Question about Singer 8280 Mechanical Sewing Machine
Emarading how can use emardaring the machine. plzs show me
E5 show in my screen keep on beeping
Look in you manual under messages it is some type of error message
Sep 21, 2015 | Singer 6180 Brilliance Sewing Machine
Elna problems
power the machine down and unplug and let set for 30 mins then try again, if that doesn't work then will have to be repaired
Sep 03, 2014 | Elna Xplore 8600 Computerized Sewing...
Bobbin winder on Pfaff 2170
sounds like the machine needs to be checked, since the bobbin icon
isn't showing up, could be something wrong with the computer
part of the machine
May 30, 2012 | PfaFF Sewing Machines
My machine shows FO4 message and none of the buttons are working for this message.
There are 2 things that cause the F04 error.
1 - Wrong foot control: If you have 2 machines, you might have them mixed up between machines.
2 - Burned out foot control.
Bring the machine to a Brother shop; try the new foot control on your machine before you buy it.
The part number is XC7290051
Alternative Part Numbers Include XC6651321, XC6651221, XC6651121, XA3931051, XC1154051 & XC6651051
Apr 16, 2012 | Brother SE-270D Computerized Sewing...
Screen won't show numbers on quantum 9910
it sounds like the computer part of the machine needs to be check at a sewing machine repair shop
Jan 20, 2012 | Singer Quantum 9910 Computerized Sewing...
Bernina Deco 650 Check if upper or lower thread is cut shows on
turn machine off and on to see if message clears... not sure for that machine ( I work with Brother products) but if it has a wiper (small hook shaped blade) that trims the tread automatically it may be stuck in the extended position
Apr 08, 2010 | Bernina Bernette Deco 600
Stitching tension
hi,
different fabrics and layers has diferent set up on threading. try cotton fabrics w/ thread tension of #3 to #4 and stich # 8 to #12.if you change fabric and layers gradual setting on dial tension should be done until you acquired the good set up.have a nice day.regards
May 29, 2009 | Singer 8280 Mechanical Sewing Machine
Sewing machine
Simple solution..
take the thread off your machine, set your tension to the middle setting. rethread your machine up to the needle. before threading the needle, put your presser foot down. If your thread pulls hard, then the machine is threaded right. If it pulls easily, you need to chead the thread thru the tension wheel.
Kelley
Rule of thumb.
Loops on the bottom, problem on the top.
Loops on the top, problem is on the bottom.
May 02, 2009 | Singer 8280 Mechanical Sewing Machine
How do you thread a SInger Sewing machine 2623
hi! there,
you can show some actual bobbins winder and threading go to internet explorer and type the address of "www.youtube.com" then on search type "sewing machine".there is a slide show for sewing instruction.just click the slot and it play the video showing what you want.regards don' t forget to rate me.
Apr 09, 2009 | Sewing Machines
Singer 8280 Mechanical Sewing Machine Logo
Top Singer Sewing Machines Experts
Tally Girl
Tally Girl
mystery_soul
Are you a Singer Sewing Machine Expert? Answer questions, earn points and help others
