Question about Kenmore 62602 Electric Dryer
Kenmore washer series 90 top loader. stops after a few minutes, smell like an electrical burning. I reset it, works for a few minutes and stops.
    Problem Solver:
  • 19 Answers
Could you be overloading the washer, causing the motor to over heat?
Posted on Feb 21, 2009
I have a 90 series washer and I just changed the motor coupler. Now the washer emits a electrical burning smell. what can I do?
not proper fitting has been done so motor is jammed,,,not moved freely so the burning smell is from motor ,,,disamble & assemble properly,,,check brakes fitting also due to jammed motor
Mar 11, 2015 | Kenmore Washing Machines
Tip
We have a Kenmore 90 series hvy duty top loader, it works fine in wash cycle but...
This advice is for all Whirlpool manufactured TOP LOADING washing machines. This includes Kenmore, Estate and Roper models as well. This is an easy repair that anyone with a little know-how and determination can perform.
First of all, unplug your washer. You will need to remove the console in order to get to the lid switch. The washer may have release tabs under the console at each front corner. Simply slide a putty knife straight in from the front at each corner and push in while lifting up. You should feel the release tabs push in and the console will pop up.
If not equipped with this type of console, you may have a console that has removable end caps. They can be removed by gently prying up on the top of them from the rear on each side. You may have to use a small screwdriver for this. The caps should pop right off. Once removed, you will need to loosen a screw under each cap. Once you have the console loosened, carefully lift it up and lay it back over the rear panel of the washer in its resting position. Be careful not to damage the small plastic hinges that hold it in place. Now you will need to perform the following steps:
1. Under the console you will find the white plastic lid switch connector plug. Unplug the switch from the connector.
2. There will be two brass colored clips. You will need to remove these to remove the machine casing. Place a flat blade screwdriver straight down into the opening on top of the washer and into the groove of the clip. Push the screwdriver away from you while holding into the groove and the clip will release.
3. Open the lid of the washer and place your hand under the front rim of the opening (DO NOT grab the wash tub). Now pull the case from the frame by lifting from the back first.
You do not have to remove it all the way from the frame, just enough to gain access to the switch. All there is to the switch is a couple of screws holding it in and a ground wire. It's a pretty easy repair job. Some models will have the switch located on the right-hand side of the lid rim opening, while other models will have the switch located adjacent to one of the lid hinges in the rear.
Once you've completed your switch installation, make sure you get the case back on the frame correctly by following these steps:
1. While looking down through the lid opening, place the front lip of the machine case UNDER the washer frame and start leaning it back onto the frame. There are four small cleats that must fit into four slots on the case or the washer will vibrate. Make sure the frame is seated properly, lean forward from the front of the washer, grasp both sides of the rear panel and pull towards the case. The rear panel should be seated and flush with the casing before inserting the retaining clips.
2. Insert the brass-colored clips into the slot on the washer rear panel first (this is the end of the clip with the 90 degree bend), and then push straight down into the opening on the top of the washer with some force. If you have the case seated correctly, the clips will snap back in.
3. Make sure you plug the connector from the console back into the lid switch receptacle BEFORE you reassemble the console. This is easy to forget.
I hope this information is helpful..
on Jul 26, 2010 | Washing Machines
Kenmore series 90 washing machine clunking and burning smell
First, see the Sears parts site for your washer:
http://www.searspartsdirect.com/partsdirect/getModel!retrieve.pd?pop=true&modelNumber=110.26902691
See the section on the Machine Base.
There are a number of balance springs and vibration pads that help keep the tub from vibrating and going out of balance.
It's possible that one or more of these is broken, loose or damaged.
Following is a description of how to remove the cabinet to get access to them.
http://www.american-appliance.com/catalog/newsdesk_info.php?newsPath=16&newsdesk_id=135
Also see the Whirlpool Service Manual for their direct drive washers.
https://secured.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/f7e2147fa98b28cf85257122007475cb/$FILE/L-55.pdf
For the vibration, I'd check the springs and vibration pads.
While you have the cabinet off, I'd pull the pump and motor and check the Motor Coupler. This could be the cause of the "burning smell"
Nov 22, 2009 | Kenmore 24902 Top Load Washer
Kenmore 70 series top loader washer machine smells like its burni
you had the clutch coupling replaced sometimes i have noticed that the smell will last a few loads but no more than that
Apr 22, 2009 | Washing Machines
Kenmore 90 Series Washer
CHANGE THE LID SWITCH
Apr 18, 2009 | Washing Machines
Washer stops at rinse cycle-hums and has a smell.
Problem is with your lid switch which has to be replaced. This is if your filter is all clean.
Feb 28, 2009 | Kenmore 15864/15862 Top Load Washer
Washer works but smells like its burning.kenmore 90 series heavy
The burning smell could be the motor going out. When the water gets into the tub and makes it heavy it puts strain on the motor and the motor may be getting weak.
Feb 02, 2009 | Kenmore 24032\24036 Top Load Washer
Empty washer tub wobbles during spining, plus burning smell
BOTTOM OF TRIANGULAR PLATE ARE 3 SKID PADS, USUALLY WHITE OR BROKEN HALF MOON SHAPE WHEN WORN OUT RESULTS IN THIS
Nov 30, 2008 | Kenmore 24032\24036 Top Load Washer
Kenmore Series 90 Washer
Aside from complete disassembly & cleaning it, try a hot wash on full with nothing in it except a bunch of bleach.
Jan 09, 2008 | Kenmore 15864/15862 Top Load Washer
Kenmore 62602 Electric Dryer Logo
147 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal De
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
