Question about Riccar Sewing Machines
Riccar sewing machine.e6 in pattern display
Riccar sewing machine. model computer 5800 showing E6 in the pattern display and will not stich. can you help please?
SOURCE: Brother Sewing Machine CS-100
My niece has this machine, was recently helping her sew with it -- I go the E6 code also - I believe it is the button lever is down - it is the white/beige 'flag' arm beside the presser foot - it needs to be raised back up to the case housing to clear the error - it means you do not have the proper stitches for the foot. Good Luck.
Posted on Jul 28, 2008
dizzythevamp
  • 9 Answers
actually e2 is the button hole lever being down. e6 means that the thread is tangled and to prevent the motor from overheating the machine automatically stops. All you have to do is re-thread the machine and take the bobbin out, untangle it and put it back in and sew. This usually works. If it keeps happening, there could be a few things wrong.
1. if you are using thick fabric your tension should be lower. normal tension is 5.
2. your machine is out of alignment. take it in to a service center, they can fix it in 5 minutes. to find a service center near you go to http://www.brother-usa.com/service/
3. your needle is old or bent and should be replaced.
4. Your needle is too thick, standard is 80. The thicker the fabric, the thicker the needle.
Posted on Jan 06, 2009
dizzythevamp
  • 9 Answers
SOURCE: E6 and F5 error message
Are you using the right size needle? Try using an 80. Also try taking it to a service center. To find one near you go here: http://www.brother-usa.com/service/
SOURCE: I get an E6 message while trying to sew on my Brother cs-6000
Here is the online manual for your machine. http://www.brother-usa.com/ModelDocuments/Consumer/Users%20Manual/UM_CS_6000_ES_2000_EN_185.PDF
Posted on Mar 30, 2009
Zenqi
  • 208 Answers
SOURCE: brother sewing machine screen displays E6
E6 is an error code. You didn't state the model number, but if you look in your instruction manual, it will list the error codes. If you don't have a manual, go to Brother.com and you can get the answer.
Posted on Oct 01, 2009
My brother cs-6000i computer sewing machine shows a E6. I cleaned around the bobbin and checked the needle. I replaced the bent needle and it still does the same thing "E6". What will fix this?
Follow the instructions below if you receive the error message "E6"
1. Check if the machine rattles and stops as soon as the sewing starts
- Upper thread could be tangled or threaded incorrectly
- Check that the thread take-up lever is threaded
- Raise the presser foot to raise the needle to its highest position and re-thread the machine
2. Remove the bobbin and bobbin case
- Clean any lint or loose threads
- Install the bobbin case so that the projection on it aligns with the spring and install the bobbin into the bobbin case
3. The needle could be bent
- Check that the needle does not hit the needle plate
- Replace the needle if necessary
- Make sure the flat side is facing the back
If the problem persists, your machine may require service.
If the machine is in warranty, call Brother Customer Service at 1-877-Brother (1-877-276-8437) for warranty options.
If the machine is out of warranty, contact a Brother Authorized Service Center for repair by clicking on the link below:
http://www.brother-usa.com/service/default.aspx
https://help.brother-usa.com/app/answers/detail/a_id/54048/~/error-message-e6
Feb 02, 2018 | Brother Sewing Machines
Brother sewing machine nx250 error message E6
Search for:
Make Model error E6
https://www.google.com/search?q=Brother+sewing+machine+error+E6&ie=utf-8&oe=utf-8
Aug 25, 2017 | Brother Sewing Machines
Error message e6. Needle won't move
Check your owner's manual - troubleshooting section. Sometimes it will show the error codes. Otherwise, search the internet for:
Make + Model + "error code E6"
You can also check with the manufacturer.
Nov 09, 2016 | Sewing Machines
Showing E6
You receive the error message E6 when the motor locked up because thread is tangled or the machine is seizing up.
Remove the tangled thread, it it still happens that means your machine is seizing and requires service.
Apr 30, 2014 | Brother CS-8060 Computerized Sewing...
Brothercs6000i E5 E6 wont sew
could have a problem with the computer part of the machine, it would be a good idea to have it checked.
Nov 24, 2013 | Brother CS6000i Computerized Sewing...
I keep getting the E6 (tangled thread) message on my Brother CS600 when I try to sew. I have check for tangled thread and cannot find any. Could it be that the bobbin case needs to be replaced? It seems...
is the bobbin case damaged in any way?
try turning off the machine & unplugging it & then replug it back up & turn it on & see if that clears the computer parts of the machine
if it still shows a E6, then you can replace the bobbin case or you might even consider having it serviced
Aug 29, 2011 | Brother CS6000i Computerized Sewing...
I had sewing machines E6 computer bother a few yeas . Now I sewing , it turn E6 . what does E6 mean? Can you help me . How to fix it? Thank you.
Download a free manual from www.brother-usa.com and under support and put in your model number. E6, means that the thread is tangled, totally unthread it, now with the presser foot up, rethread, pull the top thread, now lower the presser foot and pull the thread, it should barely move. This will seat the thread in the tension discs. Read your manual before using, it will save you lots of grief. People love to skip this step, and wonder why the machine is not working right. This is one time you should take the time, it is worth it.
Apr 11, 2011 | Brother CS-6000
The stich is not tight
CHANGE UR STICH SIZE AND TIGHT UR TENSION DISK
Apr 04, 2010 | Riccar R651 Mechanical Sewing Machine
Brother sewing machine screen displays E6
Oct 01, 2009 | Brother Sewing Machines
Sewing Machines Logo
91 people viewed this question
Top Riccar Sewing Machines Experts
Tally Girl
Tally Girl
Joseph Mueller
Joseph Mueller
Are you a Riccar Sewing Machine Expert? Answer questions, earn points and help others
