Question about Hitachi Air Tools & Compressors
Motor will not start under load, but will start from empty tank.
I suspect that the problem is that this 2HP motor is not capacitor start, and as not the original motor i just need to check the correct size and rpm speed of the motor, the one fitted is 2HP and 1400 rpm, Does anyone know the volume of the tank and the rated CFM?
Thanks in advance
Paul
    Champion:
  • 205 Answers
Bad check valve allowing air from tank back to the pump which when trying to restart has all that air pressure in pump cylinder pushing against the pump piston and with this load you will end up burning the motor
Posted on Feb 26, 2009
MTHAPPYFACE is totally correct check valve may be stuck with dirt etc..take it a part andlean it.
Posted on Jul 07, 2009
How can i fix my ec12 hitachi electric air compressor
This problem is caused by either the starter capacitor or the in-tank check valve. Ez to check. With no air in tank, start compressor; if motor hums or has difficulty suspect capacitor. If motor starts, partially fill tank and unplug the power. Check for air leaking at the pressure switch or air coming out of the air inlet (remove the air filter). If air leaking, replace check valve. If no air leaking, again let out all the from the tank and connect power. Allow the compressor to fill and shut-off. After the compressor fills, again listen for air leaking from the pressure switch unloader valve. If air continues to leak from unloader, replace the check valve. Good luck
Jun 11, 2015 | Hitachi EC12 Portable Electric 2hp Air...
Air Compressor trips breaker under load. If I remove the belt the motor runs fine, spins freely as does the compressor pump. With the tank pressure empty, the compressor starts and runs fine. When it...
Most people recommend replacing the motor capacitor in this situation, since a faulty cap will reduce the starting torque. But in my case the check valve was the culprit - there was too much back pressure on the head.
Oct 22, 2013 | Campbell Hausfeld VT6290 2.0 HP 20 Gallon...
My 4 gallon 2hp unit will not start on its own and then the circuit breaker goes. I need to assist it to get started. Any ideas?
Check the tank check valve where the pump output line goes into the tank. If it's stuck open the pressure on the head won't be released and the motor will have to fight the tank pressure every time it tries to restart. Another possibility is the start capacitor on the motor may have gone bad. Only way to test it is to replace it.
Sep 19, 2012 | Coleman Powermate 02 - Gallon Air...
I have a kobalt 236005 air compressor. It will fill the tank to 150psi properly. When it is time for it to refill the tank it will either trip the breaker or overheat the motor. It will not fill the tank...
Apparently you have a start capacitor, which acts as a surge tank to allow motor to start up under a load. Its usually a black cylinder shaped object with two [2] prongs with a wire plugged onto each one [1]. It can be tested with proper equipment, but should be reasonable to buy.
Sep 22, 2011 | Garden
My dad bought a used 2HP 4 gallon clarke pancake type air compressor at an auction. It keeps blowing capacitors. Does it have a centrifical switch to take the cap out of the cct once started?
hi there!
some motor compressor are equipted of centrifugal switch connected at the shatfting of the motor compressor after turning at rated speed this will be open and disconnecting your starting circuit as well as the starting capacitor.
have anice day fix my rate, thank you
May 07, 2010 | Clarke Power Products Inc AC2001 2HP 4...
2 hp 120 v motor on compressor. motor will not start under load
bleeder valve is bad or dirty drain air unplug machine pull the back up plate control plate and make it shinny with emmeory cloth then clen it and try again, if it still does the same thing your going to nedd to replace unloader valve.
Apr 14, 2010 | Hitachi EC12 Portable Electric 2hp Air...
My Clarke AC2001 4 Gal. compressor hums when power button is up. Compressor will not start up! Why?
one of a few things possible, first is that the start capacitor is faulty, second could be the start switch inside the motor, and the third that the pump is not unloaded ( if only happens when the tank has air in it) or the pump and or motor is locked up.
Mar 23, 2010 | Clarke Power Products Inc AC2001 2HP 4...
Motor hums dont start
sears craftsman air compressor motor hums. replaced start capacitor still hums
Mar 13, 2010 | Clarke Power Products Inc AC2001 2HP 4...
Compressor won't restart with any pressure in tank
try replacing the capacitor. a bad start capacitor will not let it start under a load.
Jul 10, 2009 | Craftsman 3 gal. Air Compressor, 1.5 hp,...
Air Tools & Compressors Logo
496 people viewed this question
Top Hitachi Air Tools & Compressors Experts
John Trevino
Jim Thurston
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you a Hitachi Air Tool and Compressor Expert? Answer questions, earn points and help others
