Question about Toshiba Tecra 8100 Notebook
My laptop sudenly shuts down without warning
I can only use it if im connected to a power supply, the battery doesnt work and it sometimes just shuts down
  • hcsr
    hcsr May 11, 2010
    Hello.
    If your battary does not work and doesn't charge then take it out of the laptop. no need for a dead battary in a working laptop, plus not sure if its a good idea to have it in the laptop incases of leekage.
    when your laptop is on with the ac connected does it work ok before it shutsdown of do you get memory errors sometimes. is the ACpower pack the correct power pack for that laptop. make sure the centre pin on the laptop is the same size as the power connecter hole on your power cord as is the pin is smaller then you could simply just have a bad power connection, keep in mind as well that if the ACpower is not the correct adaptor then that is also why the battary does not charge.
  • Flapa May 11, 2010
    It shuts down when connected to the AC adaptor only? Have you tested it whit the battery out of the laptop?
    If it shuts down with AC power supply only does it shutdown in a specific application? various aplications? specific OS?
    Specific timings? (temperature issues)
    Please respond.
    Problem Solver:
  • 12 Answers
Sounds like thermal problem.Debris in the fan or heatsink
Posted on Mar 21, 2009
My compaq presario sr1103wm doesn't boot up it
First of all.. try connecting all your peripheals to your PC.(monitor, mouse,keyboard,mic,speakers,etc)
Then u should open your pc and remove BIOS battery and leave it out for few minutes and put it back in...
if that doesnt work u should remove all your RAMS (memory chips next to processor) carefully and start your PC without them, u should hear some beeps, that okay, just a warning, after that put them back in and start again.
if that doesnt work try changing your hard drive with another one, or just take yours and test it somewhere else.
the last u should check your power supply, i see it starts up and then shuts down.. if your power supply is dead u couldnt even start PC, maybe there is a problem with your power outlet, try changing cables and outlets, if still doesnt work test your power supply on other PC.
if none of this works then u probably have issues with motherboard or processor.. then you should take it to service
:D
Feb 16, 2013 | Computers & Internet
Toshiba satellite l300 not charging, doesnt work on the power supply
Try removing the battery completely and running it with the power supply connected. If that doesn't work, try borrowing a compatible power supply, or buy a universal one, and try with and without the battery connected.
The problem may be the power supply, in which case the battery won't charge and the laptop won't get any power.
Apr 06, 2011 | Toshiba Satellite Pro L300 Notebook
My computer is randomly shutting down. Sometimes it will work and other times it will not. I think the processor is overheating and causing it to unexpectedly shut down. the screen goes black, the power...
Few reason for the shut down
Could be heat, electrical,
1. try cleaning all vents with compress air in order to remore dust and fuzz that can be cloging the vents.
Once this done, verify that fans works proprelly,(check air flow coming out of vents) if they dont they will need to be replace or cleaned out.
2. Check power supply unit, and battery.
Sometime power supply unit is defective, getting too hot and power output is not stable and shuts down the laptop. ( change power supply unit) check if battery hold charge. if not change battery
3. Check connections for looseness and contact
If all seems normal,and none of the mentionned point seem to be defective, the cause is deeper and would need to be looked at by a technician.
Sep 29, 2010 | Acer Aspire 7520-5185 Laptop
Computer shuts down without warning
My first guess is that your laptop is over heating. Even with a fan underneath, if the bottom vent is clogged with dust, the CPU will still get too hot. Does your computer last longer when you run less programs? I would check for dust around the fan inside your laptop. There's a video on youtube showing an acer being disassembled:
Although it may not be your laptop specifically, hopefully it will head you in right direction. It would be a bad idea to blow the dust further back into your computer, so you may have to loosen some screws and buy a electronics duster from an office supply store, but it should solve the problem. I've ran into this a lot over the years, specifically with Acer and Dell computers. Hope this helps!
Jul 14, 2009 | Computers & Internet
My HP laptop zd8000 shuts down in the middle of my work
There is a class action lawsuit currently being initiated against HP for this issue. The Complaint alleges that HP misrepresented and concealed material facts regarding certain laptops including a design defect, which causes the power jacks of the laptops to fail.
Sign up here:
http://www.sfmslaw.com/pages/cases.php?id=300
May 01, 2009 | Computers & Internet
HEEEEELLLLPPPP MEEEE~~~~~~~
i need u to get in to the lapryor.net in Texas so i can get on what ever i want
Nov 21, 2008 | Twinhead SlimNote N12PI Notebook PC
Overheating
if fan is working well then it might have processor problem.
Nov 19, 2008 | Toshiba Satellite A105 Notebook
Shutting off
Try running it without the battery and see if it does the same. Sometimes a bad power supply will cause a short to develop in the battery. If it stops shutting down without the battery the you'll need a new battery.
Jul 03, 2008 | Gateway 6022GZ Notebook
Compaq Presario Laptop lost power
the battery charger board, is what I would swap first.
Good luck, keep us posted.
Nov 15, 2007 | Computers & Internet
Toshiba Tecra 8100 Notebook Logo
69 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
