Question about RCA Televison & Video
I have an old RCA F2763OSF. I don't have the original remote as I use a Verizon box. I can't get the TV on channel 3. It jumps from 2 to 4. There was brief power outage. How do I get back to channel 3
  • 4,234 Answers
Siest way is to be sure that there is a signal for channel 3 (cable box) and then engage the autoprogram feature. You should be able to do this from the front panel.Once the autoprogram is complete, channel 3 should again be available.
Posted on Feb 20, 2009
Sansui dtv2798
use a av cable ( rca cable ) and then select the av input
Jun 22, 2013 | Televison & Video
I don't have a remote control for my RCA TV and it's on channel 2. It needs to be on channel 3 so that It's compatible with my cable box. How do I change the channel without a remote to channel 3. It
U should have a menu button on your tv.If so try to find the channel setup option if you find this you should b able to manually go through your channels to add & delete the channels you want.If not you will have to go out a buy a universal remote.Make sure that it is compatibl to your tv.They should be a list on the back of the remotes pack stating all the brands that the remote is compatible with.I think you should be able to get one for unde 5 the pack it should have an instruction manual.some tvs u can set up very easily & some you might have to keep putting in different codes until it works.Hole this could be some help to you.Good luck.
Apr 19, 2013 | Televison & Video
I cannot get the TV or the remote to move to channel 3 to access cable, any ideas? The menu screen will not come on.
You are using the tv original tv remote?Yes,push the buttons on the remote that said like VIDEO or INPUT see if u can get in a tv screen like video 1 or 2.Yes,than you can get your pay cable tv go through video outputs 1 or 2.By using a RCA cable Y,R,W plug plug in one end to the tv IN Holes like Y,R,W and the other end of the cable Y,R,W to the cable box OUT holes Y,R,W.If your tv is too old, that don't even have VIDEO INPUT 1 and 2 for basic VCR and DVD players hook up.It 100% time to upgrade your tv because your tv is out dated and extinct as a DO DO bird.
Nov 17, 2012 | RCA G35831AT 35" TV
No channel 3, the tv goes from channel 2 to 4, can't use the cable box
Two options...
1. Connect the Cable Box via RCA cables (Yellow/Red/White) or Component cable if you have a HD cable box and select the appropriate input on the TV to view your programs. This will provide the best picture quality as well.
2. Make sure the cable box is on. Using the original TV remote type in the channel 03 and if this tunes to the channel then go to the TV menu and then go to Set up and then select add/erase and select add.
If typing 03 did not tune in channel 3 then using the TV remote select menu then go to set up and then make sure TV / Cable is set to cable then on the cable box press the channel button a couple of times and then select auto program on the tv.
Jan 03, 2010 | Toshiba 27AF44 27" TV
What channel does the TV need to be on to watch a
If your tv has input [rca connections] jacks, look at the original remote and use the input button.In some cases....pressing 00 on the remote will access an input. If you must a converter box...set your tv and the DVD player to channel 3.
Dec 25, 2009 | RCA F27442 27" TV
Need 1992 Remote Control For RCA ColorTrak TV Set
Tries 1-800-Factory remotes originals Website.
U get same as the original remote.
Aug 17, 2009 | RCA F27450 27" TV
Set up digital set top box
Either tune your TV to channel 2 or 3 or (on some TV's) to 91.
Then, connect the COAX-output from the set-top-box to the COAX-input on your TV, or connect the "output" Red/White/Yellow RCA-jacks on the set-top-box to the Red/White/Yellow "input" RCA-jacks on your TV.
Apr 23, 2009 | Toshiba Televison & Video
Magnavox with pic tube tv skips over channel 3..goes from 2 to 4
You are right about the auto-programming, but Magnavox no longer has the original remote.
For my answer to be right, you must have posted this question to the EXACT CORRECT model # of your Magnavox TV - 27ms343s:
Press TV on your Verizon remote, and then press "0" and "3"
If that fails:
Press MENU to see the TV’s on-screen
menu. In the menu, use VOL.+/_ and
CH.+/_ to make adjustments or selections.
You can press MENU on either the
remote control or the front of the TV to
access or remove the menu.
Jun 14, 2008 | Philips Magnavox 27MS343S 27" TV
Can't get TV onto the AUX channel
You can purchase an RCA universal remote that will let you access the A-V inputs. These only cost about $10.00 or so. Stargazer
Sep 09, 2007 | RCA F25254GY 25" TV
i have the same set i used a rca universal remote rcr311w i think its the oem one i bought two of them at walmart i don,t know if they still carry them
Sep 09, 2006 | RCA T13208 13 in. TV/VCR Combo
Televison & Video Logo
44 people viewed this question
Top RCA Televison & Video Experts
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
