Question about Denon AVR-1604 Receiver
No sound on digital inputs
Hi, When I have a digital input, either COAX or optic, I am not getting any sound in any mode. This includes stereo, 6 ch surround etc.
Analogue input and tuner is all OK, but only on stereo or direct but not in surround.
When I have a digital input, the 'digital' on the display is shown indicating a digital input, but nothing going to speakers.
The relays click in, but no sound on either speaker.
Test tone also not working.
Any assistance greatly appreciated.
Dave
  • dahbrown Feb 25, 2009
    Thanks! FM works OK. both front speakers work. I have proved the speaker connection as when I put an external input into the 5.1 input all speakers work fine. I also tested with a friend that if I put an optic signal in and connect the optic out into his amp, it works OK.
    I suspect DSP card as there is no voltage on either speaker on the header to the CPU board. I tested this by putting the test tone on, and checking voltage.
    I have also verified the 5V regulator on the DSP board is OK.
    Any clues would be muchly appreciated!
Hi there, in regards to your problem the only thing i can think of is that you have to go to settings and select the channel for each digital output i.e. aux then optical 1 you must turn it on . then it should automatically switch to that when it detects the digityal signal.
Posted on Jun 13, 2009
  • 119 Answers
Do you get sound when on FM? but not on test tone! check all speaker connections, spkrs are on and if thats good you may have to do some digital input assigning, let me know I can help with that
Posted on Feb 25, 2009
No sound on coax audio input from HDTV
Check your settings on your tv. You may have to turn off the internal tv speakers in the setup menu in order to get any audio output from the jacks on the back.
Dec 20, 2012 | Sony STR-DE835 Receiver
Does my tv have audio outputs?
42PG20 Connections
  • Connector Type
  • 1 x Composite video/audio input ( RCA phono x 3 ) - Rear ,
  • 1 x S-Video input ( 4 pin mini-DIN ) -
  • Rear , 1 x Digital audio output (optical) ( TOSLINK ) - Rear ,
  • 1 x Remote control ( Mini-phone 3.5 mm ) - Rear ,
  • 1 x Serial ( 9 pin D-Sub ) - Rear ,
  • 2 x Component video input ( RCA phono x 3 ) - Rear ,
  • 2 x Audio line-in ( RCA phono x 2 ) - Rear ,
  • 2 x HDMI input ( 19 pin HDMI Type A ) - Rear ,
  • 1 x VGA input ( 15 pin HD D-Sub (HD-15) ) - Rear ,
  • 1 x Audio line-in ( Mini-phone stereo 3.5 mm ) - Rear ,
  • 1 x Composite video/audio input ( RCA phono x 3 ) - Side ,
  • 1 x HDMI input ( 19 pin HDMI Type A ) - Side
42PG20 Audio System
  • Sound Output Mode Stereo
  • Surround Mode Yes
  • Sound Effects SRS TruSurround XT
  • Audio Controls Bass , Treble , Balance , Sound mode
  • Speakers Included 2 speakers
  • Output Power / Total 20 Watt
  • Additional Features Auto volume adjustment
  • Speaker(s) 2 x Right/left channel speaker - Built-in - 10 Watt
Feb 04, 2011 | LG 42PG20 42 in. Plasma HDTV
I have the onkyo tx sr502, onkyo dv sp402e with the speakers..etc.. i'm trying to set up the whole thing to a normal television. that is, what cables go from what components, out/inputs..etc..and which...
Hi troy my names Josh i would be glad to be able to help you with your setup. First things first some people have a preference with they way they like things and for one do myself. I set up and intstalled my home theatre. I have receiver much like yours. On the back of your reciever you should have multiple inputs of coarse some for sound some for video. Your sound inputs would include digital optical, digital coax, standard analog which of coarse is the red and white RCA inputs and then a multi in which i doubt you have. So lets start simple If you have satalite or some form of cable i would assume you have your reciever box feeding a signal to your tv and the same for your DVD. I would recommend for your sat. that you connect your picture and sound strait to the tv rather it be component video or s video or standard video source or connect then for your sound strait analog to your tv thats just Red and White RCAs which will give you your sound to your tv. Repeat the same for your DVD depending on the kind of inputs and number of inputs you have on your TV. Now for the sound to your reciever. I ran digital sound from both my DVD and my Satilite to the reciever which means on the back of your recievers providing you have a similar configuration you would look for a plug on your dvd player that says optical thats your digital to run sound to your onkyo and the same for your sat or cable if you have a box look for either digital optical or a single digtal coax output that will also be ran to the onkyo for sound. You should only have two cables running to the onkyo one fiber optic from your dvd to the onkyo and one digital coax or fiber optic to your onkyo depending on the number of those inputs you have on the back of the onkyo you can run it how ever you want.
Oct 07, 2010 | Onkyo TX-SR502 Receiver
What is the A.F.D. mode?
it stands for All Field Dynamics. this is the mode you need to use in order to get the dts to work. use a digital input (either coax or fiber optic) from your dvd player and cable or satellite box and run in a.f.d. what it does is picks the best quality sound input a picks what ever mode best works for it. but if you play a cd in your player it will only come out as stereo or 3 channel. so then you can pick another mode of your choice. for movies and tv just leave it on a.f.d. all the time.
Feb 21, 2009 | Sony STR-DE545 Receiver
No sound from optical or coax digital inputs
You have to use the system setting using the remote and turn on the inputs you want to use. Hope this helps.
Keith
Oct 16, 2008 | Denon AVR-1602 Receiver
Connecting new tv to DRA-685
you can use the headphone jack just get an adaptor to change from the headphone type to RCA type. adjust the volume of the tv to 3/4 of the way to give line level to the stereo, use an aux input on the stereo. if you had a suround sound dolby digital / DTS receiver then use the digital coax out to that type of receiver, but since you have an anolog 2 channel receiver you must use the only anolog source (the headphone).
May 21, 2008 | Denon DRA-685 Receiver
No digital input at all
Have you tried to push play on the sound source? It says no coax/optical input until you start playing..
May 18, 2008 | Logitech Z-5500 Computer Speakers
Pioneer receiver VSX-D411
Yes techtod you are right you do have to tell the receiver what you want it to do usually on the front panel you can access set up menu and go into input set up This is an example Say you plugged the dvd into optical one or coax 1 you must go to the input that says dvd click down till you highlight dig input and then select optical 1 or coax 1 there can be as many as 8 digital inputs so just check wich one you plugged it into and then tell the amp then you should be back to watching your digital movies
Mar 21, 2008 | Pioneer VSX-D411 Receiver
No Sound
O1 is the OPTICAL input. C1 is the COAX input. Try pressing the DIGITAL INPUT button to cycle to the analog mode.
Nov 27, 2007 | Sherwood RD-7103 Receiver
Denon AVR-1604 Receiver Logo
309 people viewed this question
Top Denon Audio Players & Recorders Experts
 Grubhead
Grubhead
Electro Med Services...
Are you a Denon Audio Player and Recorder Expert? Answer questions, earn points and help others
