Question about Samsung SGH-U700 Cellular Phone
U700 when slide the soft touch key not response
My u700 does not work properly when it slide up and the display place inverted lcd
Sounds like a flex connector problem. have it replaced asap.
Posted on Mar 03, 2009
I have an Acer Extensa 5635. All the lights on the laptop work and i can hear the Windows sounds but the monitor doesn't show.. what do i do?
follow this steps and fix it. God bless you
    Power off your computer. Examine the bezel of your laptop, which is the perimeter surrounding the LCD display. There will be screws around the edges of the bezel, likely with screw covers on them, depending on your exact model. Pop off these screw covers using a knife tip, for example, and then remove all the bezel screws using a Phillips screwdriver. Put these screws in a safe place, such as a small plastic bag, because you will need them later.
      • 2
    Remove the bezel from the display. Pop it off by isolating a corner and peeling it off from there. Be careful not to bend or warp the bezel in the process.
      3 Disconnect the inverter cable. The inverter cable plugs into the inverter, which is located directly beside it. The inverter can be found beneath the bezel after it is removed, and directly below the center of the LCD display.
        • 4
      Remove the remaining screws. These screws are located in the metal brackets on either side of the laptop screen. These metal brackets are only visible once the bezel is removed. There should be two screws on each bracket, but this varies by model. Use your Phillips screwdriver to remove these screws, and put them in safe place, such as your plastic bag.
        • 5
      Pull the LCD display from the back plastic of the computer carefully, then remove the old display altogether. Slide the new display in and reconnect the inverter cable.
        • 6
      Replace the screws into each metal bracket, making sure to hold the new LCD display in place. Then, put the bezel into place over the LCD display. Replace all the screws and make sure they are tightly screwed into the bezel. Power the Toshiba laptop back on and enjoy your newly fixed hardware. Save any documentation that shipped with your replacement LCD display for later perusal or warranty purposes.
      Jul 31, 2013 | Computers & Internet
      Toshiba a500 wont turn on
      If your laptop won't turn on, you could have any number of problems. The problem might be a genuine power issue derived from either battery failure or simply a loose AC adapter. Conversely, it may only appear to be a power failure, and the problem may lie with another component. Errors in brightness settings and LCD display malfunctions can both make a laptop appear to be powered off, and all these problems will need to be corrected.
      Look at the battery indicator light on your computer. Is it on? If so, check your brightness settings. If your laptop appears that it is not on, it may in actuality have lowered brightness settings. If the brightness setting is at its lowest setting, the laptop screen will be completely dark, and the laptop will appear to be powered off, even though it is not. Try cranking up the brightness settings. Check your AC power adapter. Is it snugly plugged into the wall or surge protector? Make sure the connection is made and it is not loose. Also, try connecting the power adapter into a different wall outlet. Check the status of your laptop battery by considering how long you have had the same battery. Most modern batteries are only good for about 1,000 full charges. After that point, the battery can and eventually will greatly deteriorate. Replace your battery if necessary. Replace your battery by powering off your laptop and then flipping it over and locating the battery cover outline, which will be near the bottom back of your laptop. Remove any screws with a Phillips screwdriver and pop off the battery cover. Slide out the old battery. Put in the new battery by sliding it in until it clicks, and then replace the cover. Consider replacing your laptop monitor. Your laptop may power on, but if the monitor display does not work, it will appear to be off and you will not be able to operate the machine. Check to see if your current LCD display works by plugging your laptop up to an external monitor using a VGA cable. If the external monitor displays your computer contents, your computer motherboard and underlying systems are still working, but your display will need to be replaced. Replace an LCD display by removing the screws around the bezel of your current display with a Phillips screwdriver. Pop off the bezel carefully and remove it. Then, locate the screws on the two metal brackets beneath the bezel and on either side of the display, and remove these too. Disconnect the inverter cable, which is plugged into the inverter. The inverter is located just beneath the display, at the bottom-center of the laptop. Then, pull back and slide out the old display, and replace it with the new. Put the metal bracket screws back in place, reconnect the inverter cable, and then pop the bezel in place. Replace the bezel screws. Hope this helps.
      Jan 20, 2013 | Computers & Internet
      Black screen delld600
      Several things can cause your Dell Latittude D600 laptop's LCD screen to stop working.
      Two of the most common causes relate directly to the inverter board and the backlight lamp.
      The inverter board is a thin circuit board placed inside the LCD panel.
      It's main function is to transfer power from the motherboard to the backlight bulb inside the LCD screen.
      If the inverter board goes bad or the backlight lamp burns out, the screen will appear dim or eventually go completely black.
      Turn off the laptop, unplug the power cable, close the LCD panel and place the laptop face down.
      Remove the battery pack from its compartment on the bottom of the computer.
      Flip the laptop back over and reopen the display panel all the way until it is in a 180-degree position.
      Insert a flat head screwdriver into the right side of the keyboard bezel.
      This is the plastic strip situated above the top row of keyboard keys. Carefully pry the bezel from the laptop.
      Remove the two Phillips screws located above the top row of keyboard keys.
      Grasp the top edge of the keyboard, tilt it upward and lay the keyboard face down on the palm rest area.
      Unplug the keyboard's ribbon cable from the motherboard connector.
      Carefully remove the entire keyboard from the laptop.
      Disconnect the video and speaker cables extending from either side of the LCD panel to the motherboard.
      Loosen the Phillips head screws on each LCD panel hinge.
      Carefully lift the entire LCD panel off the laptop's base.
      Relocate the panel to a flat work surface, and place the panel so the screen is facing upward.
      Use a thin, flat head screwdriver to pry the rubber screw covers from the LCD panel's front plastic cover.
      Remove the Phillips head screws revealed by the rubber covers.
      Carefully remove the front plastic cover from the display panel.
      Locate the inverter board situated below the LCD screen, inside the bottom edge of the display panel.
      Disconnect the two cables from each end of the inverter.
      Remove the two Phillips head screws fastening the inverter to the display panel.
      Carefully lift the inverter board out of the display panel, and dispose of it.
      Repeat this procedure in reverse to install the new inverter board, and reassemble the laptop.
      Hope this helps
      Oct 23, 2012 | Dell Latitude D600 Notebook
      Will not turn on
      Is it on?
      hope this helps
      Oct 22, 2012 | Dell Latitude D610 Notebook
      Soft "Pop", Then Black Screen. Sound is OK.
      First check the inverter for any burst capacitors and the display boards.
      Aug 28, 2012 | Toshiba 20DL74 20 in. EDTV-Ready LCD...
      Computer wont start in any mode, black screen
      Look at the battery indicator light on your computer. Is it on? If so, check your brightness settings. If your laptop appears that it is not on, it may in actuality have 1.lowered brightness settings. If the brightness setting is at its lowest setting, the laptop screen will be completely dark, and the laptop will appear to be powered off, even though it is not. Try cranking up the brightness settings.
      2.Check your AC power adapter. Is it snugly plugged into the wall or surge protector? Make sure the connection is made and it is not loose. Also, try connecting the power adapter into a different wall outlet.
      3.Check the status of your laptop battery by considering how long you have had the same battery. Most modern batteries are only good for about 1,000 full charges. After that point, the battery can and eventually will greatly deteriorate. Replace your battery if necessary.
      4.Replace your battery by powering off your laptop and then flipping it over and locating the battery cover outline, which will be near the bottom back of your laptop. Remove any screws with a Phillips screwdriver and pop off the battery cover. Slide out the old battery. Put in the new battery by sliding it in until it clicks, and then replace the cover.
      5.Consider replacing your laptop monitor. Your laptop may power on, but if the monitor display does not work, it will appear to be off and you will not be able to operate the machine. Check to see if your current LCD display works by plugging your laptop up to an external monitor using a VGA cable. If the external monitor displays your computer contents, your computer motherboard and underlying systems are still working, but your display will need to be replaced.
      6.Replace an LCD display by removing the screws around the bezel of your current display with a Phillips screwdriver. Pop off the bezel carefully and remove it. Then, locate the screws on the two metal brackets beneath the bezel and on either side of the display, and remove these too.
      7.Disconnect the inverter cable, which is plugged into the inverter. The inverter is located just beneath the display, at the bottom-center of the laptop. Then, pull back and slide out the old display, and replace it with the new. Put the metal bracket screws back in place, reconnect the inverter cable, and then pop the bezel in place. Replace the bezel screws.
      Sep 28, 2011 | Computers & Internet
      Having a sound problem when sliding up my SAMSUNG SGH-U700 phone
      It will be problem on the strip of ur phone,
      Just Contact to Authorized Service center to solve.
      May 09, 2010 | Samsung SGH-U700 Cellular Phone
      What is the possible trouble of my samsung sgh u-700, the screen only shows blank and sometimes the features appears but not in a normal appearance,,, it appears scattered and moving in different direction...
      I think this a problem related to the flex cable that connects the main phone body to the sliding screen. Over time the flex cable wears down as it slides and results in a whole range or problems such as: display acting weird (eg. mirror-image and inverted colours), speaker not working, off-button not working etc.
      Flex cables are cheap to buy on ebay (a few dollars) and there's internet sites that show you how to open the phone and replace them. (google: samsung u700 replacement flex cable)
      Mar 21, 2010 | Samsung SGH-U700 Cellular Phone
      I have a hp2000 with a black display screen
      your problem is a faulty ccfl BackLight Inverter, the display uses the backlight to illuminate the lcd screen, the inverter is used to illuminate the cold cathode light in the back of ther lcd theirs countless places to laern about it on google
      Aug 20, 2009 | Dell Latitude D600 Notebook
      Touch Keys and Screen
      Jul 13, 2009 | Samsung SGH-U700 Cellular Phone
      Samsung SGH-U700 Cellular Phone Logo
      534 people viewed this question
      Top Samsung Cell Phones Experts
      Computer Repairing
      Computer Repairing
      Ronny Bennett Sr.
      Ronny Bennett Sr.
      Are you a Samsung Cell Phone Expert? Answer questions, earn points and help others
