Question about Canon PowerShot A430 Digital Camera
Have lost manual for canon power shot A400 tried to insert new memory card (scan disc SDHC card 4gb) it it comes up with an error reading on camera screen? Thank you in adv for any help.
  • 1 more comment
  • vjsilver Feb 22, 2009
    It just says memory card error. Thanks....
  • vjsilver Feb 23, 2009
    ahh, thank you for that, I will go back and pass that on to the guy at the shop that sold me the card. It is a lovely camera. Thank you for your fast answer.
  • Rob
    Rob May 11, 2010
    Hi there. What error reading are you getting? What does it say?
  • Canon Master
  • 4,738 Answers
Love the A400, it's one of my all-time favorite Canon P&S cameras. But sorry to say your camera will not understand SDHC cards. This format came out well after the A400 was designed. The max memory the A400 can use is a 2GB standard SD card, no higher. Fortunately, these are very inexpensive these days, and run about $6 with shipping:
http://www.amazon.com/s/ref=nb_ss_gw?url=search-alias%3Daps&field-keywords=sd+card+2gb&x=17&y=26
The user manual may be downloaded directly from Canon here:
http://gdlp01.c-wss.com/gds/0900001151/PSA400CUG-EN.pdf
And the quick start guide can be downloaded here:
http://gdlp01.c-wss.com/gds/0900001155/PSA400QSG-EN.pdf
Posted on Feb 22, 2009
I have a Canon A400 that is displaying the common 'memory card error' message. I've been through most of the tricks that I've found on the Internet but still no success. Tried multiple memory cards,...
There are several possible causes for "memory card locked", "memory card error", or "no memory card". The most common is trying to use a 4GB or higher SDHC card with an older camera made before SDHC format came out. Other causes include problems with the tiny slide switch on the side of the card, or the electrical contact switch internal to the camera. The problem may also arise from simple formatting problems if the card has never been formatted in the camera (note that this will also erase the card). Troubleshooting tips for this problem may be found at this link. By the way, if you are indeed using 2GB or less cards (as you should be for your older A400), then give the toothpick fix a try listed in the above link.
Mar 05, 2011 | Canon PowerShot A400 Digital Camera
I have a Canon Power Shot A520 and have just put in a new memory card 4GB and new batteries. When I turn on camera is says memory card error at the top of the sceen. Why is that?
The A520 is designed to work with SD cards. Your 4GB card is actually an SDHC card. While it fits into the slot, it is electronically incompatible.
You need to use SD cards 2GB and smaller.
Oct 05, 2010 | Canon PowerShot A520 Digital Camera
Camera say no meomory card
There are several possible causes for "memory card locked" or "memory card error". Some include trying to use of a 4GB SDHC card with an older camera made before SDHC format came out. Others include problems with the switch on the side of the card, and the switch internal to the camera. The problem may also arise from simple formatting problems if the card has never been formatted in the camera (note that this will also erase the card). Troubleshooting tips for this problem may be found at this link.
Jun 06, 2010 | Canon PowerShot A400 Digital Camera
How do you unlock the memory card
If your using an SD card you might need to slide the lever on the side of the actual memory card itself. The little lever is a hardware lock that prevents it to be written to or files to be deleted from it.
Apr 10, 2010 | Canon PowerShot A400 Digital Camera
When i insert 4gb memory card into canon power shot s21s, camera is disabled. cannot take pictures
Your new 4GB memory card is the problem. The card would likely be an SDHC card (look on its front cover). Your A540 camera was designed well before the SDHC format came out, and your camera will not recognize it. Your camera can only use standard SD cards (2GB or less). Here's some from Amazon.
Feb 14, 2010 | Canon PowerShot A540 Digital Camera
New digital memory card inserted and camara reads memory card error
1. Try to format your memory card using a PC/Laptop.
2. Now, insert it in camera and check whether its working!
please rate this advice if it helps....tc! :)
Jan 02, 2010 | Canon PowerShot A530 Digital Camera
Loaded new memory card, and screen reads memory card error-memory card locked. Removed new card from camera, nnlocked card, inserted card again, but received same message. Please advise.
I'm guessing you bought a new 4GB SDHC card. Although it looks exactly the same as a standard SD card, the format the card uses is very different. If your camera is more than a few couple years old, it's likely it was designed before the SDHC format came out. Sorry, but a SDHC card will not work with older cameras.
For older cameras, you'll need to use standard SD cards (usually those 2GB or less). But if you really want to use a 4GB card, do a Google search for 4GB SD "non HC", with the non HC in quotes. Believe Transcend makes one.
Dec 25, 2009 | Canon Cameras
Inserted new memory card error message:memory card error unable to access format under menu
I'm guessing that you bought a new 4GB SDHC card. Although it looks exactly the same as a standard SD card, the format the card uses is very different. Unfortunately your camera was designed before the SDHC format came out. Sorry, but a SDHC card will not work with your camera.
You'll need to use standard SD cards (usually those 2GB or less). But if you really want to use a 4GB card, do a Google search for 4GB SD "non HC", with the non HC in quotes. Believe Transcend makes one.
Nov 07, 2009 | Canon PowerShot SD630 Digital ELPH / IXUS...
Canon Power Shot A400 will only work with original Canon SD card
Make sure you are using an SD card and not an SDHC card. The SDHC protocol is newer than your camera, and your camera does not support it. SD cards have capacities up to 2 GB. Your camera should work properly with any SD or MMC card.
Apr 22, 2009 | Canon PowerShot A400 Digital Camera
Message: Memory Card Error - Memory Card Parameter Error on 4gb SDHC card
I have been rummaging around trying to find two solutions: 1) to get my Toshiba Satellite card reader to read SDHC cards and 2) to get my desktop USB ports to read SDHC cards. While MS offers a hotfix for XP, it does not always work because of the different Chip Sets in computers. I have also read where posters say that the SDHC card works in the compter NOW, but NOW will not work in the camera... and the SDHC card NOW works in the camera but will NOT work in the computer.... I found a tekkie article that may help clear the air... SDHC cards are formatted in Fat32x (NOTICE the "x") and SD cards are formatted in Fat32 (no 'x') and these compatibility problems arise when the user unwittingly or unknowingly RE-formats the SDHC card, either when it is put in the computer and won't read or when it is put in the camera and won't read... but just don't bother to mention that THAT is what they did upon inserting the card and only proceeded to complain about an apparent incompatibility. The camera or computer might even mislead you asking if you want to format the card..... but all is not lost. The Panasonic site gives a program AND a pdf instruction book on How To ReFormat an SD or SDHC card specifying the proper Fat32x or Fat32 format. Hope this helps.
Feb 16, 2008 | Panasonic Lumix DMC-FX01 Digital Camera
Canon PowerShot A430 Digital Camera Logo
240 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
