Question about General Electric Washing Machine Chrome Timer Knob W/Clip
Timer is wonky, pump didn't work, now the spin is kaput
We have a mod; WISR309D TBWW Ser#ZH107243G. we are out here in west africa, and the timer is wrecked, I pulled apart the timer, the contacts were dirty, so I cleaned them, but I must have something out of time, as either the pump won't kick in to get rid of water, or the spin and agetate doesn't work. there is a little motor thing on the back to turn the rotary dial, but am not sure how to time that, also had trouble getting the contacts to work right, but I think that I solved that. Am suggestions would be greatly appreciated.
Paul
  • psterken Feb 20, 2009
    power supply is good, I think that I am already in the control board, and that's were the contact points are, how do you time the rotary dial to the motor that turns the rotary dial?
    Brigadier General:
  • 3,614 Answers
HI THERE,
better do checking also on the control board, must be check and clean also the contacts.
Posted on Feb 20, 2009
  • micromaster
    micromaster Feb 20, 2009
    also for clarification.
    did the washer gets power or it has power coming into it. turn off the breaker and plug the washer into a different outlet.
    let me know
My model GLET1041AS2 Frigidaire Laundry Center fills/agitates, but does not pump or spin. The timer would make a slight buzzing/timer sound when it hits the spin cycle, but nothing else.
The circuit board has a Cycle generator and sequencer that accepts commands when you manually do a setting. When the sequence enters the spin phase a block occurs and discontinues further action. It is not the timer, but the command center on the circuit board. Because the board has many functions, it is like a set of Christmas Tree lights in series, and when one bulb fails, so goes the set. You will no doubt need a new command board for that model.
Mar 12, 2014 | Frigidaire Genuine Washer Timer 134049600
I can't find the wiring diagram for my whirlpool refridgerator.... MOD.#ET19RKXFN01 SER.#EG3222178. Can you please help. I need to change the defrost timer.....Thanks
I will try to locate a wiring diagram for your model ET19RKXFN01 but to change the defrost timer you will only need to know its location. Here is a link to the repair parts=> ET19RKXFN01_Repair_Parts_List
Go to page 5 of the repair parts list and you will see item number 4 Then on page 6 of the parts list you will see the timer part number beside the item 4. That is your defrost timer part number 2193084 Defrost Timer
Your refrigerator is an older model and may have the wiring digram in a packet behind the kick plate in the front near floor. Changing the defrost timer will not require use of a wiring diagram. Simply remove the old timer and replace the new defrost timer by plugging it into the wiring harness. The defrost timer can be found behind the control panel inside the fresh food compartment where the controls are located above the top shelf. If you have questions just let me know, Thanks Sea Breeze
Nov 30, 2012 | Whirlpool Refrigerators
Kenmore 417.43142200 final spin is slow
obviously the timers contacts are bad so replace the timer.
May 16, 2017 | Kenmore 43142 Front Load Washer
My Sears washer Mod. # 110.28822791 SN CJ1904857 will not advance to the spin cycle. I replaced timer part # 3950200. It works intermittently. You have to move it to the spin cycle and then it will...
If you replaced the timer with a new one make sure its the right one with its part number listed on it if its the wrong one it wont work right. sounds like a power problem or clock problem with the timer might need a qualified service technician come look at it to rule the problem out hope this helps.
Jan 06, 2011 | Kenmore Washing Machines
My dryer does not tuen off on its own anymore. how can I fix it?
More than likely the timer has gone out. It has a small electric(not replaceable) motor in the timer that advances the time. If the appliance works when you manually advance it to different cycles
thats probably the problem.
Leo Ponder
imufo2@sbcglobal.net
Jul 25, 2010 | Maytag MED5707TQ Electric Dryer
Washer will not empty
if it spins and agitates, but wont empty, ur timer is bad,(dialcontrol)
May 08, 2010 | Whirlpool Calypso GVW9959K Top Load Washer
Water goes in and pumps out basically only hums no timer movement
I would take apart the pump and I'll bet you there is a booby pin or something jamming it, I had the same problem and fixed it by myself.
Jan 15, 2009 | Kenmore 44072 Front Load Washer
Whirlpool Ultimate Care II spins only once in a while :-)
hi there,
sounds like the timer switch. the switch is mechanical, so it's quite easily replacable.
also, the overfilling is a result of the pressure switch no engaging. this switch senses the water level and once it's up to capacity, it will shut off the water supply into the tub. check the switch and switch wire to make sure it's working correct. this switch is also mechanical and easy to fix.
let me know if i can be of more help.
thanks
Sep 29, 2008 | Whirlpool Ultimate Care II LSQ9549L Top...
Washer fills/agitates and stops prior to draining
If pump works fine or still pumps out water, then it is a timer malfunction. Replace the timer and you should be fine. To locate a part number for your timer, refer to www3.sears.com with the model number off your washer.
Mar 14, 2008 | Kenmore 24032\24036 Top Load Washer
General Electric Washing Machine Chrome Timer Knob W/Clip Logo
27 people viewed this question
Top General Electric Hardware & Accessories Experts
jdthefixer
pawnpower
Are you a General Electric Hardware and Accessory Expert? Answer questions, earn points and help others
