Question about Vacuums
Vax IPX4. Not sucking from carpet. Plastic
Vax IPX4. Not sucking from carpet. Plastic sealing clip broken. This is one of a pair that click shut to fasten dirty water container and keep it airtight
  • royzee May 11, 2010
    Sorry, what is the question?
ukvacfan
  • 328 Answers
SOURCE: Operating instructions for Vax wet cleaner
What is an IPX4 by Vax?
Posted on Dec 29, 2007
reddevil6
  • 1673 Answers
SOURCE: Hoover steamvan cleaner F5807
If this has a duct part #38661003 (#3) that is supposed to be installed in front of the tank isn't there, then you will have no suction to pick up the dirty water.
If this doesn't use a duct, then either the foam filter (#2) is up all of the way, need to leave 1/4 in. gap from the top, or the rear of the tank lid is not locked down.
Posted on Jan 22, 2008
SOURCE: hoover will not suck carpet shampooer
no solution, hoover is by far the most rediculous machinery... it says its as easy as filling it up and using it as a vacuum.. but it doesnt show how the hell you fill it up, there are two possible places where water and solution obviously enters and leaves... yet niether of them open up for fluids to be put in
and of course the instructions dont tell you how to fill it up
no wonder it has only a 30 day money back "guarentee"
because it takes 30 days for the buyer to realize that it doesnt work
so you can spend 300 on this faulty product.. or spend 300 on something that wont infieriate you
have fun
Posted on Jul 24, 2008
farr64
  • 121 Answers
SOURCE: Cleaner not sucking up dirty water.
try stripping it down and cleaning all parts and filters .some cleaners use a safety 'ball' to stop water getting on the motor is this stuck it should slide up and down a small track in a tube..good luck hope this helps farr64.
Posted on Apr 29, 2009
SOURCE: water lesking from vax rapide carpet washer
i have been using a vax v26 carpet cleaner and the washing water is leaking from the bottom then the solution will not come out has the pump given up?
Posted on Jun 14, 2009
Rapide XL. Why isn't it sucking up the dirty water?
you need to set it lower for water
Aug 10, 2015 | Vax Vacuums
Vax carpet shampooer water tank leeking
If tank itself is leaking nothing you can do but replace it. Check it for cracks or leaks at sink. Make sure the round rubber seal it sets on is ok an not bent over or broken, also check the leaver to make sure it is not hing up an is working properly.
Jan 29, 2015 | Vax Vacuums
Vax vrs5w will not suck up dirty warter
sounds like the filter is clogged.
Who makes this dirt sucker?
Aug 19, 2014 | Vacuums
Vax carpet washer deluxe leaks from bottom of water tank, somewhere between coming out of the tank and going into the jet to squirt on the floor. pissing me off - any help would be great!
This is a common problem known by repairers. What happens is residue gets stuck in the seals. The next time you use the machine and press the trigger the seals stay open and water leaks continually. It was suggested that maybe after you finish using the machine you do a whole tank of plain water to rinse it out but I haven't had any luck with that. I am stuck with a machine that doesn't work.
May 06, 2010 | Vacuums
How do you use vax 2000 to shampoo carpets. do not have a manual
Set up is complicated unless you are patient.
Remove the paper dust bag from the bottom of the canister and then filter ring. Then put in the recovery bucket of which 4 litres of warm water should be added and a capful of floor cleaning solution.
Then remove the pump wire on top of the Vax motor where the blue filter circle is (keep the filter in, do not remove it!).
If the 2000 has a separate pump notch on the rim of the Vax motor head on the outside then you should plug the black cord in that has a washer screw type metal connector. Push, twist and lock in. Then the black cord which eventually leads to a clear pipe with the older clip on wash handle that has to be clipped to the main hose handle has to have the black and see through cord clipped to the main hose and eventually down the extension pipes until you get to the floor head. If you have the older style T shaped floor head the cord should slip into the floor head easily. Then either squeezing the trigger to release the cleaning solution in, switch the Vax on and hit the secondary pump button. This will pump the cleaning solution and water into the carpet. To stop the pump you can either lock the wash trigger to stop the liquid or squeeze the trigger to make sure no other liquid comes out. Generally you can see the foamy carpet solution flowing through the see through rubber hose and eventuallly through the floor head.
To **** up the rest of the carpet solution, stop the pump button and the Vax can be used to **** out all the dirty solution/water in the carpet. Its a big and tedious task generally!
See an alternative manual for the Vax 1000 which is an older model but similar to the 2000. It is free and in pdf downloadable form:
http://www.vax.co.uk/downloads/pdf/VaxGuideNo8a.pdf
Jun 15, 2009 | VAX Appliances 2000 Canister Vacuum
Vax carpet shampooer wont release shampoo
if you unscrew a bit on the base that allows you to take off the brush, you will see a black plastic strip with very small holes in it. These are where your shampoo comes out of. Take a needle and re-pierce these holes and it should work again. I have just sorted mine out. good luck .
Jun 01, 2008 | VAX Appliances Vacuums
Vacuums Logo
123 people viewed this question
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
