Question about Poulan Pro 22" Self Propelled High Wheel Mower
Thanks for your help...I have another question.
Thank you Mr.FixIt. I appreciate your help. I don't know if this makes a difference but our mower is the Poulan Pro self propelled with electric key start. So the wires that our dog chewed up are the ones that connect to the key start. Can those be replaced? We are in the military and stationed overseas so we don't have a local repair shop to go to. Do you know of any websites that we can order the new wires from? Thanks!!
    President:
  • 1,073 Answers
Hi!
Well..im nor Mr FixYa, but im one of all the pple trying to help other ppl out:)
Now to your question, yepp! they can be replaced, and you can easy make your own cables and replace them. But if you dont know how, you can order parts and accessories from here:
http://www.poulanpro.com/poulanpro/indexAction.do?id=default
You can also aks them on that site if there is a shop near you who have their products.
Good luck to you
Nic
Posted on Feb 20, 2009
AnthonyBR82, This was helpful. Thank You. I found that debris was in my tensioner pulley. It engages fine now. When I was cleaning the debris out. I found a broken spring. It attaches to the forward part...
Frank (Gunny G),
I replied from a different location. I replied under you post, so look there. If you can not find it then let me know and I will get back to you.
Semper Fi Gunny,
Anthony (anthonybr82) former MM2/SS USN
Jul 12, 2011 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
My mower lacks speed in forward. It works fine in reverse. Does it need hydraulic fluid? If so, how do I add it?
Good question ... what kind is it ... should I guess? Some take 30 weight non detergent oil ... others take transmission fluid type F or GM or other "flavor" (specialty oil). Some fill under the seat others fill else where. Are you sure it is hydraulic? Have you looked for the fill tube? Do you have the instruction/owners manual anywhere? I would like to help you and maybe I have, inadvertently. Please don't put anything in until (1) you know what kind of fluid is suppose to be put in (2) you know it is low and requires additional fluid (3) don't operate it until you get the answers to (1) and (2). Is there a dealer for your unnamed make and model in your town? Have you called them? Maybe you should give them a call ...
If you have additional information to offer which will help me to help you solve your trouble, please post it. Thank you.
Thanks for visiting FixYa.com today.
Jun 06, 2011 | Garden
DO NOT KNOW HOW TO REPLACE THE BELT TO THE DECK MOWER
Me to ... you want help but you don't give any description of the mower! There must be a way to remove it ... think about this ... someone put it on! so it has to come off! You may have to disconnect part of the deck, I don't know ... You may have to cut the old one off and pry the new one on (on cheaper models) I don't know, you will not tell me what we are working on. It SHOULD be reasonably easy - some company made them by mass production - they wouldn't make it hard for them to assemble (unless it is a really cheap one).
I suggest you get on the ground and study the deck ... look for levers or tension pulleys. Make sure the mower is OFF, OF COURSE. ALSO, disconnect the SPARK plug as turning the belt COULD START THE MOTOR!!!!!!! I don't know what this machine is so I am stressing the safety aspect of what you are about to do!!!!!!!!!
If you will post additional information on this machine, I may be able to offer more suggestions.
Thank you for using FixYa.com
Jun 05, 2011 | Garden
What kind of fluid goes in the hydrostatic drive ? The mower goes fine in forward and reverse when first started. As the mower heats up it has trouble pulling itself. After about an hour it will barely...
Hi Jeff,
Use hydrostatic fluid. Consult your owner's manual for information. Do not use hydraulic transmission fluid.
If you do not have your owner's manual, you can find one on www.managemylife.com Just go to that site, click on manuals and enter your make and model number.
Hope this helps. If it does, I'd appreciate a 4 thumbs up. Thanks,
Handie Andie
May 09, 2011 | Briggs & Stratton Garden
I have a 96 cadillac deville and my air compressor seems to not be turn on what could it be
check out fuses,relay first. low charge ,bad cycle switch. or the dreaded fluid sensor, ts in the liquid line, and the freon has to come out to replace it. or the coil in the clutch could be bad or air gap of the clutch to wide, check with a test light for power and ground at the compressor clutch
its a lot i know.. what can i say , its a/c and its a/c on a caddy. have fun and if'n i was of help leve a coment or vote .. try to BUY USA made products . thank you Jay.. mr fiXit
Nov 21, 2010 | Cadillac DeVille Cars & Trucks
Mower will start but not stay running
the mower seems to be running fine now. after i read a solution to another readers question on a different problem, thought i'd give it a try. i took off the bowl. it was filthy, so i cleaned it out, checked the float, and put it back no. then reconnected the fuel line, and cranked her up. problem fixed so far. thanks fixit guys.
May 04, 2009 | Craftsman Garden
The bottom shelf of fridge is broken. Where can I find the replacement shelf Thanks Nazakat
just move it from the bottom to the top and your problem will be gone or if that doesnt help any branch of fridgeshelves r us your friend mr fixit
Apr 26, 2009 | KitchenAid Superba Architect KSCS25INSS...
Toro Model # 20331 Starts, but doesn't run
Mr. Fixit...excellent advisement...really appreciate it. It got my grass cut today. Big yard! Problem is, when I finished, now I have the same problem with it not running...what do you think: take the Toro to the junk yard or what? Thanks!
Apr 25, 2009 | Toro Lawn Mower With Toro Power Tools
I have an MM 275 18" Electric Lawn Mower. This is the 4th summer I have used it and I love it. However, the lever is not working properly. I have to hold it in the corner very tightly to keep it...
well its a easy fix if thats what you wanna hear.
usually in the housing the wires try to disconnect from the lever and makes it harder to connect.
I have found over the years over a dozen electric mowers that its just the wiring coming loose.
call mr.fixit or find someone to manage to take the handle apart and put it back together again after.
Aug 04, 2008 | Black & Decker 19" Electric Lawnhog...
Poulan Pro 22" Self Propelled High Wheel Mower Logo
Top Poulan Garden Experts
Roland W VanLue
Roland W VanLue
Phil Walker
Phil Walker
Are you a Poulan Garden Expert? Answer questions, earn points and help others
