Question about Intermatic WH40 - Water Heater Time Switch - NEMA 1 Indoor Steel Case - DPS
HOT WATER Is hot water suppose to be the same temperature as the thermostat setting for the hot water heater?
  • Allen Neal
    Allen Neal May 11, 2010
    WHAT TYPE OF H/W HEATER ARE WE TALKING HERE
    Novelist:
  • 152 Answers
Not exactly, the heated water in the tank it self is roughly the desired temperature of the thermostat, there is a variable of 5 to 15+ degrees depending on its calibration. there are other considerations i.e. water heater tank insulation - hot water pipes being exposed to cooler temperatures thus cooling the water in the pipe - the farther distance that the water travels from the heat source, the cooler the water will be at the spigot.
Posted on Feb 21, 2009
Unit stiebel Tempra 24Hot water is running through house but cold water pipe is getting hot. Hot water pipe is not getting hot. When cold water connection is removed and water is turned on hot water is...
follow this steps and fix it. God bless you
If there is no hot water, first push the reset button on the high-temperature cutoff; test the thermostat and replace if faulty (see below). Test the heating elements and replace if faulty (see below).
If there is not enough hot water, adjust the thermostat settings. As needed, reset, test and replace thermostats and heating elements if faulty.
If the water is too hot, adjust the thermostat settings and reset. Test and replace the thermostat or high-limit cutoff (see below).
An electric water heater is a 240-volt appliance that can deliver a fatal shock. Always turn off power to the heater at the electrical panel 585dc480-4881-44a8-afda-7267c0f3de26.jpgbefore beginning work, and verify that power has been shut off. Make sure others in the house know not to restore electricity prematurely. If you have any doubt as to whether electricity has been turned off, seek professional assistance.
Oct 02, 2013 | Stiebel Eltron TEMPRA 24 Tankless Water...
Tip
Electric Hot Water Heater Temperature Adjustment
If your electric hot water heater is not getting your water hot enough or your water is too hot then you can make the adjustment easily yourself. There are a few things that you may need to know to do this. I will go over where the thermostat(s) are located and also how to make the changes.
The first thing to remember is to make sure that the power is turned off to the hot water heater before you attempt to open any of the covers and make any adjustments.
The next thing is to locate the covers which are over the thermostats and the elements. There are two on most hot water heaters, one for the top and one for the bottom. One or two screws hold these covers in place. They will look like this when you look at the front of the hot water heater.
When you have the cover removed you will see that the top thermostat, reset safety control and the element look like this.
The bottom thermostat and element look like this.
If you need to reset the hot water heater you push the red button on the top thermostat in hard till it clicks. To change the temperature setting on the thermostat you need to take a screw driver and turn the dial to the desired temperature either higher or lower as you prefer.
The elements can also be checked by using and ohm meter and checking for resistance across the two terminals of the element. If you get no resistance or a high resistance the element is no good. A normal reading with most meters will be somewhere in the 8-25 ohm range. This even gives a bit of buffer for different meters and the possibility of them being a bit out of calibration.
For most people a simple adjustment of the temperature settings will be sufficient to give you the results you want. Remember that you may need to adjust the thermostat for both elements to get the desired result. Also remember that you can get a longer time before you run out of hot water if the water is hoter and you mix more cold into it. The downside of that is the chances for scalding are greatly increased with hotter water. If you have small children or elderly adults, think carefully about what very hot water can do to them.
For higher efficiency you also want to keep the water temperatures as low as possible to reduce the residual heat loss of the stored hot water.
http://www.fixya.com/support/r4654730-electric_water_heater_not_working
http://www.fixya.com/support/r4422595-electric_water_heater_wiring_diagram
http://www.fixya.com/support/r4041115-clean_hot_water_heater
http://www.fixya.com/support/r4656414-replace_thermostat_element_electric_hot
on Apr 29, 2010 | Water Heaters
Rheem 21vp40 1
Copy following links to identify type of thermostat, and see how to adjust temperature on that specific thermostat, and see other ways to increase amount of hot water
http://waterheatertimer.org/How-to-adjust-water-heater-temperature.html
http://waterheatertimer.org/Increase-amount-of-hot-water.html
Add a comment and describe if water heater is gas or electric, and add what other problems you are experiencing.
Jul 14, 2013 | Water Heaters
Not enough hot water ge smartwater water heater gas
1) Copy following links:
http://waterheatertimer.org/How-to-troubleshoot-gas-water-heater.html#intellivent
http://waterheatertimer.org/Crossover.html
http://waterheatertimer.org/How-to-adjust-temperature-on-water-heater.html
2) Low temperature setting, extremely cold incoming water, Water leak or broken pipe running hot out of tank, crossover caused by bad faucet cartridge or bad recircirculation check valve,, bad gas control valve thermostat.
Feb 19, 2013 | General Electric GE SmartWater Household...
Water won't stay hot long
1) Thermostat may be bad, or out of calibration. Set temperature higher, and/or troubleshoot by type of gas control.
Copy following link to troubleshoot by type of gas control valve:
2) Dip tube broken
http://waterheatertimer.org/Water-heater-dip-tube.html
3) Water leak running hot water out of tank.
Turn off all taps and put ear against pipe listening for water leak.
Dec 08, 2012 | Water Heaters
Whirlpool hot water heater puts out overly hot water
1) Make sure factory-supplied insulation and cover are reinstalled over thermostats, or cooler room temperature causes thermostat to under-approximate tank temperature, and this causes overly hot water.
http://waterheatertimer.org/images/Tank-with-insulation-2-600.jpg
2) Replace both thermostats.
Sticking thermostat can seem to act normally when tested, but when left alone it sticks, causing runaway overheating.
http://waterheatertimer.org/How-to-replace-thermostat-on-electric-water-heater.html
More resources:
http://waterheatertimer.org/How-to-troubleshoot-electric-problems-with-water-heater.html
Oct 03, 2012 | Water Heaters
Brand new heater seems to run out of hot water when ran for awhile and seems to take long to recover. also is it supposed to be noisy when running it almosy sounds like water running but its not
You have some hot water so that says specific things:
-Upper element is working.
-Electricity to water heater and circuit breaker are good
-You don't report a leak so TP valve is good
-You are not experiencing overheating event
-ECO reset button is not tripped
-Insulation and covers are in place so thermostat not exposed to cooler temperatures that would cause thermostat to misread temperature and cause overheating.
That leaves 6 suspects listed in order of ease:
1) Leaking faucet or broken water line that is running hot water all the time and tank cannot keep up.
2) Thermostats set too low. Turn power OFF, open covers and check each thermostat setting.
3) Loose screw or loose wire at upper thermostat, lower thermostat, or lower element. Turn power OFF and tighten screws, and look for signs of high heat and burning, especially on lower element.
4) Upper or lower thermostat is bad. Replace both thermostats for $28 and see if that corrects problem.
Parts available at home center, hardware, or plumbing supply
5) Defective wire between upper and lower sections of tank: If this is the case, and water heater has 2" foam insulation, then tank usually replaced since insulation is too dense to drop another wire. Call for manufacturer for warranty information. Do a full troubleshoot using multimeter.
http://waterheatertimer.org/Water-heater-manufacturers.html
6) Lower element is burned out. Test lower element. Replace lower element. Rheem elements are 4500 Watts and are available at home center, hardware, or plumbing supply
http://waterheatertimer.org/How-to-test-water-heater-element.html
http://waterheatertimer.org/How-to-replace-element-and-clean-sediment-out-of-electric-water-heater.html
Add a comment for more free help.
Also take advantage of fixya phone service.
For a price, expert speaks with you over phone while you work on water heater or any do-it-yourself project.
Fixya is always less expensive than a service call.
Jan 22, 2011 | Rheem 80 GAL ELEC TALL Water Heater 6YR SC...
I have an AO Smith Model EES 52 917 hot water heater. This morning my hot water suddenly disappeared. I have tried resetting the breaker with no luck.. I am not sure what else to try.
You have electric water heater.
Inside the upper panel on water heater is a thermostat with red reset button.
1) Click the reset.
2) Put insulation back over thermostat so it is not exposed to cooler air, so it reads correct temperature.
After resetting thermostat, you will have hot water.
The reset automatically clicks off when thermostat detects temperatures in excess of 150 degrees.
The re-set is a safety device, and it keeps everything safe.
If reset will not 're-set' with cold water in the tank, then thermostat is bad, replace thermostat.
You can repair electric water heater yourself following steps on links below
http://waterheatertimer.org/How-to-troubleshoot-electric-water-heater.html
If the reset clicks off again, just reset it
This is not a dangerous situation
Reset thermostat as many times as necessary until you can fix the problem
If you have trouble fixing the problem, add a comment at bottom of this page and it sends me an e-mail and I will help further
Thermostats with ECO red reset
Oct 26, 2010 | Water Heaters
I have a reliance 606 electric water heater. This is my problem. The water gets unbearably hot then I have to reset the reset button on the water heater. I am thinking that I need to replace the heating...
you need to replace the thermostats. the elements are working, as your water is getting hot.
I would replace both upper and lower thermostats. be sure to set the temps the same for both.
the thermostats sit against the tank and read the tank temperature. if one is malfunctioning, they will over heat the water, causing you to get severe hot water.
also as a precaution, I would replace the temperature and pressure relief valve. if your water is getting that hot, and this has not "popped" then it is time to replace it.
Sep 06, 2010 | RELIANCE ELECTRIC WATER HEATER
Intermatic WH40 - Water Heater Time Switch - NEMA 1 Indoor Steel Case - DPS Logo
97 people viewed this question
Top Intermatic Water Heaters Experts
Steve
Gary Nitowski
ray gallant
Are you an Intermatic Water Heater Expert? Answer questions, earn points and help others
