Question about Garden
Karcher dirtblaster does not oscerlate the water.
I have purchased a second hand Karcher 4040 pressure washer, after a few months of use the lance failed to osceralate the water around and just stays in one position.
  • 3 more comments
  • rooville Mar 28, 2009
    I have the same problem with my dirtblaster lance on my Karcher K 2.91M. One day it worked fine, and the next time I used it it won't spin the water - just comes out in an angled stream. I've dismantled and cleaned the nozzle assembly, but no luck. My Karcher is only about 1 year old, but I've heard that these Karchers can wear out quickly and lose pressure. Maybe pressure loss is causing my problem?
    Any advice? Anyone?
    Thanks.
  • Anonymous Apr 06, 2009
    i HAVE EXACTLY THE SAME PROBLEM WITH TWO LANCES. The session starts with stop start working which cant to the pressure washer any good. The jet then slowed in rotation until fixed. Giving the unit a tap on the ground seemed to help
    The Karcher lances dont seem to last very long but are effective on paths and patios etc
  • scott1744
    scott1744 Jan 08, 2012
    I fixed mine after it had exactly the same problem. Firstly I unscrewed the head assembly and cleaned out the holes with fuse wire (which did not change the problem but eliminated one possible cause) - I then noticed a single o-ring on the white plastic assembly in the nozzle itself - there was only one o-ring but two grooves to support o-rings. I moved the o-ring from the position it was in furthest from the nozzle to the position closest to the nozzle and the lance is now working beautifully.
  • Thierry Mattea
    Thierry Mattea Jan 25, 2016
    Purchased my Karcher brand new with the Dirt Blaster nozzle. It worked fine the first 2 times I used, then the typical problem of no oscillation reared its' ugly head. After trying all the suggestions (solutions) mentioned below, I still couldn't fix it, which is weird since the nozzle could not have been exposed to enough wear and tear with just 2 uses. I figured i got a defective product (it happens from time to time), so I bought a new replacement oscillating Dirt Blaster tip from the local Karcher dealer for $40. Worked fine the first time I used then the same problem reappeared. Now I've given up on the damn thing. You pay a premium price and buy a German brand thinking you're buying quality and reliability and you end up with the cheapest possible product you could possibly buy. Karcher is a piece of ****. NEVER EVER BUY this brand if you value your hard earned money. A chinese pressure washer for half the price is 10 times more reliable, and in case it's not, at least you won't feel like you've been duped by false claims of unsurpassed German quality!
  • Patrick Rea
    Patrick Rea May 22, 2017
    A few drops of silicon lubricant on all moving parts does the trick, the stuff plumbers use for lubricating plastic pipes
    New Friend:
Stripped down the head of the dirt blaster by unscrewing the shaft from the end nozzle(it was quite tight). Removed the white disc from the nozzle using pliers and then cleaned out the 4 holes in the disc. Under the disc is an assembly which houses a ball bearing. I noticed that the ball bearing did not protude beyond the recess which houses it. I PUT TWO SMALL FIBRE WASHERS IN THE RECESS THEN REPLACED THE BALL BEARING. THEN REPLACED THE WHITE DICSC. Noting that the ball bearing protrude by approx 1/16th of an inch.
Re-assembled and the dirt blaster now works perfectly
Posted on Jun 20, 2013
  • 1 more comment
  • sujith reddy
    sujith reddy May 01, 2014
    holdden, i couldn't pass the first step itself....separating shaft from nozzle...its very tight ...can you help me with this ... i'm also facing the same problem ... thnkyou !!
  • Reyaz Amin Malik
    Reyaz Amin Malik Sep 27, 2014
    The procedure was hekpful, but there is another issue. Once the accessory is used, everytime it need to be removed from the handle and drained, otherwise it does not work as revolving. it seems the assembly inside gets water sealed. any suggession.
  • Jamie Mahoney
    Jamie Mahoney Apr 14, 2015
    To unscrew the nozzle use an adjustable spanner on the end that goes into the lance body and clamp mole grips to the knut shaped end of the nozzle body then twist.....hard.
Posted on Jan 08, 2012
  • David Hill Jul 26, 2012
    Thanks that helped. Where does the ball barring go? Dave Hill
  • Ed Fig Apr 05, 2013
    Did you get an answer? I am looking to find the diagram.
  • 14 Answers
The lance is either blocked or worn. Unscrew the end of the dirtblaster and ensure the is no dirt inside. If this does not work replace the lance assy.
Posted on Mar 06, 2009
Karcher 2500ph pressure washer spill valve has been replaced pull wand trigger pressure good for 3 or 4 seconds drops off for a second or 2 goes back to good pressure for 3 or 4 seconds drops off again for...
If you have a Karcher then you should always post your machines barcode.
full article on nozzles :
http://repairshed.blogspot.com/2013/09/pressure-washer-lance-nozzles-what-you.html
The spill valve operates at approx 20% higher than specified pressure washer operating pressure. If you have any lance issues then the pressure could be running higher than specified (machine running at same pressure as spill valve operation pressure)
your machine produces a fixed flowrate of water (maybe 8 litres per minute) and your nozzle is a fixed size. the diameter of the nozzle determines the back pressure. A piece of debris could further close your nozzle orifice and increase the back pressure. Using a new lance that has the wrong nozzle fitted can also cause this issue.
The karcher barcode is on a silver sticker and is usually 15 digits long. Example 156987400000123 is actually model 1.569-874.0 and serial number 00123....
Aug 15, 2013 | Garden
Hi I only have my Karcher 4040 a while now and already having problems. The water is getting to the machine okay but then spilling out onto the ground before it reaches the lance, hence no power.
The is a rubber washer in the piece that you screw the hose on to maybe the washer is cracked or flattened out. Try replacing the rubber washer. The washer is supposed to seal the hose connection to the machine.
Mar 27, 2011 | Garden
Oil is coming out of the lance end when in use . it doesn't come out all the time every 30 seconds or so . it comes out whether on hot or cold . karcher hds550c
sounds like the seals & o'rings are faulty.get the model number of pump and purchase a kit for the pump.replace all seals and o' rings.this will stop the oil from the pump going through the nozzle.
Jan 17, 2011 | Honda Karcher G2400HH-R Pressure Washer
Karcher Dirtblaster jet does not rotate
Had the same problem and it turned out to be an obstruction in the nozzle and I mean a small obstruction, it looked like an ant leg. I pushed a 1mm drill bit through and now it works fine.
Apr 13, 2010 | Karcher K2.26 Electric Power Washer
Honda 2400 psi before it went out i cold tap the end of the wand on the ground and the pressure would return now when pull the trigger there is no pressure only a fine spray .its a karcher with a honda...
hi,
there is a small ball bearing inside the nozzle on the end of the lance , this can get jammed or missaligned and the nozzle orifice can get blocked , clean this or replace the whole lance with another 200 Bar lance .
hope this helps
Feb 01, 2010 | Honda Karcher G2400HH-R Pressure Washer
Dear sir/madam I bought a kArcher model K3.97
Peter , sorry to say but there is no replacement parts for that lance , you just replace the entire thing
its called a Dirtblaster lance
Nov 08, 2009 | Karcher K2.26 Electric Power Washer
Karcher Motor Pulese On and Off
hi mark, you do have a problem with the lance.
you need to disconnect the lance and straighten a paper clip and insert down the nozzle end.
use the machine to wash the dirt in the nozzle backward down the lance.
Dirt only in nozzle end.
if still no good, purchase some nozzle cleaners and file out nozzle very slightly.
Jun 29, 2009 | Garden
No pressure on certain settings
Dear Osville,
It is not clear what type of lance or nozzel you have. You said that the machine works fine with the circulating water jet(the turbo). So it seems the machine is fine. I do sometimes service variable nozzels and variable lances. But the best solution is to replace nozzels and variable nozzles and lances with new ones. Regarding the fan spray setting it could have no pressure because it might be in the chemical setting. The chemical setting lets out a fan shape flow of water, but with less pressure. The chemical system only works on low pressure in domestic washers, that is why it needs a low pressure flat spray. The pencil jet has 2 jets comming out because if it is a lance or nozzel with ball bearings, these ball bearings must have stuck in a wrong position. Also 2 jets can come out, due to a damaged nozzel hole.
Altogether, the best advice is to buy a new nozzel or lance...which ever your machine uses. All Karcher machines have their own specific nozzels, lances and high pressure hoses. You cannot change these from one model to another.
Regards,
Fulltech.
Apr 29, 2009 | Alfred Karcher K 5.93 M Electric Pressure...
I have a Karcher 3.99 Pressure Washer. The motor appears to be working and water is passing through the machine when turned to the detergent application setting. However when the lance is tightened to turn...
Hi I have a karcher 3.99 the motor comes on and water comes out however thre is no pressure i have tested the lance on my brothers washer and this is ok what is wrong
Feb 21, 2009 | Karcher K 5.85 M Electric Pressure Washer
Garden Logo
16,145 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
