Question about ASUS Computers & Internet
Graphics card fault?
Hi we have a brand new asus mobo m2n68-cm and can not get the graphics card to work we have tried two cards no joy it does work with the onboard graphics the card we are using is a gigabyte 256mb/512mb geforce pci-e any ideas please many thanks bob.
  • 4 more comments
  • jackimba Feb 20, 2009
    Hi have already done that with bios and the card does not have any spare power slots.
    Hi yes when you look in the bios it is set for pci first i am trying to get in touch with the company where i got the mobo from i will try and find another mobo to test the card.
    Hi ok the cards are ok and put my card to the mobo and that woks but it still does not work on the other two any ideas please.
    Hi ok my card is a 9500gt super+ 1gb pcie 2.0 the other 2 cards are both giabyte 256/512mb geforce 7300gs pcie.
    Ok no the card does not show in device manager ram is 2gb ddr2 800 pc6400 the cpu is amd 5200 x dual core.
    Hi many thanks to one and all i will ring the supplier in the morning to find out what card they used when they tested the board once again many thanks.
  • 77 Answers
Go into your BIOS and enable the PCI Express slot. Then also make sure your Video Card does not need a power plug into it. If it does, check the extra cables from your power supply for the proper connection and hook it to the video card.
Posted on Feb 20, 2009
  • 4 more comments
  • Randy
    Randy Feb 20, 2009
    Well, from the looks and sounds of it, one of two things is going on. If you have made sure that the PCIE Bus is enabled and set to first boot, and you have made sure there is no need for an external Power source for the vid cards, then either you have 1 bad motherboard or 2 bad video cards.
    Have you tested the cards in another system? Do you know that they are working?
    If so, I would suggest you get a replacement motherboard.
    *Upon further investigation..* That board should come ready to boot off PciE. So I would suggest it is likely you have a faulty board.
  • Randy
    Randy Feb 20, 2009
    Ok,, so your other card is a PCI Express card as well? And it works on that board. The other two cards are also PCI Express and do not work on that board, but DO work on another board? Is this correct?
    What is the model of the working card? What is the exact model of the two non working cards?
  • Randy
    Randy Feb 20, 2009
    Hmmm. Well the two you are trying to install to it are the same chipset as the onboard card. If you install one of them and boot off of the onboard card, is the card in the PciE slot seen in your device manager?
  • Randy
    Randy Feb 20, 2009
    Also, What brand and size RAM and what CPU are you using.
  • Randy
    Randy Feb 20, 2009
    It must be an incompatibility then with the chipset. The chipset on the 2 video cards you can't use are the same as the onboard graphics chipset. Same family... 7 Series. I would suggest you move up to an 8 or 9 series video card to solve this issue.
    You can call AsusTek if you wish to verify this incompatibility, but I suspect that is the issue. You could also try loading the newest BIOS file to your board, to see if they solved this problem in a later revision. However, there is no mention of a fix in the BIOS updates.
  • Randy
    Randy Feb 20, 2009
    No problem and glad I could help. I hope all works out well for you.
Graphic card problem
Sure you can upgrade and put a new graphics card in one of the pci slots.
Try Tiger Direct for graphics cards at:
http://www.tigerdirect.com
When the site comes up just put in Video Graphics Card in the search box and press GO. You can sort the list Price Low to High.
May 08, 2012 | Computers & Internet
Can i use a DDR3 Graphics card on ASUS P5KPL-CM Motherboard ?
Hello, I am the technician that will be assisting you today. My name is Norman-Wynne Damstra.
Welcome to Fixya Sachin Dhonge.
Yes a DDR3 or more correctly a graphics card with GDDR3 Memory will certainly work in your ASUS P5KPL-CM mainboard.
Take care!
Dec 16, 2011 | Computers & Internet
I use an AMD M2N68 SE2 motherboard.I bough an NVIDIA 9500GT graphics card lately.Now my display will go out after a few minutes..
Hi. This is usually an indication of overheating. Make sure the fan on the graphics card is not blocked. Clean out any dust in your system and ensure adequate air flow across the CPU and the graphics card.
Dec 06, 2010 | ASUS M2N68-AM SE2 Motherboard
Hello, i believe this is an ASUS M2N68-AM PLUS issue but it may be my graphics card. problem: after installing an Nvidia GT 240 PCI-E graphics card, the pc boots but there is NO display (while using...
hi anderson4584, i have same problem with the same configuration,.. if you find any solution so please inform me at this email-id pardeep3@gmail.com
Oct 10, 2010 | ASUS M2N-MX Motherboard
ASUS M2N68-AM SE2 Motherboard having problems installing an inno3d 8600gt graphics card. motherboard doesnt seem to pick up the card. when plugged in monitor stays on standby. also downloaded the latest...
I would first check BIOS and disable Onboard video (if applicable) and then make sure that graphics port is set for PCI-e and not PCI or pci-e 1x or something.
Check that first. And make sure that card is all the way plugged in. You won't believe how many people don't plug it in all the way.
Brian
Jul 08, 2009 | ASUS M2N68-AM SE2 Motherboard
Which graphics card ican use in ASUS M2N68-AM SE2 mother bord amd athlon 64 5200+
unfortunately, this board does not appear to have slots for upgrading its graphic card.
Model Brand ASUS Model M2N68-AM SE2 Supported CPU CPU Socket Type AM2+/AM2 CPU Type Phenom FX / Phenom / Athlon 64 FX / Athlon 64 X2 Chipsets North Bridge NV Geforce 7025 / nForce 630a chipset Memory Number of Memory Slots 2×240pin Memory Standard DDR2 1066 Maximum Memory Supported 4GB Storage Devices SATA 3Gb/s 2 SATA RAID 0/1/JBOD Onboard Audio Audio Chipset Realtek ALC662 Audio Channels 6 Channels Onboard LAN LAN Chipset RTL8201CP Max LAN Speed 10/100Mbps
You are stuck with the integrated card.
Jun 28, 2009 | Computers & Internet
Graphics Card Compatibility with Asus M2A-MX motherboard
Hi Anli!
Well, any GPU with pci expess will be compatible thit that mobo of your.
Its not easy to recomend any specific, it all depends of what you needs are.
Just make sure that the card you upgrade with is for an pci express slot.
A verry good GPU coast around 150-200 euros, a top GPU card cost 400-600 euros
There are ATI cards and there are Nvidia cards, both will suit with your MoBo as long as they are for pci express.
Good luck with your new card M8!
please take a moment and rate my answer
Nic
Feb 06, 2009 | ASUS Computers & Internet
Dont suit my mobo
remove the graphics card, turn the computer on, wait for any error beeps if any, then re-install the card , then try it again, this should work, hope this helps you,glen.
Dec 21, 2008 | ASUS A9550GE/TD Radeon 9550 Graphic Card
Motherboard problem
Hiw can u say's its display problem,Have u checked the signals on k/b ?
If not check the Num lock status in keyboard. Press the Num lock key ,if the light glows and stands for sometime display is ok,but ur vga adapter is the problem.
Otherwise problem maybe with m/b or psu.
Pl check it.
Regards.
Was this soultion useful?give the apppriciation by rating it.
Apr 04, 2008 | ASUS P5K-V - Motherboard - ATX - iG33 -...
Computers & Internet Logo
Top ASUS Computers & Internet Experts
Alun Cox
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
