Question about Sharp AR-153E Copier
Sharp AR153E - 2 red warning signals on the panel
I am not sure what the signals mean: The first is a figure of a man with an arm raised, and the second is a circle surrounded by 8 dots.
This means it is time for maintenance and a developer change . it comes on at a specified number of copies. You can ignore it, your copy quality will eventually deteriorate but it wont hurt the machine .
Posted on Feb 20, 2009
Sharp model lcd2a33M,after plug in an power on ,tv on .after few minute power indication on green change to indication red. TV on only few minute
Hey
1) Make sure you are not accidentally pressing the remote control or the Power OFF button is not stuck inwards.
2) If the TV has a key panel (Power Button) on the back cover. Check and see the button is not stuck into.
IF above fails
1) Sounds like a hardware issue. Some signals are not sending the right or receiving the right data. So the protection circuit of the TV has been activated. Please get your manufacturer to come in and give it a good check.
2) If you are able to do "Reset" the TV. It will help. But realize that this might settle the issue or worse it creates unforeseen conditions.
Aug 18, 2015 | Sharp Televison & Video
Sharp aquos LC-37HV4U won't turn on just have a red light. I have unplugged the display and the AVC system. Turned back on then get a blinking red light. Turn on at the display and to goes to solid red...
when this occurs this is got only meaning: the Ignintion panel is faulty its the board/chip that gives the signal to the TV to start
to replace that part u must a serious soldering skill and and take to much risk cuz u might make more damage on that TV
plz do rate this post as good as u can
Oct 10, 2008 | Sharp Aquos LC-37HV4U 37 in. LCD HDTV
How do you replace windshield wiper motor on a 1997 ford e250 van
REMOVAL
  1. Raise and support the hood.
  2. Remove the windshield wiper pivot arms.
  3. Remove the cowl top vent panels.
  1. Disconnect the windshield wiper mounting arm and pivot shaft.
  1. Remove the access cover from the dash panel.
  2. Remove the mounting arm and pivot shaft retaining clip.
  3. Disconnect the windshield wiper mounting arm and pivot shaft from the windshield wiper motor.
  1. Remove the windshield wiper motor.
  1. Disconnect the electrical connector.
  2. Remove the three bolts.
  3. Remove the windshield wiper motor.
INSTALLATION
  1. Install the mounting arm and pivot shaft retaining clip on the windshield wiper mounting arm and pivot shaft.
  1. Install the windshield wiper motor.
  1. Place the windshield wiper motor in the dash panel.
  2. Install the three retaining bolts.
  3. Reconnect the electrical connector.
  1. Reconnect the windshield wiper mounting arm and pivot shaft.
  1. Press on the windshield wiper mounting arm and pivot shaft after it is aligned with the windshield wiper motor.
  2. Install the access cover in the dash panel.
  1. Install the cowl top vent panels.
  2. Install the windshield wiper pivot arms.
  3. Adjust the windshield wiper pivot arms.
This is technically for the V6 4.2L but I'm sure those Ford E250's have the same setup for windshield wiper motor. Let me know how it goes.
Nov 17, 2014 | Cars & Trucks
How to clean my sharp ar153 copier? it produces thin black line
Is this thin line being produce when you send the original thur the document feeder?
Jul 02, 2014 | Sharp AR-153E Toner Cartridge AR153E...
What does a flashing Red triangle mean?
TCO means that the tachograph does not work properly. Because the european legislation is very strict regarding the malfunction of the tachograph system, the truck manufacturers alert the driver about his critical situation with a warning sign, the red triangle that flashes.
Apr 16, 2014 | Bruder MAN TGA Container Service Truck
Sharp ar153e code error f4
this is H4 not f4
c-photo-c-phot press 14 from up and down key press print key
Apr 16, 2014 | Sharp AL-1641CS Laser Digital Copier
I can't find sharp ar153e n driver for windows 7 64 bit
 Here you can find all about Sharp AL-1651CS like driver and other information www.ps2netdrivers.net/driver/sharp.al-1651cs
Jan 10, 2011 | Office Equipment & Supplies
My sharp xerox machine ar5516 is bleaking a man
Man mean maintenance signal.
Reset : # - Interrupt - C -interrupt press 14 press start key.
If you are not fix try next way.
# - Interrupt - C -interrupt press 16 press start key.
Jan 27, 2010 | Sharp AR-5320 Black and White Copier
"little red man"
The "Little Red Man" stands for that the copier has reached it's set "P.M." counter and it is time to have the copier to have a general cleaning done. It is just a counter that comes up 10k, 20k, 60k, 80k or it is set not to count at all. It should not affect the copier it self. It has to be reset and set to "0" for no P.M. count.
Apr 24, 2008 | Sharp AR-160 Copier
Sharp AR-153E Copier Logo
180 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
k24674
jasbo
jasbo
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
