Question about Hitachi WIP-5000 IP Wireless Phone
Hitachi WIP5000A - WPA firmware available?
I have a Hitachi WIP5000A currently upgraded software version v2.2.6 LA1 and bootrom v1.0.3.
Is there a latest firmware/bootrom available that will allow the phone to access WPA WiFi networks? I understand it might be version 2.5.4 but cannot find it anywhere, not the bootrom that may required with this software version.
It seems Hitachi are now discontinuing this phone, so not sure how long support will last, so keen to get it working on WPA as very pleasewd with the phone
Thanks
Steve Dunn
  • anthon Mar 22, 2013
    I'm also looking for the firmware but cannot find it anywhere.
5 Suggested Answers
  • 4234 Answers
SOURCE: Hitachi HDTV "no sound" or "no audio" OTA channels *SOLUTION*
Thank you for posting this. I will attempt to post this information in a more permanent place that can be found easily.
Thanks again,
Dan
Posted on Feb 10, 2009
SOURCE: My l32bd304 says i need
http://www.hitachiserviceusa.com:8080/L32BD304_ENG.pdf
Please find above your manual, inside here is all you need to know for now and any future references.
If that firmware upgrade box keeps popping up, I suspect that NO, the software isn't up to date? As usually it "Checks" to "See" if it is and only indicates to upgrade if it isn't,also if you do try to upgrade and it is current, the update simply will either do it over the top again, or upgrade so there is nothing to loose, so to speak.
I don't think you can "Turn the warning off" I think the only thing that will do this is an actual update?
You most likely would be best to simply follow the instructions in the manual and try to update the firmware, and see how you go. Most often Firmware upgrades only address certain "Problems" or additional "Features" that may have been added.
Posted on Jun 26, 2011
SOURCE: My Hitachi AV3000e Plasma tv is fine i think But
Hi. I'm having the same problem. Are there any other boxes available anywhere to replace the origional Hitachi one (AV 3000e) please contact anoteron_b@hotmail.com.
Posted on Jul 20, 2012
  • 48 Answers
SOURCE: Hitachi Hard drive DK23EB not readable -please help
Have you put the hdd from the laptop into slave mode, its on the back of the hdd, there might be a "jumper" that you need to reposition, failing that only insert the 1 hdd from the laptop and make it the only hdd, it should have an operating system on to run as normal. You can see the <jumper> on the right of this picture, you will need to connect both teminals (slave) with a little plastic jumper.
Posted on Apr 03, 2014
Firmware upgrade
Go to the D-link website to see if an update is available. Login to your router to see your current firmware version an hardware version. If update is available, download to your computer and upload to your router.
Jan 20, 2014 | D-Link AirPlus Xtreme G DI-624 Wireless...
Firmware won't update on magicolor 1690mf. pc can't find printer
Have a tech come out re-flash the copier OS. Firmware is only available thur secure web site
Dec 25, 2013 | Konica Minolta magicolor 1690MF All-In-One...
Superstack 3 3848 reset at default
Hi ! I think this solution should be approached. Because this procedure is the same for switches 3Com and HP A-series with Comware OS.
1. Connect light blue console cable between a computer (serial) and the 3COM switch (RJ45 console port)
2. Open PUTTY or Xshell or HyperTerminal with a serial connection and the following settings (19200, 8, 1, N) If not connected may use 9600 or 115200 bps
Starting......
* 3COM 2928-SFP Plus BOOTROM, Version 119 *
Creation Date : Feb 3 2010
CPU L1 Cache : 32KB
CPU Clock Speed : 333MHz
Memory Size : 128MB
Flash Size : 128MB
CPLD Version : 002
PCB Version : Ver.B
Mac Address : 002473959EC8
4. When "Press Ctrl-B to enter Extended Boot menu..." appears, press "CTRL+B"
Press Ctrl-B to enter Extended Boot menu...0
Please input BootRom password:
BOOT MENU
5. Press "7" to "Skip current system configuration"
1. Download application file to flash
2. Select application file to boot
3. Display all files in flash
4. Delete file from flash
5. Modify BootRom password
6. Enter BootRom upgrade menu
7. Skip current system configuration
8. Set BootRom password recovery
9. Set switch startup mode
0. Reboot
Enter your choice(0-9): 7
7. Press "Y" to skip the current config at next reboot
The current setting will run with current configuration file when reboot.
Are you sure you want to skip current configuration file when reboot? Yes or
No (Y/N):Y
Setting...Done!
8. Now Press "0" to reboot the switch
BOOT MENU
0. Reboot
Enter your choice(0-9): 0
9. The switch will reboot, allow it to fully boot this time
Starting......
CPU L1 Cache : 32KB
Memory Size : 128MB
Flash Size : 128MB
CPLD Version : 002
PCB Version : Ver.B
Starting to get the main application file--flash:/S2900-CMW520-R1101P09.bin!...
The main application file is self-decompressing................................
.........................Done!
System is starting...
Configuration file is skipped.
User interface aux0 is available.
10. Press "Enter", you will not need a password to login.
Press ENTER to get started.
<3Com Baseline Switch>
#Apr 26 12:00:16:292 2000 3Com Baseline Switch SHELL/4/LOGIN:
Trap 1.3.6.1.4.1.43.45.1.10.2.2.1.1.3.0.1<h3cLogIn>: login from Console VMadmin.co.uk
%Apr 26 12:00:16:461 2000 3Com Baseline Switch SHELL/4/LOGIN: Console login from aux0
11. Now type "initialize" to delete the configuration file and reboot the switch once more, Press "Y" to accept reboot.
<3Com Baseline Switch>initialize
The startup configuration file will be deleted and the system will be rebooted. Continue? [Y/N]:Y
Please wait...
#Apr 26 12:00:33:537 2000 3Com Baseline Switch DEV/1/REBOOT:
Reboot device by command.
%Apr 26 12:00:33:641 2000 3Com Baseline Switch DEV/4/SYSTEM REBOOT:
System is rebooting now.
12. The switch will full start up again, this time completely factory reset.
Starting......
CPU L1 Cache : 32KB
Memory Size : 128MB
Flash Size : 128MB
CPLD Version : 002
PCB Version : Ver.B
Startup configuration file does not exist.
13. Press "Enter", then enter the username "admin" and password "<blank>". Press "Enter" and you will be logged in.
Login authentication
Username:admin
Password:
#Apr 26 12:00:19:811 2000 this article is from VMadmin.co.uk 3Com Baseline Switch SHELL/4/LOGIN:
Trap 1.3.6.1.4.1.43.45.1.10.2.2.1.1.3.0.1<h3cLogIn>:admin login from Console
%Apr 26 12:00:19:981 2000 3Com Baseline Switch SHELL/4/LOGIN: admin login from aux0
14. If you type "summary" you will see all the switch details.
Amongst these details are the IP address of the switch. If you have DHCP on your network this switch is connected to it will receive one as in my case below, so I can now configure the rest via a web browser.
If not you can use the "ipsetup" command to set a static management IP and access via a web browser.
<3Com Baseline Switch>summary
Select menu option: Summary
IP Method: DHCP
IP address: 192.168.1.250
Subnet mask: 255.255.255.0
Default gateway: 192.168.1.254
Current boot app is: flash:/S2900-CMW520-R1101P09.bin
Next main boot app is: flash:/s2900-cmw520-r1101p09.bin
Next backup boot app is: NULL
3Com Corporation
3Com Baseline Switch 2928-SFP Plus Software Version 5.20 Release 1101P09
Copyright (c) 2004-2010 3Com Corp. and its licensors. All rights reserved.
3Com Baseline Switch 2928-SFP Plus uptime is 0 week, 0 day, 0 hour, 1 minute
128M bytes DRAM
128M bytes Nand Flash Memory
Config Register points to Nand Flash
Hardware Version is REV.B
CPLD Version is 002
Bootrom Version is 119
[SubSlot 0] 24GE+4SFP Hardware Version is REV.B
15. Once you can access the web management page for the switch make sure you set a strong password for "admin" and store it in a secure encrypted location for next time.
16. Don't forget to save your new configuration! Otherwise the switch will be at factory defaults if the power goes off!!
Jul 24, 2017 | 3Com SuperStack 3 3848 48-Port Gigabit...
Hi please tell me how to unlock nokia 6500 slide
you can try to check if theres any updated software/firmware for your 6500. you can check that from this website:
http://europe.nokia.com/support/download-software/device-software-update/can-i-update
then enter the code which is located at the back of your phone.
you can check the your current firmware by typing *#0000# from the standby screen
NOTE: PLEASE MAKE SURE TO BACK UP EVERYTHING BEFORE UPGRADING YOUR SOFTWARE/FIRMWARE
if it shows that theres a latest software version than the current version of your phone then upgrade your software using Nokia PC Suite. then it will reset your security code and settings.
Aug 22, 2010 | Nokia 6500 Slide Cellular Phone
Firmware
Hello jagancs1,
The Belkin Router's software (firmware) can be occasionally updated. To check for new updates, go to the Belkin Router Setup page http://192.168.2.1/ . The following choices will appear to update firmware and save current settings:
•Select Firmware Update (Near the bottom of the left-hand panel)
From time to time, Belkin may release new versions of the Router's firmware. Firmware updates contain improvements and fixes to problems that may have existed. Click the link below to see if there is a new firmware update available for this Router.
•Firmware update Options:
Firmware Version > #.##.##
Check for New Firmware Version > [Check Firmware]
Update Firmware > [Enter file name/Browse]
[Update]
•NOTE: Please backup your current settings before updating to a new version of firmware. Click Here -> http://192.168.2.1/system_c.stm to go to the Save/Backup current settings page.
•Save/Backup Settings
You can save your current configuration by using this feature. Saving your configuration will allow you to restore it later if your settings are lost or changed. It is recommended that you backup your current configuration before performing a firmware update.
*Saved File name is user.conf*
If this solution is helpful please click a thumbs-up rating below.
Have a great day,
martyshaw152
Jul 04, 2010 | Belkin (F5D7230-4) Router (587009)
My Hitachi 55VS69A has an upgrade slot, did Hitachi ever produce one for this model TV?? If so, where can a aquire one?? Thanx Mark
DTV version 0109.0001 was the last version released. You should contact Hitachi if you need it, as it appears to be only available to servicers (I didn't see it on the customer website anyway... double check it you like). They should be able to mail it to you with instructions on how to install it. However, if you are not having any issues with the product, there really is no need to upgrade the TVs firmware. This update will not give you any added features.
Mar 15, 2010 | Televison & Video
We have a Hitachi 42hds69 tv no picture but have sound. I have sound and picture on most channels, but on 2 digital channels, I have beautiful picture, but no sound. help!!
Here is what you need to do to fix this. Call Hitachi Global Storage Technologies & request for the firmware upgrade.
1-800-HITACHI (448-2244)
They will send it to you for free. You get a small SD card that plugs into the back of your TV just below the Cable Card Slot. I wouldn'd have known it was there unless the instructions in the mail packet told me so.
To determine if you need to upgrade go Into the Setup Menu. Then, Go to Software Upgrades & look at the software version. I had 0110.xxxx. the version I upgraded to was 0125.0000 & it fixed the audio problem on 7-1 & 11-1.
now all channels work great.
THANKS HITACHI!!!
Mar 18, 2009 | Hitachi 42HDS69 42 in. Plasma Television
UPGRADE MY HITACHI
Go to MENU>SETUP>UPGRADES. Jot Down Your Software version. Call Customer Support at (800) 448-2244. Give them your current software version, Model number, and TV Serial Number, and they will tell you if you need upgrade. If upgrade needed, they will mail out MMC card with instructions for upgrade.
Mar 18, 2008 | Hitachi 65S700 65" Rear Projection HDTV
Firmware upgrade to GE-Thomson 28310 2 in 1 Skype/Landline phone
You must leave the handset in the base charger. Otherwise it would not complete.
Feb 29, 2008 | Lands Phones
Getting The WRE54G To Connect With The WRT54G
The WRT54G, WRT54GS, and WAP54G all must have the latest firmware versions available installed in order to connect with the WRE54G Wireless-G Range Expander. Here are the minimum firmware version requirements that you must meet: * WRT54G (all versions): at least firmware version 2.02.2 * WRT54GS: at least firmware version 2.07.1 * WAP54G (all versions) : at least firmware version 2.07 To Identify your WAP54G Version Number: To find out which version of the WAP54G you currently have, flip your Access Point over to look at its underside. Near the serial number label, near the Linksys© logo, you will see your model number and a possible version. Labels for the WAP54G version will look like one of the following: * WAP54G (no version means Version 1) * WAP54G ver. 1.1 * WAP54G v. 2 For WAP54G Version 1 and Version 1.1 Users ONLY: (if you have a WAP54G Version 2, you may proceed with the 2.07 or later firmware upgrade) NOTE: Before upgrading the WAP54G Version 1 and Version 1.1 models to firmware version 2.07 or later, make sure your Access Point?s current firmware is version 1.09.1 beforehand. The version 1.09.1 code performs an important OS upgrade for these versions of the Access Point -- it must be loaded before using later firmware.
Feb 16, 2006 | Linksys (WRT54GC) Router
Hitachi WIP-5000 IP Wireless Phone Logo
375 people viewed this question
Top Hitachi Computers & Internet Experts
Alun Cox
Are you a Hitachi Computer and Internet Expert? Answer questions, earn points and help others
