Question about Acer Aspire 7720 Notebook
I beleive my hard drive is not installed
My computer dosent start up a black screen pops up upon power cycling
  • Ravvie Feb 27, 2009
    The computer doesnt freeze. Vista boots fine. The whole computer seems to work fine, except for the fact the screen doesnt work. Its black. Maybe Vista Updates?
  • 530 Answers
Hi im josh in cebu phils. may i help you? Black screen or no display. Most of this problem comes from the video socket slot or video card.try to check your video card if u r using video card be sure it s firmly tighten.lost contact may cause this problem. if the video is built on the mainboard try to check the connection of your monitor chord if it s damge of loosen it can cause this problem. or if it shows a line or a number or a word on the screen.meaing your video is ok. try to reformat your pc or just try to run windows installer if it displays it means that is a software problem. good lcuk friend hope i helped you.
Posted on Feb 20, 2009
Does not boot (hard drive problem?)
When a hard disk makes a clicking sound and the computer does not detect it then the hard disk is faulty. This is commonly known as "The click of death".
There is no way of fixing this hard drive, if you need to recover your data, then there are companies that can recover data off faulty hard drives BUT it will cost you an arm and a leg for their services.The hard drive needs replacing and Windows installed on the new hard drive to get your laptop working again.
Feb 23, 2013 | Toshiba Satellite L655-s5075 Laptop Screen...
Acer aspire 5253 error message no botable device after laptop was dropped on carpet
No bootable device suggests that your Acer Aspire hard disk may have been damaged when the computer was dropped.
You should try opening the cover on the base of the laptop where the hard drive is fitted and check to make sure that the drive is seated firmly and has not come loose with the drop. See the Acer Aspire 5253 Quick Start Guide for the location of the drive cover.
If reseating the drive does not help, then you would need to find any recovery discs that you may have made or received with the laptop plus need to buy and install a replacement hard drive.
Jan 10, 2012 | Acer Computers & Internet
I power up and all i get is pc going into power saving mode , no screen ,just black . tried f-8 upon bootup ,but nothing . tower is running and and monitor has power ,just says powering down power saving ,...
One bad lead can cause a computer to continue on a cycle or to shutdown or fail to detect your hard drive
Test all leads that attach to your hard drive including electrical extensions,IDE,SATA
the leads from your ((motherboard to your hard drive)) make sure they have a secure connection and are not faulty or just replace them there probably old and faulty
make sure all leads that are attached to your drives dvd\cd 3 1/2 inch floppy have secure connections and are not faulty even the electic extensions or just replace them they are probably faulty a computer needs its connections to have an end so any faulty leads will end up with a computer error hope this helps
don
Mar 04, 2011 | Computers & Internet
My laptop was running slow, so we ran the back up disks and it went thru them completly and when it shut down and restarted it came back up with a black screen, so we beleive it may be the hard drive that...
Is this what your laptop looks like on the bottom? If so, the hard drive is located at the lower left-hand corner of the picture, where that bulge in the case is. Remove the battery first, then just pop it out. Before you do that, however, download a linux CD and see if you can access your hard drive from there. It may be that something is corrupt in the registry and the hard drive is fine. You can get a linux CD to try at http://www.ubuntu.com
Mar 04, 2011 | Toshiba Satellite L305-S5924 Laptop
Black screen with info that pops up immediately upon booting up
Hi:
That sort of message comes up when your computer is unable to boot to the hard drive. Those messages basically mean that it is trying to boot from a network, (which it isn't hooked upt to). Your hard drive could have failed, or your boot sequence could have been inadvertently changed too.
First, make sure your thumb drive is not installed in the laptop, as this can cause the problem too.
You can check your boot sequence by rebooting your computer, and entering the BIOS, usually by hitting F1 or F2 on start up. Tab over to the Boot section, and see what the boot order is: Usually it should be: CDROM drive, Then Hard drive, then removeable drives.
If this is ok, check and make sure that your hard drive is showing up in the BIOS on the main page too.
If not, it might be bad....
Hope this helps!
Apr 23, 2010 | Toshiba Satellite X205-SLI1 Notebook
My screen is completely blacked out and I can't reboot my discovery cd. I shut off my computer with the cd in the drive and power up and press f12 and nothing happens
your hard drive or something dosent work properly go to the place u bought it and tell them that your screan blacked out they will fix it
Mar 16, 2010 | Toshiba Satellite M35-S456 Notebook
Windows does not start up upon booting, instead a black screen comes up and a few lines come up saying something along the lines of media not found. and this repeats itself without ever leaving the screen....
there should be somthing that tells you to press f12 or f2 to set up i believe your machine is not booting the hard disk first once you get to the boot menue you can change this setting
Sep 10, 2009 | HP Compaq Presario V2000 Notebook
"Disc Boot Failure" upon powering up the compaq
your harddisk is not detected.
open your cpu case.
then reattch the power code and datacode to hard disk.
Nov 03, 2008 | Compaq Presario S6300NX PC Desktop
Acer Aspire 7720 Notebook Logo
Mohammed Ebrahim M
Mohammed Ebrahim M
