hi, there is a common fault on this model, to do with a bga chip (ball grid array) just underneath the touchpad. try appling a small a mount of pressure with 2 fingers just above the touchpad on the plastic between the keyboard and touchpad while it is booting . if you get any further response from the laptop then this is your problem. i have this model and same problem occurred i took the unit apart and placed a rubber wedge ontop of the intel BGA chip. put it back together and with the pressure applied from screwing the case back together hey presto works fine. hope this helps.
by the way please dont attempt to open the laptop unless you are confident you can put it back together :-)
Comments:
Feb 21, 2009
- you ranked this as not helpful . like i said i would bet my house this is the problem. at least thanks for trying would have been more courteous you will find a better response to your problems if you are more polite. as i am unhelpful i wont be offering any more advice for your problem.
Thanks a lot to the guy with Solution 1. Amazing! I just pressed the frame above the touchpad and it run like breeze :) I could have been pondering for 3 years without ever such a thing cross my mind!
This worked for me after trying several other things. Thanks so much.
Comments:
Oct 19, 2009
- This has worked fine for me for several months, however now at times my USB ports just stop working. I use an ext USB mouse. Sometimes after being on for awhile it will just stop working. The touch pad does still work. Any ideas?
Hi I have an Acer Aspire 5810 timeline, running on windows 7 and office 2007. I can't get the...
(More)
Hi I have an Acer Aspire 5810 timeline, running on windows 7 and office 2007. I can't get the internal microphone working or even find it!! Nor can I find a user guide anywhere on internet - can anyone help? Thanks
my time 8375 laptop keeps freezing when playing games can i upgrade graphics card on this or is ram...
(More)
my time 8375 laptop keeps freezing when playing games can i upgrade graphics card on this or is ram sufficent at 512 advise please thanks
problem solved but every time when we restart it it show it again...... any permenant solution so...
(More)
problem solved but every time when we restart it it show it again...... any permenant solution so that we can get usb functionality also..... sanjeev sanjeev@ritecomputers.com 9896114731
