Question about Whirlpool AKZ159IX Oven
Forno whirlpool con guasto f03
Dopo interruzione corrente elettrica comparsa sul display scritta f03 e il forno non si accende.
  • Anonymous Apr 08, 2009
    dopo interruzione della corrente elettrica il forno non whirpool non funziona e compare la scritta F 03. AIUTATEMI รจ gia' la seconda volta che chiamo il tecnico e mi costa un sacco di soldi. ciao alberto -treviso-
2 Suggested Answers
rylee_smith
  • 8619 Answers
SOURCE: Display reads code F03 on Whirlpool oven. Can I
Hi
Thanks for using FixYa. F3 error means Open oven temperature sensor or thermal fuse. You’ll need to replace oven temperature sensor or thermal fuse to resolve the issue.
Please do accept the solution if the issue is resolved or else revert for further assistance.
Thanks
Rylee
Posted on Jan 15, 2010
Whirlpool oven fault f03
Hi
Code F03 usually means that the oven temperature sensor is 'open circuit', that is not working at all.
The remedy is to have it replaced.
Dec 19, 2010 | Whirlpool AKZ159IX Oven
Our Whirlpool OBI C10 Oven has stopped and is displaying FO3 on the panel. I switched the supply off and on to try and reset, but to no effect. What is the cause?
Hi
Thanks for using FixYa. Error F03 in your range/oven means oven temperature sensor circuit failure. To resolve this issue you’ll have to check the oven temp. sensor circuit if the reading is more then 1100ohms then it should be replaced however, if the rating is fine then it is the Electronic Range Control (ERC) that has gone bad & should be replaced. Please do rate the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Aug 24, 2010 | Whirlpool Ovens
Cooker has code f03
Needs programming sometimes they leave the factory without it or they can lose the programme.
Feb 16, 2010 | Whirlpool AKZ159IX Oven
Hi
Thanks
Rylee
Jan 15, 2010 | Whirlpool RBD305PD Electric Double Oven
How do you set the clock on hotpoint forno sy36x
HOTPOINT FORNO OVEN IS SET ON DEMO MODE HOW DO YOU DISABLE THIS
Oct 10, 2009 | Ovens
F03 Displays
I bought a new oven found this one way to complex anyway. Afterall i just want to cook in it.
Regards
Ken Mc
Sep 14, 2009 | Whirlpool RBS305PDS Electric Single Oven
I bought a Whirlpool double oven AKZ161 and error code F03 appear
On this model, F03 indicates a faulty power control board (also known as the "Capricorn" board by Whirlpool technicians). A new oven with no guarantee? There is usually a reason something has no guarantee, in your case, a faulty control board. It is a relatively expensive part unfortunately.
You can try disconnecting from power, removing top panel from oven. The large square electronic board you see on the top of oven is the power control board. Check all plug connections are OK, especially the large thin multi plug that goes to the display board- I have had a poor connection at this plug causes F03 faults. If still no go, power control board will need replacing
Aug 17, 2009 | Ovens
Whirlpool oven fault f03 shown
f03 error is a sensor error.you could have taken an ohm reading on the thermistor to see if it was bad.if you replaces the t-mistor then the only other component responsible is the board.make sure all the connections on the board are clean and tight before you replace it.
Sep 28, 2007 | Ovens
Whirlpool AKZ159IX Oven Logo
3,070 people viewed this question
Top Whirlpool Ovens Experts
Dan Webster
Dan Webster
ashburton
Sal De
Are you a Whirlpool Oven Expert? Answer questions, earn points and help others
