash. (hot wash with bleach, and no clothes) if there is mold on the boot it is inside the washer as well.
There is a way to prevent this. when the washer is not in use, hang a small towl on the washer door, and do not close the door.
this will allow for air movement in the washer
May 27, 2009 | Maytag MAH6700AWW Neptune Front-Load...
There is mold on the rubber gasket of my Maytag front load washer. How can I remove it?
Try a Magic Eraser first. That usually works. If not, use straight bleach and a white cotton rag to clean it off. You may even need to scrub it with an old toothbrush if the mold is thick.
May 12, 2009 | Washing Machines
Mold issue on front gasket
A solution of bleach and water will do. Just wet the rag and rub it down well. When this is done you may still have the marks but the mold is dead. If you want it to be completely clean you may need to
Jan 08, 2009 | Frigidaire Affinity ATF7000E Front Load...
Black mold growing on rubber gasket and under rubber gasket in Whirlpool Duet front loading Washer
The solution? Plain old bleach.
Scrub rubber seal on door. Run the bleach through the machine once a month to keep clean.
Keep door open after each wash to ensure that it dries out properly.
Oct 12, 2008 | Whirlpool Washing Machines
Frigidaire ATF6000ES Front Load Washer Logo
312 people viewed this question
Top Frigidaire Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
