I've written up a detailed step-by-step tutorial on how to remove the front bumper of a 2004-2010 Toyota Sienna: John Fixes Stuff How to Remove the Front Bumper on 2004 2010 Toyota Sienna
SOURCE: Remove rear plastic bumper cover
please email me at [email protected] with any other info or questions if you have already gone to a body shop
SOURCE: Toyota Sienna bumper dent
These vans have a styrofoam bumper wrapped in semi-rigid plastic. When you dented the bumper you probably dented the styrofoam as well, so depending on how deep the dent is you may not be able to bring it back to normal.
The surest way to fix the dent would be to remove the bumper by unbolting it, then taking out the styrofoam and pushing out the dent.
SOURCE: Replacing RH Side view mirror on a 2006 Toyota Sienna
On the inside trim, you can remove screws that are by the door handle, arm rest, under door and side of door and then gently pull back on the panel as there will also be retaining clips attached and you don't want to break them. You'll need to lift the door panel upwards in order to get it off the window ledge. Then you'll need to manipulate the panel and disconnect the door handle linkage from the door handle and disconnect the wiring for your controls. Then you can access the bolts that secure the mirror onto the door
SOURCE: 2006 Toyota Sienna Battery Drain. Side power
the sliding door is probablly draining the battery,, have door checked.. make sure tracks are clean and hinges are not binding
SOURCE: what is the towing capacity of a toyota sienna?
2006 Sienna Standard towing specs:
2WD or 4WD: Max Tongue Weight: 200 lbs
Max trailer and cargo weight: 2,000 lbs;
(over 1,000 lbs requires trailer brakes)
Max trailer and cargo weight: 3,500 lbs WITH the factory tow package
Thanks for using FixYa!
