Question about Dewalt DC920KA Heavy Duty Xrp 18V Cordless Drill/Driver
Cleaning up gear transmission for new grease - Dewalt DC920KA Heavy Duty Xrp 18V Cordless Drill/Driver
    President:
  • 1,902 Answers
Once you take the chuck off use somethine to the effects of brake cleaners, Wrap everything that you do not want to get the brake clean on and clean it and then let it sit for a few minutes then go ahead and oil everything and you will be good. Safe and effect way to do this especially if you have dirt or sand in the gears
Posted on Feb 20, 2009
I Have A 1995 Eagle Talon It Is A Manual Transmission Every Other Gear Shifts Fine Besides 3rd Gear It Grinds What Is The Problem And What Can I Do To Fix It The Least Expensive Way???
manual ,well try pumping some grease into the gearbox your problem is a worn baulk ring on the syncro and to fit a new cluster is a gearbox out type repair job.More that the car is worth no doubt so add a grease gun full of LM grease to the gearbox and learn how to double the clutch so you can change gear without a crunch .
Jan 03, 2013 | Cars & Trucks
Hi, I have a Kitchenaid stand up mixer custom edition 500 watt model #Kd2661xmc that sounds fine when I don't have anything in it, but sounds like its crying when I put just a single cake mix in it. ...
Get A Copy of the Repair Parts List for your model at Kitchenaid.com.
Remove the Gearcase Motor Housing (1) & the Transmission Housing (7)
Remove the 2 screws (23) holding down the Motor (2) and lift off way from
the Worm Gear (17). Test run the motor by itself at different speeds.
If it runs fine then it's time to inspect all the gears in the Transmission
Housing(7). Remove all the brown Grease covering the gears.
Pay attention in particular to the teeth of the Worm Follower Gear (19).
(the Bevel Gear (21) sits on top of this gear)
They should not be worn out or chipped. If they are then this is the source
of the noises you're hearing (the Worm Gear is grinding away the teeth of
the Worm Follower Gear). Once the Follower is replaced, your mixer will
be just as new again.
Please Note that this replacement is not an easy task. You need the right
tools and don't use a hard object like a steel screwdriver to pry out the
Planetary plate (15) from the beater shaft. Before re-assembly, use only
fresh new Food Grade Grease from Kitchenaid (the old grease may contain
metal filings from the worn out gear that will damage your new one)
Jul 22, 2011 | KitchenAid KSM150PS Artisan Series Stand...
The self propeller is messed up. It sounds horrible. I might need parts for the gears.
On this mower it will probably need a new transmission assembly. If you replace the gears you may still have problems. The transmissions on the Toro product line, before 2009 have a bad tendency to go out. If the unit is still under warranty I would take it in and get it replaced. If you decide to do the work yourself it will take a while. If you provide a model number in the add comments section I can get you a parts breakdown, and maybe a parts manual for your model. Also if you get a new transmission assembly, take the four bolts off of the bottom and add grease yourself. We use high temp grease in the transmissions. Add the grease until the box is full then put the bolts back in. This will help it to stay working longer. Depending on which transmission you need, the price of an assembly is somewhere between 65 and 75 dollars. I've seen some of them go for over 100. It just depends on which one you need. I hope this helps.
Apr 07, 2011 | Toro Lawn Boy Self Propelled CARB Walk...
Transmission, not wanting to go in gear
After replacing a transmission on one Rodeo for that problem, I discovered there is a transmission control module located on top of the transmission on the driver's side. Two bolts disconnect it. Wipe off the old electric grease, and put on new electric grease. Reinstall the part. I have now driven 30,000 miles on this fix. Needless to say, I was very unhappy with AAMCO. If your rodeo starts having that problem, drive only in third gear until you can fix this part. Planetisuzoo is very detailed on this fix.
Dec 30, 2010 | 2002 Isuzu Rodeo
On an automatic transmission there is two places to put gear oil. Is this the same on a manual transmission. I have switched out a auto for manual and added gear oil in one place but still get a growl am...
Was it a new manual transmission? If it was used, you may have gotten one with some wear on the bearings. There is only one place to put transmission into the transmission. Are you using the correct grease for a manual transmission?
Sep 16, 2010 | Geo Prizm Cars & Trucks
Sears rototiller wheels locked up engine runs great
After taking the transmission/frame apart, the drive chain for the tires broke and wedged in the case. I cleaned the rest of the gear box and washed all of the gears and sprockets. Ordered up the chain, gasket and grease. I re-installed and greased all of the pieces and reassembled the case. I used a marine wheel bearing grease for the water resistant properties. I installed a zerk fitting right over the shifting lever. This should help keep the grease on the top end of all the gears. After a few hours it is good to go and works just like new.
Aug 20, 2009 | Craftsman Garden
Can't find filler plug on transmission
Jim the older tillers did not have a place to put grease in. You have to break the case apart then it takes 00 grease. These are sealed units and don't need additional grease. Check with Sears.com parts lookup for a new manual. I am on my second Craftsman r/t tiller now rebuilt the transmission on the first and wore it completly out then bought a new about 8 years ago. About to rebuild the transmission on it.
Apr 24, 2009 | Craftsman Rear Mount Tiller
Hobart A200 noise
Your mixer was built in 1942 and from the sound of it, it's been without grease for some time. Before you dismantle it, try adding new grease to it. This is the less expensive and less time consuming approach. The grease product to look for is Shell Darina XL EP-2, Try to find a local Shell Distributor and see if they'll sell you about 4 tubes of 400 grams each. This grease is compatible with most other greases, so you won't have to remove the old grease before you add the new stuff.
Remove the four screws that attach the Hub to the body of the mixer, pull off the hub. You now have access to the transmission area. work the new grease into the cavity, try to get as much grease as you can toward the back of the compartment. This will be a very messy job unless you have, or acquire a grease gun that the tubes will fit in. Lay the mixer on it's back and let gravity help you to get a lot of grease down through the hub opening. Keep adding grease until you've greased up to the hub opening. Grease the hub gear and then re-install the hub. Raise the mixer to vertical and start up the mixer, letting it run for a couple of minutes. Stop the mixer and shift gears,, once again start the mixer and repeat this procedure for the last gear. Listen for the sounds it was making before, they should be silent or at least muted. If it's still making loud noises, You may well have to take it apart for an overhaul. Dont overlook the planetary gearing, this gearing is not bathed in grease like the trans. Remove the planetery assembly, clean and inspect the planetary gear and the large ring gear in the mixer body. Regrease both and re-assemble. Your mixer is now as quiet as it will get short of a complete overhaul. If this solution works, it has only cost you a few bucks and a bit of time, making this. solution a good one, unless you still have the major noise issues.
I f you've found this solution helpfull, please rate it and Good Luck! ricardok45
Nov 26, 2008 | Hobart A200 Stand Mixer
2007 Ford Focus SE
they probley put grease in with tranny oil to try an silence it try cleaning oil pan out an retop tran oil if no cure u have seriouse box problem
Nov 17, 2008 | 2007 Ford Focus (3 Door) Hatchback
K45 started smoking while mixing cookie dough
There is the possibility that if the mixer is 30 years old and it has never been serviced that the gasket around the gear case is leaking oil and in that case it would not be hard to get liquids on the armature or the stator as the gear grease in the transmission is vegetable base grease and it separates into liquids and solid and when the head is tilted up the failed gasket allows the separated oil to leak down and to the rear onto the mixer right onto the motor parts. It maybe nothing more that cleaning out all the old grease and re-packing and adding a new gasket.
Dec 14, 2007 | Food Mixers
Dewalt DC920KA Heavy Duty Xrp 18V Cordless Drill/Driver Logo
199 people viewed this question
Top Dewalt Drills Experts
Jim Thurston
Are you a Dewalt Drill Expert? Answer questions, earn points and help others
