Question about Moen 7437 Chateau Single Hole Kitchen Faucet with Side Spray Chrome...
Hello, I would like to know how can I open (unensemble) the kitchen faucet (it has some Leakage). Please, advise Thanks
  • Arthur Bayne May 11, 2010
    what brand & type offaucet is it?
    Problem Solver:
  • 9 Answers
Unfortunately, to disassemble the handle to remove the cartridge to resolve the leak can be tricky. And requires a few different tools to perform the task . Make some calls to "small" plumbing company to check prices on the job needed. And if way out of range, let me know and I will extensively run you through the steps to do it. But you will need some specialty tools and patience.
Posted on Feb 21, 2009
How do I disassemble a Kohler kitchen faucet
Remove sprayer and hose from faucet body.
Remove handle and cartridge.
Pull up on body.
Replace parts and reinstall in reverse order.
Aug 31, 2014 | Kohler Model 10433: Fort® Single-control...
Leaking Kohler Vinnata kitchen faucet.
you must use genuine kohler parts,if you got something from lowes or home depot that was some other brand they usually leak. also look for calcium build up inside the valve body,you can use 1500 grit wet sand paper to remove it just be carefull and dont sand too much,then apply water proof plumbers grease inside the valve body befor you install the new cartridge.
Nov 08, 2012 | Kohler K-690-VS Vinnata kitchen sink...
Just purchased a Ladylux faucet for my kitchen sink and want to know if there is any way to strengthen the water pressure (water stream). It is too weak for kitchen use. Please advise at your soonest as...
Do you have good water pressure in rest of house if not you may have to put a pressure booster system in. if you do there may be a water saver washer in the end of the hose on the faucet,you can disconnect the hose and if there is a washer with small holes in it you can take that out(you may have to put some type of hose washer back in the hose so it dosen't leak).
Jun 13, 2011 | Grohe Ladylux Cafe Faucet with PullOut...
I have a kitchen faucet that is leaking at the base where the faucet connects to the base. It leaks all the time. Do I need to replace the O rings in the stem of the faucet? Or do I need to replace all...
hi! if tightening the knob(s), (or if you apply pressure on the knob of the faucet,for the models with no thread for open/close), modify the amount of water leaking ,you need to replace the seats in the faucet. if not ,just replacing the o rings should fix your problem.
Feb 20, 2011 | American Standard Kitchen Faucet 6310 020...
I have a Blanco 157-081-ST Single handle, satin finish faucet that leaks. I'm trying to get to the cartridge but don't know how to take off the handle. I've removed a single screw on the handle body but...
If the screw you have removed is a set screw then you shuold be able to remove the handle. If it has been on there awhile you may need to pry on it with the handle in the full open state. Use something that will not mar the handle.
Feb 12, 2011 | Blanco 157-081-ST Modera Kitchen Faucet...
Moen kitchen faucet leak from spray
This might mean that the diverter in that controls the sprayer needs replacing. It is located behind the valve body underneath the tub spout sleeving
Feb 23, 2010 | Moen ShowHouse S711 Waterhill Single...
I have a single handed Kohler Vinnata kitchen faucet that is leaking from the handle. Cartridge has been replaced and hasn't stopped leak. What now?
turn off water remove handle and check retaining nut remove cartridge and check o-rings for damage or replace replace and tighten cartridge check for leak
Nov 04, 2009 | Moen 7437 Chateau Single Hole Kitchen...
Low hot water pressure in kitchen faucet
I have moen kitchen faucet # 7560 and water pressure very low. What should I do? We check water flow in pipe it is ok. I changed cartridge as well as pipe nothing help. Please let me know. thanks
Oct 14, 2009 | Moen & Replacement Cartridge
Water flow is too powerful..
I got you, you want a screen to be put on the spout!
check the inside of the spout. there may be a internal thread, if it is, then you can get a external thread screen from home depot.
Apr 22, 2009 | Danze D405046 Bellefleur Single Handle...
Moen 7437 Chateau Single Hole Kitchen Faucet with Side Spray Chrome... Logo
164 people viewed this question
Top Moen Plumbing Experts
john h
Don Numinen
Don Numinen
Are you a Moen Plumbing Expert? Answer questions, earn points and help others
