Question about Hotpoint FFA60 Bottom Freezer Refrigerator
Freezer high temperature indicator light stays on
I have hotpoint fridge freezermodelnoFFA64 .High freezer temperature light has come on for few days &food is partially defrosting.fridge section is apparently working fine.Any solution please?
  • 290 Answers
SOURCE: Food is defrosting in my hotpoint frost free fridge/freezer
Can you hear the compressor running? Is the fan inside the freezer running? It could be that a wire connection has come loose during the move. Was the fridge laid on it's side during the move? If so you probably have compressor oil restricting the refrigerant system. If compressor and fan are running you will probably need a qualified refrigeration tech to check it out.
Posted on Oct 03, 2007
  • 17 Answers
SOURCE: fan not working on fridge section of Hotpoint Fridge Freezer Model FFA90
the problem is there is a build up of ice insid of the freezer .
What you need to do is take out all your draws in the freezer and you will see a plastic backing held on with about 8 screws . undo all the screws and the back should come aay and you will see all the ice built up . just use a hair drier to melt the ice and that should cure your problem.
Posted on Dec 10, 2007
SOURCE: Hotpoint FFS70 fridge/freezer
water keeps appearing beneath salad bin we have checked to see that nothing has come into contact with back wall of fridge ,and we have used a straw to keep the defrost gutter drain hole clear but water still appearing beside gutter drain hole .
Posted on Mar 02, 2008
  • 538 Answers
SOURCE: Hotpoint Fridge freezing the food.
thermostat is buried behind the walls of that unit, are you ready to run this one..takes quite a bit of time..but
will get the item, if you can supply the actual serial number from inside or back of that unit..
Posted on Oct 26, 2008
SOURCE: Hotpoint Mistral Frost Free Fridge freezer - fridge not getting cold
We have just had to call out an engineer to get our 1 1/2 year old Hotpoint Graphite Frost Free Fridge Freezer repaired. The fridge had almost entitely stopped cooling even when on high. I was amazed at how easily the problem was sorted. The engineer removed all the basktes from the freezer to access the screws on the inside backpanel of the freezer. Once this panel was removed it was clear that the so called Frost Free doesn't really mean what it says. The ice need to be melted with a bit of simple care. It is obvious that with a bit of care it is easliy a diy job BUT PLEASE BE CAREFUL AND READ THE NEXT PART BEFORE YOU BEGIN TO REMOVE THE ICE> The ice forms around variouys pipes etc and he usecd a screwdriver to help release the ice quicker than waiting for it to defrost and he also used a simple hairdryer to help speed up the process. He had a ntowel and a basin to take care of the water. Next time I would have no problem doing this myself but I would need to leave it a little while to defrost and NOT USE A SCREWDRIVER as I am sure somehow I would puncture a pipe or the wall of the freezer itself and I am quite used to doing the odd bit of DIY. On a difficulkty scale of 1 to 10 with 10 being difficult I would rate the job as about a 3. Hope this helps anyone who reads this about £70.
Posted on Dec 27, 2008
I have a hotpoint freezer fza34 The red high temp
it could be that your fridge,freezer setting is not turned up high enough to keep the freezer cold enough.turn it up to setting number 5 at least and if that dont do it u could have a faulty thermostat.have it checked by a engineer.
Oct 30, 2013 | Freezers
Freezer high temp light is on. So is fast freeze. It's been plugged in at least 24 hours but not freezing.
Mar 11, 2011 | Hotpoint FFA70 Bottom Freezer Refrigerator
Hotpoint rfs60 high temperature light staying on but freezer still works although maybe not to full potential
Had the same problem with the same model fridge, had to get the engineer out from hotpoint said it was the gases and their was a blockage in it. could not be fixed.
Jun 19, 2009 | Hotpoint RFS60 Bottom Freezer Refrigerator
Hotpoint fridge freezer green and red light on, switch offering 0
It could be a few problems to do with electrics, but try this first:
Red light on for High Freezer Temperature Warning
or freezer not cooling, but fridge is and a lot of noise from compressor.
Also, fridge drain hole blocked, water in bottom of fridge.
This is a common fault in Hotpoint Fridge Freezers and can also happen if the door has been left open or has been a power cut.
1. Turn off fridge freezer, or at least turn down the freezer temp to minimum, though not ideal.
2. Open freezer door and remove all drawers.
3. Remove the back panel on the inside of the freezer. This is held in place with 4 screws, which might be 6mm hex head or star allen head. Pull the panel out.
4. Behind where the panel was, there is a cooling element for cooling, pipes, and below this a temperature sensor. If the fridge freezer is not switched off, then fold together a few layers of tinfoil and wrap around the sensor.
5. Use a hairdryer to slowly melt the ice. Melt it around areas where it appears to be hanging on, such as the corners of the cooling element or bolts, as well as any thin sections below the main block of ice around the cooling element, which will be supporting the main block. Use a plastic ice scraper to remove ice but not near pipes or sensor.
Warning: Be careful using electrics around water & melting ice & drips.
6. Below the cooling element, there is a drip channel & drain hole. If this hole is full of ice, pour a small amound of warm water down, leave for 10 seconds and pour a bit more until clear.
In the fridge, clear the drain hole in the same way.
Warning: Do not pour a lot of water down, as this water drains onto a tray above the hot compressor at the rear of the fridge freezer to be evaporated by the heat of the compressor and the tray will only hold a small amount.
7. When all ice is removed, dry all moisture. Put the shelves back. Close door. Turn on fridge freezer. Turn up the freezer temperature to your normal setting. Turn on fast freeze if available. After 1 hour, check with a thermometer. It should be cold enough after 1 or 2 hours.
Dec 04, 2008 | Hotpoint FFA60 Bottom Freezer Refrigerator
Red light on Hotpoint Iced Diamond freezer
got a hot point iced diamond fridge/freezer, just got back off hols and red light on, all food defrosted with water running out of bottom. whats wrong?
Aug 27, 2008 | Refrigerators
Red light is indicating temp is too high, this can be caused by a variety of reasons.
You need to call an engineer to sort the problem out.
Jul 28, 2008 | Hotpoint 6.92 cu. ft. / 196 liter Upright...
Have a hotpoint rsf60 fridge/freezer,noticed over temp red light on, defrosted as ice buid up on top shelf of freezer.light still on red temp set at 3/4 ?
The red warning light will not go out?
1. Has the fridge freezer just been
installed? If so, this is normal and the
light will go out when the correct
temperature has been reached.
2. Has the fridge freezer been loaded
with a large quantity of food? If so,
the light will go out when the correct
3. Have the doors been closed
Jul 01, 2008 | Hotpoint Refrigerators
Sounds like frosting up. Defrost completely...that can take 2 days. Restart. Also, clean the condenser. Check door gaskets, clean and replace as necessary. Don't keep door open longer than necessary.
Dec 20, 2007 | Refrigerators
Hotpoint FFA60 Bottom Freezer Refrigerator Logo
125 people viewed this question
Top Hotpoint Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Sal De
Are you a Hotpoint Refrigerator Expert? Answer questions, earn points and help others
