Question about Pioneer DVR 108 Dual format 16X DVDRW Burner W/"-"&"+" (ATAPI) BARE DR. (MXDVDR) Burner
Hp laptap pioneer CD wont play
I have a HP pavilion dv4-1125nr laptop with a pioneer DVDRW DR-TD08HB player and the CDs wont play. the laptop doesnt recognize the CD
  • ryx18 Mar 05, 2009
    hi! it worked! thanks:)
I had the same problem. Go to the link below and follow the directions. Don't worry if you don't have a lower limit directory. I didn't and it still worked. Before restarting go to the device manager and uninstall the driver. I have a similar computer to yours and when I restarted it automatically reinstalled the driver.
http://support.packardbell.com/uk/item/index.php?i=topic_02125&ppn=PB42B00901
Posted on Mar 03, 2009
My pioneer dvdrw dr-td08hb ata in my HP pavillion is not burning anything, I try changing the blank cd and dvds brand and also empty out most of my hard drive, try uninstal and reinstal it again and still...
If your not a PC guru then try removing DVD from device manager and reboot
if your a geek try editing your registry and remove the upper and lower filters from this HIVE HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Class\{4D36E965-E325-11CE-BFC1-08002BE10318}
Aug 25, 2010 | Pioneer DVR 108 Dual format 16X DVDRW...
Why my dvdrw dr-td08hb appears in my safely remove harware option, how can i make it not appear to be removed?
Most of your hardware (if not all) appears there why would you want to remove it?
Aug 23, 2010 | HP Computers & Internet
I have an Hp laptop with a pioneer dvdrw dvr k17b not burning.
dies your burned this work on your PC? if it works on your pc you just have to select the correct settings for your burning software, when you burn does it ask you to burn multiple sessions? if it does and you selected the option create multiple session then what will happen is the disc's you burnt will only work on your windows and not on any other computer or devices that use dvd's or cd's, on the options it will also have a choice for you to choose single session only wherein this will allow you to use the burnt disc in any other computer and will most likely work 100% of the time ^_^ NOTE: this step I gave all depends on the software you use to burn your disc and you may be required to play around your software for some softwares do not have the same info in them but at time be the same in thier function and purpose ^_^ I just based this answer to your question using my NERO
Jun 06, 2010 | Pioneer DVR-107D DVD±RW Burner
My DVDRW DR-TD08HB ATA Device is uninstalled i need to install it but cann't do it
Go into your device manager. (Right click my computer, properties.device mgr. hardware) Find the device and enable it.
Sep 21, 2009 | HP Pavilion dv4000 Notebook
Pioneer DVDRW DR-KW08HB ATA Device driver issues
To me that sounds like something got corrupted with Windows, if you have a restore CD, or know how to reinstall your OS I would recommend that, AFTER you back up your files though as you will lose anything you had saved on there. But that could fix it, or it could be the drive is bad also.
Sep 09, 2009 | HP Computers & Internet
Pioneer DVDRW DR-KD08HB not working on HP Pavilion Solved the problem once from fixya and now the problem returned. Anyone??
You should really give more detail on the issue for people to solve the problem quicker. If you can't see the dirve on your drive list but it show up under device manager and getting error 39 you can try the following link.
http://msbin.com/kb/entry/53/
Sep 08, 2009 | Computers & Internet
PIONEER DVDRW DVR-K17B ATA Device Issue in HP Pavilion DV9500 Lap
you may need to clean the lens of drive with a wet tissu paper, otherwise the drive might gone out of order, need replacement.
Feb 10, 2009 | Pioneer DVR-107D DVD±RW Burner
DVD RW DVR-K16 does not recognize blank DVD-R
I have a Pioneer DVDRW DVR-K16, in a sony dv81114Notebook. Running Windows XP. It cannot play dvd's and cd's, It will recognize blank CD-R's but when I insert a DVD-R it say's no disc installed. I have firmware version 1.15.
Nov 26, 2008 | Pioneer (DVR-K16) DVD RW Dual Layer Burner
Computers & Internet Logo
1,233 people viewed this question
Top Pioneer Computers & Internet Experts
Computer Links
David
David
Are you a Pioneer Computer and Internet Expert? Answer questions, earn points and help others
