Question about HP Compaq nc6320 Notebook
Wont power up
I have hp dv6000 laptop and when i push power switch lights come on then go off after a few pushes of power switch they stay on fan comes on for 2 seconds no screen then it goes off battery fine even charges up
  • lilmarry06 Mar 15, 2009
    i push the power button the lights come on but screen doesnt. then it shuts off for like one second then tries to come on but then shuts of for another second and just keeps on. battery is fine and charger is fine. Sometimes after trying for a while it finally comes on and loads up but then the screen is all scratchy looking and you cant see anything. Once in a while you can get it to come on correctly but it take for ever
  • 65 Answers
Sounds like someone has spelt water or something on the laptop. Don't keep trying to start it and remove the Battary and take it to you computer service agent to have a look.
Other easy things to look at first would be to remove any USB items connected, test your power pack and make sure it working.
Posted on Feb 20, 2009
  • I an also servlcing personel. please instruction given me.
My hp compaq nc600 laptop wont turn on just an ornage light comes on, black screen and fan for 10 seconds then dies?
In the first instance you need to check your power lead. Exchange it for another one that you know works.
Apr 09, 2013 | HP Compaq nc6000 Notebook
Describe your HP Pavilion dv6000z 15.4" Notebook Laptop PC (AMD Turion 64 X2 Duo Core TL-50 1.60GHz, 1GB RAM, 100G... (d6000z) PC Notebook Problem SCREEN WONT TURN ON LED LIGHTS OF POWER BUTTON...
The dv6000 series was commonly affected by the video card heating up and reseating itself. This was usually a soldering issue. You have a few options, You can either replace the motherboard, or have the motherboard reflowed. Unfortunately the video card itself is not detachable or individually replaceable.
I personally would recommend the second option as purchasing another dv6000 board will likely end you up in the same situation a year or 2 later.
A repair / reflow services on ebay
Dv6000 Repair
This repair tech only does amd processor models, Not intel.
Hope this helps.
Aug 29, 2011 | HP Pavilion dv6000z Notebook
Hp pavillion dv6000 push the start button, lights come on for ''split second'', and nothing. lights go off, no motor, no nothing. happens when plugged in or not
You have suffered a motherboard failure, just to be sure you need to check the voltage at the tip of your AC adapter and leave the system battery out of it, Just try to power it on with the adapter. If the same event happens, you will need to either service the motherboard or replace it. Ebay has several MOBO repair services for the HP products, specifically the DV6000 and the DV9000. These have been HP's problem child for a few years.
Jan 15, 2010 | HP Pavilion dv6000z Notebook
Laptop Pavillion DV6188eu doesn't start up
From what you are describing, the motherboard has failed. I would however like you to try a couple of things though. First remove the hard drive and see if the computer will go to the BIOS screen. If it does not, then the Motherboard has definately died. If you can get to the BIOS, then you might consider a hard drive failure, or your windows installation is so corrupt, it is causing this problem. I would however lean toward a bad MOBO....seems this model, the DV6000 and the DV9000 have serious cooling issues and tend to burn their mobos up. HP recently started updating the BIOS files for these models so the fans and processor run more efficiently to keep the laptop cooler.
Nov 08, 2009 | HP Pavilion dv6000 dv6100 dv6200 dv6300...
Hp dv6000
dear problem in prossear fan and hit sink jus chenge the hit sink and fan after working fine
www.compudesk.in
Jun 22, 2009 | HP Pavilion dv6000t Notebook
Hp dv6000 won't start up at all, lights turn on, then off
You may need a new power supply, It may be putting a bit of power out but not enough to run thr comp
Jun 15, 2009 | HP Compaq nc6000 Notebook
On my laptop the vent fan starts then stop and the power goes out
These machines have a terrible overheating problem! You will have to clean the fan opening and, put sylicon grease on the heat pipe and, heatsink that covers the cpu
Apr 04, 2009 | HP Pavilion dv9000z Notebook
AUTO SHUT OFF HP DV6000
Youre cpu heatsink is clogged with dust not breathing properly and causing it to over heat and shut down.Must remove keyboard heat sink should be on top right removed heat sink and clean dust .Use air can and spray whole laptop.
Oct 02, 2008 | HP Pavilion dv6000z Notebook
HP Compaq nc6320 Notebook Logo
181 people viewed this question
Top HP Computers & Internet Experts
Brian Sullivan
Brian Sullivan
Tony
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
