Question about Brother DCP 130C All-In-One InkJet Printer
My brother dpc 135c prints faintly
I installed repro cartridges and cannot get the printer to print out in a reasonable quality. All I get is very faint printing and cannot find a way to solve it.
5 Suggested Answers
SOURCE: Brother DPC- 115C
I have same problem. It started off as empty ink and low ink so I replaced first the black, did a test print then even though the other one yellow was still unchanged low the test print came out as black fine, cyan fine but yellow and magenta blank. Because it was blank and reading low I changed the yellow anyway but its still blank. After lots of tests and cleans magenta and yellow still remained blank. Now the cyan is near empty and the magenta even though nothing has been printed. I took them out many times to see if it will get it working tried all the above suggestions and anyway its now started saying no cartridge. I'm not using orig brother ink and don't expect it to be as good but not to print some colours at all is a bit odd. Cant get round this no cartridge thing though, machine has hardly been used so I'm disappointed if its had it.
Posted on Dec 21, 2007
SOURCE: printing faint
buy an HP
Posted on Feb 01, 2008
SOURCE: samsung ml2010 has faint printing
i have changed the ink powder so i have a good quailty printing ... but when i used another kind the problem appaer again
Posted on Feb 13, 2008
printerman40
  • 170 Answers
SOURCE: Brother Intellifax 2800 Faint Print
did you remember to remove the pull tab to allow the new toner to be utilized? it's either that or you just have a defective toner cartridge which if you replace will take care of the issue. If you have used canned air to blow out your machine it is possible that the toner dust has been blown into the laser housing and fogging up the mirrors that it uses but that's kinda a last resort check...
Posted on May 07, 2008
Neerak21
  • 101 Answers
SOURCE: It si not printing -very faint colour and np black
Here are the steps.
1.Print Demo Page.
a.Press the Menu button of the printer.
b.Use the down arrow key and select Print Demo Sheet.
c.Press Ok button.
If issue persists,the printhead on your printer requires replacement. Call 1.800.421.6699
Thanks.
Regards,
Neerak21
Posted on Sep 24, 2009
Brother DCP-135C Every time I switch on the printer, I get "Cleaning Cleaning Cleaning" for about 4 or 5 minutes before I can print anything. It's driving me potty. Is there a fix for this before I chuck...
try these options below....
turn on/off, unplug, plug in2_bing.gif, should reset configs.
take all the paper out, put half as much back in.
check the rollers to make sure no paper or particles are stuck.
go to applications folder for your computer, dbl click printer icon for make of printer. check settings. print 'test document and clean cartridge heads', this should ensure proper printing formats. another thing might be that you have to leave the printer on at all times, have you've tried this? i have known printers to be this way, not so sure with your brand though.
lastly, go to web site of printer model and check site for trouble shooting if this does not work above.
hope this helps and good luck
Apr 29, 2010 | Brother DCP-135C Flatbed Digital MFC...
Brother DCP-135C won't print yellow
1 years?
Means still under warranty for print head. maybe print head faulty. Better send to Brother.
Jan 27, 2010 | Brother DCP-135C Flatbed Digital MFC...
The colour on my Brother 135C Printer is not printing properley, could it be that the printer heads need aligning? If so how do I do that? Regards, David Melton
I have a brother MFC 3240C. My Black ink stopped printing(initially printed horizontal faded lines and gradually got worse), the other colors were printing fine. I tried cleaning numerous time( 50 -100 times over 1-2 weeks ). Still no improvement. The way I print now is:
1. I go to Printer Properties
2. Change Media type from "Plain Paper" to "Inkjet Paper".
3. Change Quality to "Photo".
This takes a long time to print 1-2 minutes per page. However, this works for me since this is my Home printer and use it for printing only few pages here are there.
Good Luck
RK
Jan 17, 2010 | Brother DCP-135C Flatbed Digital MFC...
I cant get the black print,after putting a black cartridge in,can you help please...brother 135c
Dear sir.
If your black cartridge is original
then it is problem printer black ink head
change it and buy a new one
Thanks
Tareq
Aug 26, 2009 | Brother DCP-135C Flatbed Digital MFC...
Ink well cleaners
There is a design reason why the print heads are changed when you change an ink cartridge is changed. The print head isn't made to be reused and the quality of your print will suffer at some point if you reuse the same print head 6 or 7 times. I would get new cartridges and be happy with the print quality that a new cartridges will bring.
Nov 10, 2008 | Brother MFC-5860CN InkJet Printer
Printing is faded and too light
more important than all that nonsense is:
is it faint when you do an internal report or make a copy?
if only on copies it is the film on the underside of the glass.
if on prints and copies it is the drum.
Oct 23, 2008 | Dell 1600n All-In-One Laser Printer
Very faint printing
its the print head..get a new printer. OR
Brother inkjets are like the epson..once the print head goes its toast.
Jul 07, 2008 | Brother MFC 210C All-In-One InkJet Printer
Using far too much ink
This came from brothers website:
The Yellow ink cartridge yield is up to 300 pages @ 600 x 150 dpi when printing at 5% coverage on A4 sized paper.
The Magenta ink cartridge yield is up to 300 pages @ 600 x 150 dpi when printing at 5% coverage on A4 sized paper.
The Cyan ink cartridge yield is up to 300 pages @ 600 x 150 dpi when printing at 5% coverage on A4 sized paper.
The Black ink cartridge yield is up to 350 pages @ 600 x 150 dpi when printing at 5% coverage on A4 sized paper.
so it appears that what you are experiencing is not normal and you may have a leaking printer.
There is one thing you can check though, everytime you print, make sure that you are not printing at the highest quality option selectable as this almost certainly will fire out more ink than regular printing... choose a middle quality option or even draft option if you will be printing regular text.
Jul 02, 2008 | Brother Office Equipment & Supplies
Brother DCP-135C Print Quality Settings Not Working Correctly
Have you uninstalled the driver, and reinstalled it?
Are you running Windows Vista? If so, have you downloaded the latest software from Brother's website? www.brother.com
It sounds like the driver is confusing the settings internally, which leads me to think that it is either corrupt or not compatible with your operating system.
Apr 19, 2008 | Brother HL 1440 Laser Printer
Brother DCP 130C All-In-One InkJet Printer Logo
260 people viewed this question
CheckitRight
CheckitRight
Soulvisitor
Soulvisitor
Ron Dufek
Ron Dufek
