Question about HP Computers & Internet
Error code 90
Please,
I have a error code A0 followed by a error code 90. I have tried to open the case and uninstall e reinstall each carrier on the autoloader belt. But it did not solve the problem. Any suggestion?
thanks,
Rogério
I have the same problem with HP StorageWorks ultrium autoloader 1/8. Same error codes "A0" and "90". Dismounting the case and removing tapes and cartridges, then placing them back did not resolve it. I wonder if this could be a problem of the mechanical sensor?
  • HP Master
  • 1,892 Answers
NO PC stated, it has a HP name, like DV6-12345,
no OS stated, XP , w7 , w8 or w10. we can not guess OS, ever.
start a post by telling the helper what is in your hands.
we cant look for you, you must tell it.
tapes, sounds , RELIC for sure...
Posted on May 09, 2017
2 Suggested Answers
  • 19 Answers
SOURCE: HP StorageWorks 1/8 Tape Autoloader
The library picker arm cannot move to the home position. There could be something blocking it. Try the Reset option from the Configuration menu. This is detailed in the library user guide.
Posted on Jan 14, 2011
How to fix 59.A0 AND noise from the fuser unit on hp color laserjet 9500mfp
I would suggest the drum unit or the toner cartridge was not reassembled correctly. Do it again.
Apr 10, 2016 | HP 4G1-1483-000 Hewlett-Packard Color...
X2580 not printing. Have uninstalled and reinstalled but it comes up with the realign box but doesn't print it then it asks you to put it under the glass but can't ofcourse because it hasn't...
The problem could be due to the cartridge/s in the carrier or the carrier has stalled. Please follow the steps below to fix the problem:
  1. Open the printer cover and remove the cartridges.
  2. Check the cartridge area for any debris or foreign objects blocking the cartridge carrier. Check the encoder strip (transparent strip behind the carrier) and make sure it has gotten unseated from its position.
  3. If the cartridge is clear and looks normal, close the printer cover.
  4. Unplug and re-plug the printer into the power source to reset it.
  5. When the printer turns on, check for any error. If "alignment" error appears again, please contact Lexmark Technical Support Center for additional assistance. If no error appears, reinsert one cartridge first.
  6. Close the printer cover and check for errors.
  7. If no error appears, reinsert the other cartridge.
  8. Replace whichever cartridge is causing the error to appear. It could be a faulty cartridge. You may also try to insert a different known working cartridge to determine if your other cartridge is faulty.
If problem continues, please contact Lexmark Technical Support Center for additional assistance.
Aug 10, 2011 | Lexmark C533DN InkJet Printer
Our dell powervault 122t shows error code A0
Error Code A0 - Error occurred during carousel movement (Position Not Found). Could be caused by a missing or misaligned cartridge carrier, or an obstruction, or unexpected cartridge in either the carousel path or Import/Export slot.
Remove the power cable and SCSI cables then try open the top cover. Check and see if there are any tape blocking or obstructing the movement. Sometimes it works sometimes it doesnt. I have 5 of these devices, few of them were replaced as its not working anymore due to these codes and as they are pretty obsolete, its not worth to repair them anymore.
Feb 03, 2011 | Dell PowerVault 122T LTO (pv122tlto)...
HP StorageWorks 1/8 Tape Autoloader SDLT 320 - tape library - Super DLT - SCSI Displayed Error! Code: A0 When you try to import or export are displayed error code 90
Jan 11, 2011 | Quantum ValueLoader SDLT 320 Super DLT...
IBM Autoloader 36232sx error code A027 & A060
A0= Error occurred during carousel movement (position not found). Could be caused by a carousel motor power issue, a missing or misaligned cartridge carrier, an obstruction, or an unexpected cartridge in the carousel path.
I also advise you to update the FW of the loader.
Are you having tapes get "Stuck" in the unit?
Feb 01, 2010 | IBM Computers & Internet
Carrier Stall is the error
Please do the following..
To check the cartridge carrier:
  1. Unplug the printer.
  2. Move the cartridges to the left by hand and then take them out.
  3. Try to print without the cartridges in the carrier. Do you still receive a Carrier Stall error message?
  4. If not, put the cartridges back into the carrier and snap them in at the back. The message should no longer appear.
If the power light on the printer is not blinking, the error message may be caused by a communication error. Do the following:
  1. Remove any other devices attached to the USB/LPT port.
  2. Uninstall the Lexmark printer.
  3. Connect the printer directly to the PC and ensure that power is being supplied to the printer.
  4. Reinstall the printer.
Thank you....
Jan 26, 2009 | Lexmark X83 All-In-One InkJet Printer
Euroxox codes leeds???
17:55 30/11/08
CW KEYS
5C 01
00=2F 1E 90 1B EA 7F A0 26
01=60 1F 48 73 19 D6 CA 99
TW KEYS
5A 01
00=B7 19 92 E2 9B 15 AF 96
01=C6 64 1D EF 47 5A 0E EF
PURE KEYS
54 01
00=5A 35 D6 3B 4D A0 75 EC
01=28 98 21 38 22 BC B9 EF
Nov 30, 2008 | StarTech.com StarView SV211K 2-port KVM...
Lexmark x83 carrier stall
http://support.lexmark.com/cgi-perl/knowledgebase.cgi?ccs=229:1:0:95:0:0&framed=&docid=ENUS22722&relevance=0
Use the above link to trouble shoot the problem.
Error: "Carrier Stall" ID:470
Feb 24, 2008 | Lexmark X83 All-In-One InkJet Printer
Uninstall & reinstall Lexmark X5150
open the control panel printer or fax add printer and setup it just follow the instruction.
Dec 28, 2007 | Lexmark X5150 All-In-One InkJet Printer
Adic faststor2
Try changing the autoloader SCSI ID and the tape drive SCSI ID at the front panel:
Use this option to view or change the SCSI IDs used by the autoloader. The autoloader occupies two SCSI
IDs, one ID is assigned to the autoloader and the second ID is assigned to the tape drive.
The default SCSI ID for the autoloader's SCSI controller is 0. The default SCSI ID for the tape drive is 5.
You only need to change a SCSI ID if there is another device, or devices, already assigned to these IDs.
NOTE: This option is primarily used if the autoloader is in an error state. However, any
backups that have not been verified as complete should be considered lost.
NOTE: If you changed the SCSI ID, you may also need to cycle power on the host
system and reconfigure your backup software before you can use the
autoloader. Consult your hardware and software manuals for more information.
Dec 27, 2006 | ADIC FastStor2 LTO (90024202)
Computers & Internet Logo
214 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
