Question about IBM (91P8745)
IBM laptop track pad wont open files on double tap
IBM laptop after installing a fresh copy of Windows XP stopped responding to double tap
    Problem Solver:
  • 13 Answers
GO 2 DEVICE MANEGER ,IN CONTROLL PANNEL C IF ITS RECONISED ,IF NOT TRY A MOUSE ?
Posted on Feb 20, 2009
Reboot IBM think pad A21e
There are two possibilities, the hard drive has issues or windows has corrupted files. If you have a cd installation disc for a fresh install, try to see if the operational system will load, no change! the hardware should be checked in the event it needs to be replaced.
Apr 12, 2012 | IBM ThinkPad A21e 2655 Notebook
My hp 4520s probook's mouse pad got locked accidentally, and it's not unlocking by double tapping on the light button on the mouse pad. please help me with this asap.
First, try double tapping the light again. You may have just mis-tapped.
Next try restarting the laptop. Certain laptops re-enable the track pad on restart so long as a USB mouse isn't connected.
If that fails, navigate to the Mouse Settings on your PC and re-enable it there. If you have a USB mouse you can use that. If not, you can use the keyboard. Windows Key will launch the Start Menu, arrow keys can highlight options, Enter will click on them, Control+Tab and Control+Shift+Tab will switch tabs (in a window that has tabs).
In Windows XP and 7 (and probably Vista), Mouse Settings is located at Control Panel > Mouse > Settings.
Mar 21, 2011 | HEWLETT-PACKARD ProBook 4520s
I have a IBM Thinkpad R52 laptop - after reinstalling a fresh copy of windows my sound does not want to work - even though I did install the audio driver. How do I resolve this problem?
The same model ThinkPadcan have different types of network, video and audio drivers and unless youknow exactly which one is installed in your ThinkPad, you need to download allthe drivers and install each driver until you find the right driver. When you download thedrivers, write down the device driver and it's file name so you have a recordof which driver you are installing and which directory the unzipped files arelocated on your hard drive. Go to the IBM/Lenovo WEBsite - support/download page and download the latest Windows XP or Vista devicedrivers for your model computer, Use this link: - http://www-307.ibm.com/pc/support/site.wss/product.do?template=%2Fproductselection%2Flandingpages%2FbrowseByProductLandingPage.vm&sitestyle=lenovo&brandind=10&validate=true You can download thevarious drivers and then you click on and run the various driver files, theywill then unzip and expand into a sub folder on C:\drivers Then install thevarious drivers from this folder (run the set-up file).
Feb 16, 2011 | Computers & Internet
MY LAPTOP IS ACER ASPIRE 5315/2492 WINDOWS
it seems u have done every try.So now i recommend u too backup ur necessary files and install a fresh copy of windows via cd.
I recommend u to use xp or windows 7.
Mar 31, 2010 | Acer Aspire 5315 Notebook
MY IBM THINK PAD R51 IS SHOWING ERROR MESSAGES NTLDR IS MISSING PRESS CTRL+ALT+DEL TO RESTART
Windows XP users
  1. Insert the Windows XP bootable CD into the computer.
  2. When prompted to press any key to boot from the CD, press any key.
  3. Once in the Windows XP setup menu press the "R" key to repair Windows.
  4. Log into your Windows installation by pressing the "1" key and pressing enter.
  5. You will then be prompted for your administrator password, enter that password.
  6. Copy the below two files to the root directory of the primary hard disk. In the below example we are copying these files from the CD-ROM drive letter, which in this case is "e." This letter may be different on your computer.
    copy e:\i386\ntldr c:\
    copy e:\i386\ntdetect.com c:\
  7. Once both of these files have been successfully copied, remove the CD from the computer and reboot.
Sep 19, 2009 | IBM ThinkPad R50e Notebook
Laptop powers on, but windows doesnt load
Boot PC from Windows XP installation CD you will be ask to instal fresh copy or repair existing installation - go for "fresh copy" software will analyze you PC and try to find your previous copy of Win XP you will be ask again to repair copy of your existing Windows Xp now go for "Repair" option so installation software restore all Windows files and will keep all your settings*.
This solution is only temporary because IE 7 and 8 will no longer work after restoring - backup all your data and instal fresh copy of Win XP after all and always keep Your Backup up to date!!
Sep 07, 2009 | Medion (40010998)
It has no network driver to connect to the internet how do I do that
Boot up your Toshiba laptop Go to the IBM/Lenovo WEB site - support/download page and download the latest Windows XP or Vista device drivers for your model computer,
Use this link :-
http://www.ibm.com/products/finder/us/finders?pg=ddfinder&cm_re=other-_-suprcn-_-download There may be one or more driver files for each device, depending upon what device is installed on your IBM, download them all because only one will work with your device but you won't know which one until you install it and it works. Then copy the drivers from the Toshiba to a USB memory stick, then remove the memory stick and boot up the IBM R52 and insert the USB memory stick into the R52's USB port. Click on the USB memory device and double click on each of the device drivers. Each driver file will then expand and copy the driver files onto the C drive under a folder called Drivers. Open this folder to view the various drivers and run the Setup file for each driver.
May 13, 2009 | IBM ThinkPad R52 Notebook
Think pad r40/2681(driver prob.i.e. usb/wireless/sound etc.)
Go to the IBM/Lenovo WEB site - support/download page and download the latest Windows XP or Vista device drivers for your model laptop,
You need to use a computer that has Internet access to download and transfer the files to your computer.
Mar 01, 2009 | IBM ThinkPad R40 2681
I have a Sony Vaio and I have had issues with Word 2007 for quite some time. 1. Cannot use the touchpad to move around the document area. Can use it on the menus and ribbon bars, but not to posistion the...
You mentioned "recently my laptop never goes into hibernation" and that is the key to your issues. In order to solve that you'll need to reinstall some signficant part of the OS, using the system disk that came with the PC. When hibernation works again, your mouse and Word problems will be fixed, too. I suggest you start by uninstalling and re-installing (the reinstall will be done automatically by the operating system) your touch pad from the Device Manager (Windows Help tells you how to run Dev. Mgr.).
I also suggest after you set Windows to disable Hibernation as it's got a bug in XP (you can do so from the Power options applet in Control Panel).
Dec 20, 2008 | Sony VAIO VGN-N250E/B Notebook
C0000218 (Registry file failure)
Windows cant access required registry files
if you have a xp cd, put it in, start the setup, and enter repair console.
In repair console you should see a
c:>
prompt, type cd windows
cd repair
copy *.* c:\windows\system32\config\
type exit after files have been copyed, overwrite if asked.
type exit
restart pc and try to start windows if this fails
go back to xp setup and perform a repair installation.
Mar 27, 2008 | IBM ThinkPad T20 2647 Notebook
Computers & Internet Logo
118 people viewed this question
Top IBM Computers & Internet Experts
Alun Cox
Are you an IBM Computer and Internet Expert? Answer questions, earn points and help others
