Question about Intel D845GLLY Motherboard
Bios problem I have Intel Desktop D845GLLY motherboard, recently it has no display and when power is on it gives one beep
  • 530 Answers
Hi im josh in cebu phils. may i help you? Friend if it gives one beep and no display. the problem is either the memory or the video only. because this hardware gves this sign if deffective. First thing to do is to check your video card or video connections if it is connected properly and firmly.tighten firmly the video card on the mainboard if you are using video card.or 2nd try to to clean your memory bank or your memory chip with an pencil erase,try to do it slowly.then install it firmly tighten in your memory bank. thats all if it still occurs the same prblem try to replace your memory or the video card. Good luck friend. Hope i helped you.
Posted on Feb 20, 2009
Sir iam recently purchaged the intel d845glly motherboard i can swiched on the cpu it is no display in moniter what is that problem
YOU MAY HAVE TO GO INTO BIOS TO FIX THAT WHICH YOU SHOULD NOT DO.I SET MY BIOS PERFECTLY AND TYPED A RANDOM PASSWORD WITHOUT LOOKING JUST TO KEEP ME OUT OF IT.YOU CAN DESTROY YOUR PC IF NOT KNOWING WHAT YOU DOING.SO BRING COMPUTER TO LOCAL COMPUTER TECH SHOP..WAIT SO THERE`S NO DISPLAY WHEN YOU START UP OUT ALL WELL THEN FORGET ABOUT THE BIOS THING YOUR MOTHERBOARD DOES`NT SUPPORT YOUR MONITOR MOST LIKELY.SO YEA YOU MUST BRING YOUR PC AND MONITOR IN FOR SERVICE THE MONITORS FINE BUT JUST BRING IT TO SHOW THEM YOUR PROBLEM..THEN YOU WILL ALRIGHT....HOPE THIS HELPS!
Nov 29, 2009 | Intel Desktop Board D845GLLY Motherboard
Inf update
Dear friend download and install it.. here your link.
http://support.intel.com/support/motherboards/desktop/d845glly/#anchor2
Find Software and Update there you find the Update BIOS software. thanks
Mar 23, 2009 | Intel Desktop Board D845GLLY Motherboard
Bios problem
Dear singer. it seems like your RAM is not working properly. You need to change its slot to an empty one. Hopefully you will not have this problem any longer. Don't forget to place rating to this solution.
Mar 02, 2009 | Intel Computers & Internet
Boot up beep codes, intel d845glly
here is a list of all beep codes : http://www.cas411.com/ShowArticle.aspx?ID=54
try to identify the beep pattern, it should tell you what's wrong. Most of the time, it's a bad memory stick.
Alex
Feb 22, 2009 | Intel D845GLLY Motherboard
No Dispaly Intel D845 GLLY
check the all power cable. change the motherboard battery. remove the ram, agp, then add togther. change the power supply.
Jan 23, 2009 | Intel Desktop Board D845GLLY Motherboard
Probblen in Additinol RAM
Hi Raj_jp, the Intel D845GLLY board must have SPD memory to function correctly in the system. The memory you added (512MB) must not support SPD. To help you understand what SPD is, you can click on this link which explains what SPD is.
http://searchcio-midmarket.techtarget.com/sDefinition/0,,sid183_gci533524,00.html#
The memory sold in this next link will function in you're Intel motherboard. http://www.memory-up.com/Memory/IntelD12696.html
So will the memory in this next link.
http://www.memorystock.com/memory/IntelD845GLLY.html
If you bought the 256MB memory recently, you should be able to return it & have it exchanged. The link above also lists the part number for the memory.
Good Luck!
Remember you're Intel motherboard uses you're system memory to run the onboard video card. The total amount of memory the video card uses can be adjusted higher or lower. You can adjust this in the bios. Go to Advanced Menu. Page 40 in the Intel user manual. You can download you're manual at this link.
http://www.intel.com/support/motherboards/desktop/d845glly/sb/cs-008853.htm
Mike
Jun 02, 2008 | Intel D845GLLY Motherboard
Intel 845 glly board please solve the problem
Hi Nadeem Nawaz,
No board will show display without memory. Your motherboard must run memory type;
Two DIMM sockets supporting 3.3 V (only) 168-pin 133 MHz Single Data Rate (SDR) SDRAM DIMMs with gold-plated contacts.
Unbuffered non-ECC DIMMs only.
Maximum total system memory: 2 GB; minimum total system memory: 64 MB.
Serial Presence Detect (SPD) DIMMs only.
Intel link showing memory specifications.
http://www.intel.com/support/motherboards/desktop/d845glly/sb/cs-012825.htm
If your memory is within Intel's memory specifications & you are not getting display on your monitor. It is possible that the integerated on board graphics (Shown on page 13 in your user manual), may be defective.
You can add a PCI video card to the PC. The Intel D845GLLY will auto detect the PCI video card. No need to enter the bios & make changes.
Please keep this in mind. The integrated video card is PCI, if it has failed, there is a good chance it will not see the PCI add in video card. If you can find a used (Working) PCI video card to test in the PC.
Intel Desktop Board D845GLLY main website link.
Luck!
Apr 19, 2008 | Intel D845GLLY Motherboard
No display
Fiend your solution direct from intel. Here is your solution........
http://www.intel.com/motherboard/prob676ijt65/solution
39
Apr 09, 2008 | Intel Motherboard
Sound driver
i want intel desktop board d845glly mother audio driver
Jan 19, 2008 | Intel Desktop Board D845GLLY Motherboard
Intel D845GLLY Motherboard Logo
105 people viewed this question
Top Intel Computers & Internet Experts
Tony
Alun Cox
David
David
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
