Question about Electrolux Microwave Ovens
Replace the handle on Electrolux Microwave
How do I replace the handle on Electrolux Microwave FMV156DCA
jsrock516
  • 5911 Answers
SOURCE: Need to replace the handle I have the part but how do i desassemble the door properly
To access the door handle mounting screws, you have to remove the inner door panel that goes around the perimeter of the glass. You can use a small screwdriver to simply pry the plastic up and work your way gradually around the perimiter of the glass. Most microwave ovens have grooves in the panel that you can insert the screwdriver into. Use care not to pry against the glass. The glass is tempered and also has an RF shield that prevents harmful microwaves from potentially harming the consumer. If you break the glass, you will need to purchase a new door.
The door handle screws are located behind the inner panel. Simply remove the broken handle and install the new one. Re-insert the inner door panel carefully and gradually work your way around the perimeter of the door glass and make sure it snaps back into place.
If you have questions, please let me know. I hope you find this information helpful.
Posted on Jun 03, 2009
MicrowaveSvc
  • 9086 Answers
SOURCE: How do I replace a LG LMV1630ST microwave oven door handle?
Normally you have to separate the door panels (as shown in the attached photo) and then you'll see the screws you need to remove.
Or you can watch a YouTube video (not a video I made) here that demonstrates how it's done.
Posted on Nov 25, 2009
MicrowaveSvc
  • 9086 Answers
SOURCE: need to replace handle on dacor microwave model: pmor30s. I have
We have the service / repair manual for this model and have uploaded it to our site here for free download to help you.
You have to separate the door panels (as shown in the attached photo) and then you'll see the previously hidden screw(s) you need to remove.
Or you can watch a YouTube video (not a video I made) that demonstrates how it's done.
In some cases, you then have to gently rotate the handle to unlock it.
Posted on Aug 04, 2009
  • 19 Answers
SOURCE: replacing handle on LG LMV1680WW microwave
I have never replaced a handle on a microwave. I was looking at mine. If I have to guess how to get to the screw behind the panel, I would guess the inside cover needs to be popped out. Now a day, all the covers are snapped together. Be careful not to break it.
Or look for your manual, or look it up on the web.
Good luck
Posted on Aug 29, 2009
MicrowaveSvc
  • 9086 Answers
SOURCE: replace door handle on mco153uq
Normally You have to separate the door panels (as shown in the attached photo) and then you'll see the previously hidden screw(s) you need to remove.
You can order parts here.
Posted on Aug 30, 2009
Model E130BM55HSC. How can I replace lower door handle bracket?
Hello Teresa, thank you for your inquiry!
I understand that you need assistance replacing a component on your Electrolux microwave. In order to replace the bracket you would need to disassemble the door. You should seek help from a professional technician for proper assistance with the disassembly. This will help you avoid any personal harm of improper disassembly of the microwave. Best of luck! -Matt
Mar 09, 2016 | Electrolux Microwave Ovens
Have loose handle on electrolux icon microwave. How to repair.
There is screws inside the door when you openi it so you tight them thats all
Sep 15, 2014 | Electrolux ICON Microwave Combination Oven
FMV156DCA Microwave starts on its own
Why not unplug it, and plug it in when you need it. It probably cant be mended for less than its worth! I suspect the timer is shot
Mar 08, 2014 | Electrolux Microwave Ovens
I need to change the interior light bulb in my Frigidaire over the counter microwave. The model # is FMV156DCA.
Good Morning Evelyn, thank you for allowing me to assist you!
Here are some simple troubleshooting tips to help replace the light bulb on your Frigidaire microwave, FMV156DCA.
    ·First, disconnect power to your microwave. This can be done by either unplugging it or at the circuit breaker panel.
    ·To release cover, remove the screw on the light cover (light cover may become very hot, do not touch glass when light is on).
    ·Remove old light bulb and replace only with equivalent watt bulb available from parts distributor or the manufacturer directly. Bulbs are also available at most hardware stores or lighting centers. Bulbs larger than 30 watts are NOT recommended.
    ·Close light cover and secure with screw removed in step 2.
    I hope this information proves to be helpful. If you have further questions, please do not hesitate to reconnect.
Nov 25, 2013 | Frigidaire FMV156DC Microwave Oven
The handle is loose on my icon microwave
Some of the handles have a cover like that you pop off and then there are the screws. good luck hope you have this kind.
Jul 17, 2012 | Electrolux ICON Built-In Microwave Oven
E30so75fps loose handle
Amanda,
You need to carefully try to remove the plastic frame around the outside edge of the inside of the door and hopefully that should expose the screws that you need to tighten for the handle. I say carefully because that frame can be very expensive to replace if you break it. It is currently listing on Sears site for $95!
Jun 06, 2012 | Electrolux ICON Microwave Combination Oven
Fmv156dca buzzing loud
This is a strong indicator the magnetron is going to fail, and it is a matter time.
Apr 12, 2012 | Frigidaire FMV156DC Microwave Oven
How to fix loose handle on Electrolux TINSEB4225MRRO
you must open the door in two parts, for that unsrew the screw from the door sides, remoove carfuly the isolation and screw the handle.
Feb 20, 2010 | Electrolux ICON Microwave Combination Oven
Handle on Frigidaire Microwave broken, probably because of heat from gas burner below - this is a defect becaquse the microwave oven was manufactured to be built-in above range. Frigidaire has finally...
im kinda confussed as to why Frig would do that,,,
but if you send the model number im sure we can help
most times repacing the door is really just a matter of lifting it off the pin hinges after you have removed the vent
but i can be more clear with the exact model
Oct 28, 2009 | Electrolux Microwave Ovens
Microwave Ovens Logo
228 people viewed this question
Top Electrolux Microwave Ovens Experts
William Miller
William Miller
Paul Bade
Are you an Electrolux Microwave Oven Expert? Answer questions, earn points and help others
