My Magic Chef built-in Dishwahwer turns on but does not cycle. It get stuck on the start postion of the rotary knob and does not moove. Also the red light for the on - off switch intermittantly comes on and off while on. Thanks
Water will come into the dishwaher if the Rotary timer is set in that position..
Normal cycle (when working) is:
1. Set Rotary position to Short Wash (beginning of cycle) - Dishwasher turns on and runs for about 30 seconds..no water in yet.
2. Then Rotary Postion clicks clocwise and Dishwasher fills with water
3. Dishwasher starts is full cycle as the rotary switch continues to slowly click clockwise, "filling" "washing" "draining",,,etc..til done.
What the dishwasher is doing is whereever you position the rotary switch, it stays in that postion, performs only that cycle and never moves off that postion....Water will come into the dishwaher if the Rotary timer is set in that position..
timer but if you have tempbost buttion pushed timer will not adv till water is hot 140 f all so take knob off and clean knob will stop timer from moveing if dirt behind it i have had that hapen over the years timer but if you have tempbost buttion pushed timer will not adv till water is hot 140 f all so take knob off and clean knob will stop timer from moveing if dirt behind it i have had that hapen over the years
You can't post conmments that contain an email address.
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong.
If you are hearing a clicking or buzzing thencheck out the last two tips.
If your refrigerator is running but warm, then...
Check out these tips that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
washer think there water over fill to clear this u need ruin a diagnostic test. think of timer knob light a clock straight up being at 12 oclock an one click at 1oclock to enter the test first rotate knob to any postion except postion 6 staight down press start and fs button at same time wait 3 seconds an rotate knob to to postion 6 wait 3 second then release both button , all light should blink . you should now be in test , rotate knob to various postion to test wash cycle an rinse an spin postion 9 an 10 are the waster valve onces the test finish tun the knob to another postion to turn test off an unplug washer an plug bach in this should clear it . if still have a porblem call a applince service ok
please check and make sure the knobs are not stuck in pull on each of them the oven does not spark it has a glow bar but there are switches behind the knobs that maybe sticking check that first
Worked like a champ...
Thanks for all your help
I appreciate it!!!!!!
