Question about Moen & One Handle Tub & Shower Faucet
Just installed new Moen 82683. Seems kije the hot
Just installed new Moen 82683. Seems kije the hot and cold are working backwards even though everything is installed properly according to the very poor instructions. The hot water also runs very,very slow.
    Problem Solver:
  • 4 Answers
Take out the cartridge and flip it over.
Posted on Feb 26, 2009
My shower only stays hot for a minute and then goes cold even though the hot water works everywhere else. I have a hot and cold tap and a third one to direct to shower or tub.
I would take a look at the stem replacement task. Maybe something is clogging the hot water flow, perhaps a damaged washer or debris
Jan 14, 2013 | Moen Home
Had the Moen L82691 installed about 2 weeks ago. It worked fine, however now it only produces hot water. Even on the cold setting the water gets hot.
I think Moen is one of the easiest to work on and most trouble free there is. The only problems I have ever encouneterd with them is the mixing valve.This is the parts breakdown:
http://www.moen.com/shared/docs/exploded-parts-views/l82691pt.pdf
and a video
http://www.youtube.com/watch?v=J-SNBNijfQc
Of course you handle would have the set screw that holds it on. I would go to who ever you got the valve from and see if they will give you a new valve or, the video states Moen may provide a new one free. It's also possible, being a new install, that you may have had junk in your water lines that have now plugged the cold side of the valve. If you have some help, you may want to have someone taht can turn water off and on(slowly), cold first, and see waht kind of flow you have with valve out. Check for trash in the line and the valve first.
May 29, 2011 | Home
Leaking shower head
Not unless you had a backward plumber , If the diverter at the faucet is open for tub, then no water will go up the shower, The shower may hold enough water up there to make it look like a drip, Even if the valve was leaking all the time, it would not go up, it would come out the faucet. It only works with pressure. Unless the valve was plumbed wrong,,, Hope this helps.
Mar 16, 2010 | Moen & One Handle Tub & Shower Faucet
Cold water works, hot does not
your problem can be fixed by running a loop in the plumbing. If you hired a professional in the first place it would already be done. basically the water pressure isn't enough, i bet your faucet is on the second or third floor, or even just THAT far from the water heater.
Sep 07, 2009 | Moen Chateau Loop-Handle Kitchen Faucet...
Moen Model no. 82683 does not close
It sounds like the handle needs to be replaced. the stop place is in the handle. You can
Aug 30, 2009 | Moen & One Handle Tub & Shower Faucet
We installed two new single handle shower faucets with both hot and cold supply lines pressurized to each of the faucets. The problem is that no hot water will come out of either faucets. Their seems to be...
Sounds like the valve is defective. The supply to the stems was not bored out at the factory giving you a valve that is essentially pretty on the outside and solid on the inside. To test it, uninstall the valve. Remove the stems. Then try running a pipe cleaner though the valve from the supply side and see if it stops before the stem.
Aug 15, 2009 | Moen & One Handle Tub & Shower Faucet
Moen kitchen faucet. I changed the cartridge but
Single or dual lever? A new ball if single lever. Home Depot or Menards will carry them. Teflon tape if dual cartridge. Stay away from moving parts
Aug 14, 2009 | Moen & One Handle Tub & Shower Faucet
Hot and cold backwards on a moen shower faucet
tun off the water.
unscrew teh allen screw under neath the handle. pull out hteh handle. undo the wall plate and gain access to the cartridge in the handle body. turn the artridge around 180 degree and reisntall all parts.
Apr 06, 2009 | Moen 3175 Legend One Handle Shower Faucet...
Cannot get the cartridge out of the moen sh lav faucet..no cartridge tool, what can I use to get the cartridge out???
There is a small U clip that holds the cartridge in. It just slides up or down. Some Moen cartridges are very difficult to remove, they can be corroded inside "almost fused" it is best that you get a moen cartridge puller. Lowe's has them. If you decide to tackle this job make sure the water is off, and when you pull the cartrige remember the direction it came out. If you put it in backwards your cold will be hot, and your hot will be cold!
Jan 24, 2009 | Moen & Villeta Two Handle Lavatory Faucet
Moen & One Handle Tub & Shower Faucet  Logo
476 people viewed this question
Top Moen Home Experts
Mike
john h
Andrew Bugbee
Are you a Moen Home Expert? Answer questions, earn points and help others
