Question about Mtd LAWN MOWER PART # 683-04163B FRAME Assembly:RIDER
I need pics of mtd rider mower 300series pullies and clutch conection
3 Suggested Answers
  • 133 Answers
SOURCE: How do I know if I am replacing my mtd rider mower belt correctly
The rule of thumb for the routing of the mower belts is to make sure the "V" inside of belt is fitted into your pulleys. The "FLAT SIDE" outside of the belts rides with the flat side up against your idlers (lookes kinda like a pulley but is wider.) It might take you a couple of attempts to get it right. When the belt is on properly it will be nice and snug.
Good luck
roundo4
Posted on May 24, 2010
kel1guy2002
  • 3740 Answers
SOURCE: require replacement clutch for MTD RH 135\105 B
Hi I am Kelly and welcome to FixYa. I am having difficulty crossing your model number. Do you know what year you purchased the mower?
I have found a close match at this site using model year 1995
http://www.jackssmallengines.com/help.cfm
You need to choose these drop down window options in the order listed on the site:
"Search for Model"
MTD
MTD GOLD
13-Lawn Tractors
1995 Models (There are 3 of them... so I would bet you will have to find the closest match to your model)
After all of the above FINALLY the model diagrams will come up.
There is another drop down menu just above the Zoom + or - buttons for the sub assemblies.
I am thinking this is what you were looking for but... if not please check your model number again and I will continue to assist you.
Thanks for choosing FixYa.
Kelly
Posted on Jul 22, 2010
Why rider mower wont shut off?
The ignition switch may be broken or have a loose wire.
May 28, 2014 | Mtd LAWN MOWER PART # 683-04163B FRAME...
Clutch set up
you will have to replace the clutch located on the bottom rear of the mower, its very easy.
Apr 25, 2013 | Mtd Garden
What is the drive belt adjustment 11.5 hp ride on mower
The drive belt is tensioned by a spring on the clutch pedal. If you can give me the model of mower you are working on, I can help you find the spring or the variable speed pully.
Thanks, Matt
Jan 15, 2011 | Mtd Garden
My mtd yard machine has develabed a jurking motion going downhill only
need to replace clutch pulley this is easy if you are strong enough put it up on safe blocks rear in the air take a proper wrench put it on the nut take a 1-1/4 pvc pipe slide it over the wrench for leverage this triples leverage put a long screw driver in so the pully wont turn and turn the nut replace with new clutch pulley and belt and watch youre mower pull like new.
Nov 05, 2010 | Yard Machines MTD Gold 20 HP Lawn Tractor...
How do you remove the double engine pully on an mtd tractor
Remove the crossover plate with the belt guide bolts in it, remove both belts, remove the bolt up in the center of the stack pulley and pull it downward until it is loose from the engine
Sep 17, 2009 | Mtd LAWN MOWER PART # 683-04163B FRAME...
Mtd rider trans belt will not stay on
it sounds like the spring got stretched or came loose. or wrong belt or the dowl pins around the pully came off?
May 07, 2009 | Mtd 46" Dozer Blade, Fits All & Yard -...
Mtd LAWN MOWER PART # 683-04163B FRAME Assembly:RIDER Logo
111 people viewed this question
Top Mtd Garden Experts
Roland W VanLue
Roland W VanLue
Tim Whalen
Phil Walker
Phil Walker
Are you a Mtd Garden Expert? Answer questions, earn points and help others
