Question about Samsung V25 CXTD 2000 Notebook
I have a samsung v25 and on the screen it shows a white screen with vertical grey stripes in about 5 places, the computer does not boot up could you help me regards vic
Rainbow stripes and color changing box
If the screen is damaged, then no there nothing you can do without replacing the screen BUT then is it really damaged? I would try and see if a normal image is displayed on an external display via the laptops VGA port and cable. If good than it is most likely the screen BUT I would look into (By pulling the screen covers off, etc to see if all cables from the System board to the screen is connected properly, if they are and also same image is on the external screen then the graphics chip is the culprit...depends on how hard and at what angle etc did the Laptop hit the foot-board.
May 01, 2013 | ASUS Eee Computers & Internet
Rainbow stripes and color changing gradient box
Since this is a problem that obviously occured because the laptop fell and the LCD got damaged I suggest you take it to a repair shop, if it can even be repaired.
My laptop did not start it only show black screen
that happened to my mates laptop he had to go and get it repaired so goodluck:) please rate this solution...
Jun 06, 2010 | Samsung V25 XVC 2800 Notebook
Vertical grey line during boot sequence
check it in bios, if it is there then its a h/w fault. send it in for repair.
if not then refresh the graphics driver.
Apr 25, 2010 | HP Pavilion dv6000z Notebook
I'm also experiencing same sort of white screen problem.
To determine if the LCD screen or the video card is faulty, connect an external monitor to the video connector on the laptop. Power up the external monitor first and then the laptop. The video should divert automatically to the external monitor and if you get a normal image then the video card is OK and the fault could be the LCD screen or the video cable. Reseating the video cable and connector on the motherboard could fix yout problem.
Jun 14, 2009 | Acer Aspire 4315 Notebook
Display comes on with stripes of color then turns white
Try Booting To An External Monitor If able to...
If Display is Normal In It, Your LCD Display Panel Is Bad... The Circuit Board Attached to the Display Panel has Gone Bad...
But If You Hook It Up To External Monitor and It Doesnt Work...
Your Video Card/Chip is bad
Nov 17, 2008 | Toshiba Satellite A105 Notebook
Samsung V25 fan replacement
It may not be the fan, I have a V25 and it was the motherboard, it wouldnt power the fans anymore when the CPU required it so would crash lots.
If the fans twitch or run for a second or two when you first turn the laptop on then it's the motherboard that is faulty.
Careful with the monitor to motherboard plug as I damaged mine and the screen is now a permanent shade of blue.
Jun 25, 2008 | Samsung V25 XVC 2800 Notebook
Samsung V25 Laptop When it is powered up nothing is showing on the screen although the power light is on and you can hear a noise. This has happened before and it just came on.
One way to make sure the system is still working, remove the Batery, then plug the power adapter only and turn the computer back on, normally if the laptop goes into Hybernation mode and the battery is low on power this can happen. If that fixes the system then you can do a safe shutdown and re-install the battery and turn your laptop on and it should come on, the fact that you mentioned this has happened before makes me believe it is Hybernation issue. Good Luck.
Jan 07, 2008 | Samsung V25 CXTD 2000 Notebook
Samsung v25 won't boot up
this is os or motherboard problem, reinstall the os
Nov 05, 2007 | Samsung V25 XVC 2800 Notebook
Samsung V25 CXTD 2000 Notebook Logo
126 people viewed this question
Top Samsung Computers & Internet Experts
phoenix chi
phoenix chi
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
