Question about Craftsman 17.5 hp 42 in. Deck Lawn Tractor - CA Model
I have (MTD)riding mower 17.2 HP brand new runs good,now I tried to put a ball hitch at the rear and there"s a hole but too small so I had to used pry barand hammer to make the hole bigger,and all the pounding the hammer suddenly filled off the fuseand put the fuse back and i tried to crank the mower it won't anymore,so this is my problem can you help my problem now?
VanHuben
  • 5 Answers
SOURCE: Lawn Mower won't start
Its a thing of beauty to see problems solve themselves. It seems to me this trial and error approach is very taxing and could have been avoided if 1, your small engine repair guy/Craftsman/Sears had sold you the right parts from the start, or 2, you had bought the right part... from the start.
Posted on Oct 24, 2008
  • 8 Answers
SOURCE: craftsman riding mower model 917.270921 put on a
What method are you jump starting? Are you putting clamps from jump battery on the posts of the battery or grounding the jump battery and then touching the + cable to the starter terminal?
Posted on Feb 23, 2009
rockitman187
  • 2559 Answers
SOURCE: Craftsman 19hp riding mower wont stay running
The carb jets are partially clogged and needs to be cleaned.
Posted on Apr 05, 2009
GM Elec
  • 1000 Answers
SOURCE: Craftsman riding lawn mower...engine dies when blade is engaged
Push the clutch all the way down and try to start, does it crank over?
Let me know.
Regards,
Posted on May 10, 2009
  • 9 Answers
SOURCE: i have a bolens 38 inch riding mower. it cranked
did you try depressing the clutch to disengage everything regardless of being in neutral? and it sounds like a pulley bearing went bad.try to spin the pulley with your hand and see if it moves.take the belt off to the mower deck and that should keep them from turning when you go to start it.
Posted on Feb 21, 2010
Testimonial: "thanks. at least i can crank it and get it to a trailer instead of pushing it. i really appreciate it.......cb"
How to replace the cable that engages blade on an MTD 42" cut riding mower
Utube or ur library...has shop manuals. Do it slow n safe...dont endup the er
Sep 12, 2015 | Mtd Garden
How to adjust brake/clutch on mtd riding mower
Go to MTD website and download owners/or repair manual for your tractor ,then adjusting the brake will be easy !
Jun 29, 2014 | Mtd FASTATTACH MANUAL SLEEVE HITCH
Model # 247.28881
Variable pitch double pulley mount bearings. Requires 2 each.
Ball Bearing , 17 x 40 x 12 mm
6203-2RS
MTD PN 941-0600
Aftermarket versions available.
Jun 27, 2014 | Craftsman Garden
My riding lawn mower wont move when in gear the brake doesnt work either
have you checked the main drive belt or the gearbox drive belt? Most mowers built by MTD have a main drive belt that is run from the motor pulley to the rear end, then a shorter belt actually drives the gearbox. Mine is a Cub Cadet and you can usually get to the back belt by removing the battery and battery box. By using a piece of water pipe about 3 ft long you can move the spring loaded pulley and reattach the belt. MTD builds a large majority of the riders up to 25 hp. Ex. John Deere, Cub Cadet, Troybilt and many of the store brand riders. my Cub Cadet sometimes has a drive linkage pin to fall out and instead of stopping it goes faster. you didn't give the brand name of your mower so that would help.
Apr 28, 2014 | Garden
My 13.5 ho b&s surges heavily but smoothed out when blade/ deck is engaged or when I apply choke. I've twice cleaned carbs and still now working. I ran in garage with no air filter to elimina
hello sir, mower will not start or run,runs only when primming, does it have good spark,good compression,or only runs on full choke, are you getting fuel to the engine if not try this,your fuel pump or your carb. is clogged up here is what you can do for a simple repair for the carb,you can remove the air filter and assy, empty fuel tank and clean out tank and line,remove the bowl nut and bowl careful of the gaskets,now spray carb cleaner in the small port holes in the carb steam in the middle of the carb until clean,now spray the bowl nut holes until clean there are three,after cleaning put bowl on the same way you removed it with dip towards front of float,put bow, and fresh gas,you should be good to go,hope this helps.,thank you.~~
Feb 19, 2012 | Mtd Garden
Motor running away as soon as you start it
Had the same problem on mine. 18.5 B&S OHV. The throttle shaft in the carb broke causing it to run wide open. The shaft broke at the small screw holes holding the butterfly on. The small screw went and stuck on the head and the butterfly was not able to close to idol down. No damage luckly, just had to take off the head to remove the small screw and get a new gasket. The shaft cost me around 17 bucks from a local mower shop. not hard to put on. It had 2 different buttlerflys in the packet, make sure you use the right one. Took longer to go get the part than to repair it. Good Luck. Tom bivens40 at bellsouth dot net
Jun 24, 2010 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
MTD 46" Yard-Man Lawn Tractor battery connection problem!?
the battery for a garden tractor should have the holes already in it if not you can buy a clamp that you can use that has a hole for what you need. good luck
Apr 11, 2010 | Mtd 46" Dozer Blade, Fits All & Yard -...
Removed bolt but still can't remove rear wheel on MTD riding mower .
they sometimes are very haed to get off some wheels have two holes on the rim you have to use a gear puller
Nov 05, 2009 | Mtd Garden
Obtained Riding Yardmachine MYD mower Model 13AN690G352
go to www.superxpower.com great site for ordering all parts for MTD (and others) Great illustrated parts breakdown.
Apr 19, 2009 | Mtd FASTATTACH MANUAL SLEEVE HITCH
Craftsman 17.5 hp 42 in. Deck Lawn Tractor - CA Model Logo
97 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Dean Gruber
Roland W VanLue
Roland W VanLue
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
